AGM 12V 7Ah & 12Ah Battery Regeneration: High Temp, Distilled Water, & Charging Tips
procsa 24975 6
  • #1 16746794
    procsa
    Help: 173
    Rate: 364
    Hello, I have several AGM batteries 12V 7Ah, and 12Ah with UPS, worked at a fairly high temperature. 30 degrees, so they are "dried" after connecting the meter, they indicate from 8-10V, of course, after connecting the automatic rectifier, the voltage immediately increases to 15V and the rectifier turns off.
    I have read all TEAMT dedicated to battery regeneration, I already know quite a lot, but I also have a few questions, ambiguities ...
    1. Cork the cells after adding distilled water? I did it, but some plugs when charging (20V 0.5A transformer + 1n4007 diode + 14V 0.15A bulb) fired after a while ... with this connection, the battery voltage is about 12-13V, the bulb is lit all the time, the battery is charging ok 150-200m
    2. If the battery (other than above, in better condition?) 12V 7Ah when charging set to 14V 1A consumes max current (1A) and at the same time one cell is "boiling", what could this mean? After disconnection, the voltage drops to 12V, after connecting the 12V 21W bulb, the voltage drops to 9V but the bulb shines.
    3. Battery charged with 14V with 0.2A for about 24h, disconnect from charging, wait, how much, can it discharge? Or maybe it loads too short, people wrote in the forum that they load for months ?? What about stopping the cells, water and traffic jams?
    4. If I understood everything correctly, such batteries can be charged with such a set (20V 0.5A transformer + 1n4007 diode + 14V 0.15A bulb) or a higher power bulb to charge with higher current, but such a simple set as above will prevent battery overcharging, i.e. "accumulates" itself voltage and current too high for battery?
    Mainly I mean "clogging" the goal, for stupid reason, if the traffic jams blow, there is no force to stop such a cell because it may end badly, on the other hand, if I leave the cells open for longer, will the water that I poured evaporate ?
    I note that I do it purely as a hobby, and so I did different power supplies to test different batteries differently.
    Can I stick to this statement:
    "... the battery 12V / 7.2Ah is the discharge current 1 / 20C we get the closest to the 12V / 5W bulb. And such a bulb a functional 7.2Ah battery should discharge to 10.5V in 20 hours ..." source
  • #2 16747595
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    First of all, if you add too much water, you will harm.
  • #3 16747670
    Wlodek22
    Help: 78
    Rate: 526
    After UPS, there's nothing to regenerate, because dry batteries corrode very quickly. Open one and look for positive discs.
  • #4 16747933
    procsa
    Help: 173
    Rate: 364
    One smaller 6V 7Ah battery flooded completely and after pouring it was "rust", this battery works best ...
    Two batteries 12V 7Ah I charge the second day with a current of about 150mA, at first the voltage was at 12.5V, now it dropped to 9 ... in one jumps from 9 to 11, One at 14V can download up to 4A, but then you can hear that it is cooking in the cells so I don't leave it for such a long time.
    Initially, the batteries had about 8V, but they took 3-5mA, after flooding and waiting "started" as described above.
    If I reason well, these 12V and 4A, and without charging a drop to 9V indicate a short circuit of one cell. When trying to measure individual cells, it also works out, one cell has 0.3V, similar to the other battery.
  • #5 16747952
    Wlodek22
    Help: 78
    Rate: 526
    Take them to the purchase of scrap metal and with a little luck for a small fee you will find another toy, more promising. If you visit several scrap yards, you will find it at the bank.
  • #6 16748122
    procsa
    Help: 173
    Rate: 364
    But I like playing with acids and currents, so why do I have the joy of receiving it? :)
  • #7 16748260
    Wlodek22
    Help: 78
    Rate: 526
    You did not understand
    The batteries you have are "dead" and you will find other, still "alive" scrap.
The discussion revolves around the regeneration of AGM (Absorbent Glass Mat) batteries, specifically 12V 7Ah and 12Ah models, which have been subjected to high temperatures and show low voltage readings (8-10V). Users share experiences regarding the addition of distilled water, charging methods, and the effects of overcharging, such as cell boiling and potential short circuits. Concerns are raised about the viability of the batteries, with suggestions that heavily corroded or "dried" batteries may be beyond regeneration. Some participants recommend discarding the batteries for scrap, while others express a desire to experiment with battery restoration techniques despite the risks involved.
