Audi A4 B6 1.8T: Oil Pressure Indicator Issues - Hot Engine, Low RPM, Oil Pump Replacement, 5W40
LgN1 39768 16
Why does the oil pressure warning light on an Audi A4 B6 1.8T come on when the engine is hot and the revs drop below about 2000 rpm, even after replacing the oil pump and using 5W40 oil?
Check the oil pressure with a reliable gauge and also check the oil pressure sensor/switch, because if the measured pressure is OK the warning light is often caused by a faulty sensor or wiring rather than the pump itself [#16382921][#16385034][#16836654] The thread also notes that on a warm engine the pressure should rise with rpm, and around 2000 rpm it should be at least about 2 bar; one reply says the light can come on below roughly 1800 rpm if the pressure is under the required 1.6 bar [#16383080][#16829170] If the pressure is still low after a new pump, inspect the oil pickup/strainer (“dragon”), the pressure relief valve, the oil filter, and pump wear/installation again [#16836654][#16839029] One member also mentioned the camshaft timing side and the turbo lubrication as possible places where oil loss could occur, but the main advice was to verify real pressure first and then replace the sensor if the gauge is good [#16383062][#16836654]
  • #1 16382628
    LgN1
    Rate: 17
    I have a problem with sometimes turning on speed below 2000 and a hot engine oil pressure gauge. In the car I recently replaced the oil pump, because it did not give pressure, acetabulum, oil flooded 5w40 and the problem of the flashing light did not disappear. What could be the reason? I would like to add that now the system pressure, idle speed and heated engine pressure on the gasoline are around 1.5 bar and the gas is about 1.1-2 bar.
  • #2 16382921
    piotrekwoj1
    Help: 947
    Rate: 3433
    LgN1 wrote:
    gasoline about 1.5 bar and gas about 1.1-2 bar.
    Here you curious what relationship with the oil pressure has the type of fuel?
    Did you check the sensor?
  • #3 16383062
    Jackall
    Help: 77
    Rate: 396
    Maybe the gas has lower revolutions. The oil pressure can also be lost by the timed camshafts. But if the gauge shows well, the sensor can hit.
  • #4 16383080
    oktawian89
    Help: 52
    Rate: 444
    How much is heated at 2000 rpm?
    It has to have MINIMUM 2 bar.
  • Plans accurate pressure test and suspects oil level sensor
    #5 16384808
    LgN1
    Rate: 17
    The gas has less, because the gas is to regulate and keeps the revs around 650. But it ignites usually around 1800 rpm
    Or maybe something is wrong with the turbine and its lubrication fails? But according to me, it goes well and you do not hear anything disturbing. On Monday I will go and measure again on the exact pressure gauge, according to the mechanic something wrong, there may be something with the oil level sensor, because sometimes it also lights up when braking or accelerating
  • #6 16385034
    Duchowny77
    There is no relationship ... I think the sensor is the solution.
  • #7 16385814
    LgN1
    Rate: 17
    If it is damaged, the sensor would not be constantly burning from the pressure? Can someone tell you if there are two sensors with this motor or just one? Around the oil filter
  • #8 16386055
    matimon22
    Help: 51
    Rate: 336
    One sensor
  • #9 16386896
    Jackall
    Help: 77
    Rate: 396
    Maybe it's orange, it's shining?
  • #10 16392567
    LgN1
    Rate: 17
    Unfortunately, red, 2-3 times winks and disappears, ol zuruck or something like that
  • #11 16829161
    elDominiko
    Say you have solved the problem of this control?
    I have a similar and no one can help: the measured pressure is ok and the red indicator lights up at 1800 revolutions and goes out above 2000. pressure at 1800 2 bars at 2000 2.5bara.
  • #12 16829170
    matimon22
    Help: 51
    Rate: 336
    Little. Probably a little below 1800 / min there is no required 1.6bar and for this moment it lights up.
  • #13 16836311
    LgN1
    Rate: 17
    The problem is still unrelated. One mechanic claims that the reason may be knocked clocks, because once in a while they go crazy, and the speed tip does not work smoothly
  • #14 16836654
    lukashb
    Help: 416
    Rate: 417
    Mother, let's not put up ... no clocks, I've done such defects, including dumps, the repair was fast. What I did:
    - Micha's dismantling,
    - cleaning the dragon,
    - pump collection, in order to determine the wear of the sprockets and the stripping of the lid and housing
    - checking the operation of the bleed valve with the compressor several times
    - Replace the oil filter with a branded one
    - pressure measurement on slow, warmed up, and at 2 - 3 - 4 thousand turns, is supposed to grow, say linearly, 2 thousand - 2 bars, 3 thousand 3 bars, etc. It can be deco less, of course, and more.
    - Then a good pressure sensor screwed into the base of the oil filter, cheap like to press through the plug and oil leaks, of course, do not work at the same time.
    If you do the above, I guarantee, you will repair the car in 1 day and do not worry if the turbo is obliterated or not, because the weak supply of oil. greetings
  • #15 16839029
    LgN1
    Rate: 17
    My friend :
    The cleaned dragon
    MAN filter
    New oil pump
    Only this valve is not cleaned, and the problem is still there
  • #16 16839127
    piotrekwoj1
    Help: 947
    Rate: 3433
    What pressure do you have?
  • #17 16841527
    LgN1
    Rate: 17
    At the time of the measurement I was not, but the mechanic claims that it is good. The indicator light usually lights up at 1800 rpm
The discussion revolves around oil pressure indicator issues in an Audi A4 B6 1.8T, particularly when the engine is hot and at low RPMs. The user has replaced the oil pump and is using 5W40 oil, yet the oil pressure warning light persists. Responses suggest checking the oil pressure sensor, as it may be faulty, and highlight that the oil pressure should be at least 2 bar at 2000 RPM. Some users speculate that issues with the camshaft timing or turbo lubrication could also contribute to the problem. The user notes that the warning light activates at around 1800 RPM and sometimes flickers during acceleration or braking. Various troubleshooting steps are discussed, including measuring oil pressure with a reliable gauge and ensuring proper maintenance of the oil system components.
