Battery Not Fully Charging: 55 Ah 12V, Distilled Water Added, 5A consumption, 10.5V issue
GT2x 7476 9
  • #1 16628991
    GT2x
    Rate: 24
    Hello, I have a 55 Ah 12 v battery
    Recently, I flooded it with distilled water because the cells were above the level of the liquid, I added enough to cover the water (what you can see after unscrewing the plugs, are probably the targets, I don't know anything about it) and then connected it to the charger.
    After 5 hours of charging, the voltage was the same, i.e. 10.5V.
    After 10 hours also the same.
    The battery still consumes 5 A and is warm.
    It behaves as always under load.
    What could be the cause?
  • #2 16629007
    DiZMar
    Help: 2880
    Rate: 6580
    Which means It behaves as always under load ? You wrote as always that is, like an efficient battery. I think right?
    Can you start the car with this battery or charge it much differently (several road bulbs in parallel)? If so, what is the voltage on it without load and with load. If you start the car, the voltage on it without load is higher than 10.5V (~ 13V). The meter is correctly pointing? These 10.5V are with the rectifier connected or disconnected? You provide information too selectively (incomplete) to draw meaningful conclusions.
  • #3 16629012
    Wlodek22
    Help: 78
    Rate: 524
    One cell damaged, compact. The rest of the cells use too much voltage, hence electricity and heat.
  • #4 16629028
    DiZMar
    Help: 2880
    Rate: 6580
    Yet
    GT2x wrote:
    It behaves as always under load ...
    Your conclusion contradicts the author of the topic. Although it's hard to guess what it means as always .
  • #5 16629031
    SKM 1964
    Help: 150
    Rate: 660
    Measure the electrolyte density with the aerometer. :|
  • #6 16629828
    GT2x
    Rate: 24
    I was tired already, sorry for the lack of information.
    I connected a 12V 70W car fridge to it and it worked, the voltage dropped to 9.9V.
    The meter shows well for sure, the voltage after connecting the rectifier is 11 V.
    Unfortunately, I do not have this device for the density of liquids, but I know that the electrolyte has never been changed, the battery is from 2010.
    All devices will not work on it because the voltage is too low.
    On it, at a load of 8 Amps, the voltage from 13.5 V fell to 13.
    Now it is similar, only with other tensions, but the difference is the same.
    I was also wondering if it could be a contained cell, but what did it happen to?
  • #7 16629838
    398216 Usunięty
    Help: 3925
    Rate: 9263
    GT2x wrote:
    the targets were way above the fluid level ...... the battery is from 2010
    Battery for disposal.
  • #8 16630798
    SKM 1964
    Help: 150
    Rate: 660
    He's 7 years old anyway, but some of them work even longer. If I were you, I would have checked him more closely. :|
    What producer ?? :|
  • #9 16630826
    GT2x
    Rate: 24
    When I get home, I will let you know which producer, because I don't remember exactly.
    It worked fairly well, except for a small capacity (about 25 Ah, it was 55)
    Only after adding distilled water something broke.
    I always poured enough to keep it at the target level.
  • #10 16630827
    DiZMar
    Help: 2880
    Rate: 6580
    GT2x wrote:
    WITH...
    It was and se ne wrati. What was and is not recorded in the register. I was young and beautiful once too, and now ...
    It happened because it happened. It was flawed and that's it. You don't need this information for anything.
✨ The discussion revolves around a 55 Ah 12V battery that is not fully charging after distilled water was added to the cells. The user reports that the battery voltage remains at 10.5V even after extended charging, and it consumes 5A while warming up under load. Responses suggest potential issues such as a damaged cell, incomplete information regarding the battery's performance, and the need to measure electrolyte density. The user confirms that the battery, which is from 2010, has not had its electrolyte changed and has shown reduced capacity. Suggestions include checking the battery more closely and considering disposal due to its age and performance issues.
