Re: Fake JBL Charge 3 - No Bass, Bluetooth Delays & Improving Low Tones on Counterfeit Model
Dawid120 19908 4
  • #1 16757658
    Dawid120
    Pupil
    Hello, I have a problem I bought a counterfeit JBL Charge 3.
    I can not afford this speaker for 700 PLN so I bought a counterfeit with the thought that it will somehow play. The loudspeaker is loud, although the bluetooth has terrible delays but skipped.
    What can be done to deepen the low tones passive membranes are relatively stiff to stretch them somehow as so how or try to seal this speaker all the holes connecting plastic, etc ..
    Immediately I will mention that I do not mean that he would play like an original jbl because this is not what he wants, but he would like to improve this sound to a small degree.
  • #2 16758122
    szymon122
    Help: 302
    Rate: 758
    So you want to make the original from fakes ...
    You would have to replace the loudspeakers, the amplifier, the battery, so you would need an original loudspeaker to distribute it and put everything into yours: ')
    You will not do anything.
    Question about bass processing and speaker DSP
    #3 16758431
    Jarosx9
    Help: 265
    Rate: 401
    I would like to get to know / apply this sound / bass processor. In fact, in these portable loudspeakers / soundbars there is some kind of bass that is audible (which is rather pious at the 9cm speaker - however, it sounds like 16 cm). Is it only the subsonic filters / bottom and high pass filters, or something more behind this.
    What kind of "processors" are there and what they do with it, it can be simulated with a ffmpeg or similar type of combine.
  • Smaller front drivers and possible missing passive radiator
    #4 16758472
    Dawid120
    Pupil
    as for the processor, I have no idea what is sitting there but the speakers on the front are certainly not 9 cm only some max 5 or 6 1 from passive speakers has been pulled out or otherwise moves slightly and how would something with this bass a little improved and as to the tightness of the housing it is rather leakproof tested water resistance and nothing has flown inside the speaker works yet wonders if there is any soundproofing, how can not it be muffled inside?
  • #5 17341560
    jhusak
    Read about passive membranes. They do the job, but they have to be tuned. In the case of this loudspeaker without basses it is necessary to:
    - seal the housing, probably with silicone
    - lightly weighed (on trial with plasticine, then with a replacement, e.g. with a cap or a few m3 glued on a thermogram or epoxy) passive side membranes.
    Should help.
