[Solved] Mieczyslaw Mercedes Class 169 CDI 2008: Engine Humming at Idle Speed, 95,000 KM Mileage
krzysztofx2 12036 19
Why does my 2008 Mercedes Class 169 CDI sometimes gently wave at idle and make a humming sound, even though it has power, no warning lights, and all filters have been replaced?
A thermostat that does not fully close can cause this kind of idle wavering: the engine then stays below 80°C while driving, drops temperature at idle, and the ECU starts misfuelling, which makes the revs hunt [#17044426] In the thread, the car was checked at a Mercedes service, injections were OK, and the only stored fault was for the HFM air mass meter signal line, but clearing that error did not solve the problem [#16904515] Unplugging the MAF made the engine stop wavering and run livelier, so the flow meter was suspected too [#16907194] However, the final fix was replacing the thermostat; after that the coolant stayed at 90°C and the idle wave disappeared [#17044426]
  • #1 16747141
    krzysztofx2
    Rate: 42
    Hello, honorable forum members
    I have a small problem with my mieczysław and the class is 169 cdi 2008, the machine has a safe mileage of 95,000 km, but sometimes at idle the engine gently waves. You can hear such hum, hum ...
    All filters replaced The engine has a lot of power
    The turnover on the indicator is approx.
    No lights are on
    It burns to the touch
    Nothing too bad happens after that
    What could it be?
  • #2 16747323
    kilun1
    Help: 5
    Rate: 64
    It might be catching left air somewhere. Check the intake system for chafing
    Moderated By T5:
    A gasoline engine is not. Please read the thread carefully.
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #3 16772306
    krzysztofx2
    Rate: 42
    Hello, the intake system is functional, the erg valve is cleaned
    And from time to time, mieczysław will make a slight wave when idling
    Gentlemen, maybe other suggestions
  • #4 16772335
    jenusz11
    Help: 33
    Rate: 196
    most likely fault of the fuel pressure regulator
  • #5 16772348
    krzysztofx2
    Rate: 42
    there are two regulators on both ends of the injection rail, I wonder which regulator is on the right or left
  • #6 16772358
    jenusz11
    Help: 33
    Rate: 196
    one is a pressure sensor the other is a regulator
  • #7 16772366
    krzysztofx2
    Rate: 42
    and which side is the regulator from the side of the tubular fluid reservoir
  • #8 16825148
    krzysztofx2
    Rate: 42
    Replacing the regulator did not give anything, it is the same as it was on a warm engine, from time to time mieczysław at idle is slightly undulating
  • #9 16864452
    krzysztofx2
    Rate: 42
    Gentlemen, maybe any other suggestions for undulating these spins
  • #10 16864630
    Dziarski Hank
    Help: 246
    Rate: 934
    Where are the diagnostic results? How can an engine be blindly repaired with so much control electronics?
  • #11 16865419
    krzysztofx2
    Rate: 42
    I was no bugs there
  • #12 16865477
    Dziarski Hank
    Help: 246
    Rate: 934
    I am not asking about errors - air mass, EGR valve test, required and current injection pressure, corrections on injectors ...
  • #13 16865537
    krzysztofx2
    Rate: 42
    Well, I didn't do that
    Because the car is running well and nothing is wrong, the lights are not lit.
    It's just that it annoys me
  • #14 16865626
    moto-kord
    Help: 137
    Rate: 505
    But
    krzysztofx2 wrote:
    sometimes at idle the engine gently sways. You can hear such hum, hum ...
    Do a decent computer diagnostics.
    air mass, EGR valve test, required and current injection pressure, corrections on the injectors ...
    Greetings.
  • #15 16865710
    krzysztofx2
    Rate: 42
    I'll go to the site
    I'll let you know how it turned out
  • Suspected faulty MAF causing idle speed surging
    #16 16904515
    krzysztofx2
    Rate: 42
    welcome back
    I was in a private Mercedes service on sd and du..pa only the mileage of 97,000 km was confirmed
    Injections OK, only error stored in memory (check component B2 / 5 HFM air mass meter signal line short circuit or break)
    The guy erased the error for which he charged 50 zlotys and it did not help
    Besides, there was one more symptom
    Such that not when on a warm engine at idle speed spontaneously increase the speed to 1000 rpm
    My question
    Gentlemen, can't the flow meter be damaged that these rotations wave so much?
    But how to check if it is operational?
    I think to myself as if I unplug the flow meter plug for a moment and see if the rotation would wave then
  • #17 16906060
    konrad_bugaj
    Rate: 57
    I had such a case in w168. After replacing the cr pressure sensor and regulator, the problem disappeared. But I don't remember if there was a pressure error ?. I would suggest looking for a "foreman" who can assess the fluctuations in the set and current pressure. Ask, look, do not replace it with the proverbial dump. On websites, most are students. Not insulting the maestro, of course :) .
  • #18 16907194
    krzysztofx2
    Rate: 42
    I unplugged the plug from the flow meter and the car does not wave and how would it be livelier because when I connect the plug back it starts to wave and if something was choking the engine
    So this is probably going to be it
    Only if this flow can be cleaned somehow or it is better to buy a good used one because the price of new ones is expensive
  • #19 17044426
    krzysztofx2
    Rate: 42
    The thermostat was the culprit
    The thermostat was not fully closed and the temperature was rock solid
    When driving, the temperature never exceeded 80 degrees and at idle it dropped to a few degrees
    And then the computer went crazy and didn't fill up the fuel
    And now the temperature is constant at 90 degrees and the engine is warmed up and the wave has stopped
    I recommend everyone to replace the thermostat when it has a temperature below 80 degrees and not to listen to fairy tales that Mercedes have that because it is not true
    I close the topic
  • #20 17046288
    krzysztofx2
    Rate: 42
    I close the topic
The discussion revolves around a 2008 Mercedes Class 169 CDI experiencing engine humming at idle speed, with a mileage of 95,000 km. The owner reports that all filters have been replaced and the engine has good power, but there are occasional fluctuations in idle speed. Suggestions from forum members include checking for air leaks in the intake system, inspecting the fuel pressure regulator, and performing comprehensive diagnostics to assess the air mass meter and injection pressure. A significant finding was that a faulty thermostat could cause temperature fluctuations, leading to erratic engine behavior. The owner confirmed that replacing the thermostat resolved the issue, stabilizing the engine temperature and eliminating the humming.
TL;DR: A 2008 Mercedes A‑Class W169 CDI with 95,000 km showed idle “humming” until a faulty thermostat was replaced; “Do a decent computer diagnostics.” [Elektroda, moto-kord, post #16865626] Why it matters: This FAQ helps Mercedes W169 owners diagnose idle surging/hunting and avoid unnecessary parts swaps.
What’s the most likely cause of idle humming on a W169 CDI like this thread?
In the documented case, a stuck‑open thermostat caused low operating temperature, unstable fueling, and idle hunting. Replacing the thermostat restored a steady ~90°C and stopped the surging. Start by checking coolant temperature behavior before buying sensors. [Elektroda, krzysztofx2, post #17044426]
How do I confirm the thermostat is the culprit?
Watch coolant temperature. If it stays below ~80°C when driving and drops at idle, suspect the thermostat. A proper warm engine should stabilize near 90°C. After replacement, the user reported stable temp and smooth idle. [Elektroda, krzysztofx2, post #17044426]
Quick How‑To: check for thermostat‑related idle hunting
  1. Cold start, drive gently, and monitor coolant temperature trend.
  2. Note if it won’t exceed ~80°C cruising and falls further at idle.
  3. Replace thermostat if temps never reach ~90°C and idle surges persist. [Elektroda, krzysztofx2, post #17044426]
Is unplugging the MAF (HFM) a useful test on this engine?
Yes. The owner unplugged the flow meter, and the idle stopped waving and felt livelier. Reconnecting brought the surge back, suggesting MAF involvement or masking a thermal issue. Use this as a quick A/B test, then diagnose properly. [Elektroda, krzysztofx2, post #16907194]
What does error B2/5 HFM signal line short/break mean in plain terms?
It indicates the hot‑film air‑mass meter’s signal circuit saw a short or open. Expect erratic airflow data and idle instability. The same session noted confirmed injector health and a spontaneous idle rise, supporting airflow signal suspicion. [Elektroda, krzysztofx2, post #16904515]
Which live data should I log with Star Diagnosis (SD) to find the root cause?
Log air‑mass value, EGR test status, commanded vs. actual rail pressure, and injector corrections. As one expert said, “air mass, EGR valve test, required and current injection pressure, corrections on the injectors ...”. [Elektroda, Dziarski Hank, post #16865477]
I replaced the fuel pressure regulator and nothing changed—normal?
Yes. In this thread, swapping the regulator did not affect the idle wave. This shows why data‑driven diagnosis beats part‑swapping. Consider temperature control and airflow signals before rail hardware. [Elektroda, krzysztofx2, post #16825148]
Are warning lights expected with gentle idle waves?
Not always. The owner reported no warning lights and normal starting and power despite the humming idle. Don’t rely on lamps alone; inspect temperatures and scan live data. [Elektroda, krzysztofx2, post #16747141]
Why does idle sometimes jump to ~1000 rpm on a warm engine?
The session documented sporadic rises to ~1000 rpm along with an HFM signal fault. Irregular airflow readings or thermal mismanagement can trigger unstable idle control. Capture a live trace when it happens. [Elektroda, krzysztofx2, post #16904515]
What is HFM on a Mercedes—same as MAF?
Yes. HFM means hot‑film mass air flow sensor. Mercedes diagnostics use HFM wording, as seen in the B2/5 error. It is the engine’s primary airflow sensor. [Elektroda, krzysztofx2, post #16904515]
Will cleaning the EGR valve solve idle hunting?
Not in this case. The EGR had been cleaned and the intake checked, yet the idle wave persisted until the thermostat was replaced. Prioritize temperature regulation checks. [Elektroda, krzysztofx2, post #16772306]
What did a professional SD visit actually find here?
The visit confirmed 97,000 km, good injectors, and stored B2/5 HFM signal fault. The shop cleared the code for 50 PLN, with no improvement. Use SD to record live data, not only erase faults. [Elektroda, krzysztofx2, post #16904515]
After fixing the thermostat, what should I expect at idle?
Expect a steady coolant temperature near 90°C and the idle surge to disappear. The thread author reports stable temperature and smooth operation after replacement. Verify with a warmup and short drive. [Elektroda, krzysztofx2, post #17044426]
“Do I need diagnostics if the car drives fine?”
Yes. As advised: “Do a decent computer diagnostics.” Check airflow, rail pressure, injector trims, and EGR tests to prevent blind repairs. A smooth drive can still hide control issues. [Elektroda, moto-kord, post #16865626]
