JBL Charge 3 vs Flip 4: Comparing Membrane Behaviors, Tightness, and Air Escape Issues
bawdoo 3897 2
  • Charge 3 passive radiators move air normally
    #1 17192833
    bawdoo
    Hello, I am facing the choice of the jbl charge 3 or flip 4 mobile speaker, I have this question for you, today I watched charge 3 in the neon and flip 4 unfortunately the charge was discharged so I did not test it. Why in charge 3, after pressing one of the side membranes, the other one as if it comes out, I know that this is an understandable problem that after pressing and holding the membrane, the second one comes out and after a second it returns to its original place, i.e. I press the second one is pushed out and returns, after pressing two at once you can hear that the air is escaping, it's not my rooms, because in flip 4 something like this does not occur and the membrane does not hide, is it normal that the charge 3 is not tight ???
  • #2 17192902
    mieszaczwcz
    Help: 185
    Rate: 258
    All these behaviors are normal, the sizes of the equalizing holes are closely matched to the characteristics of the speakers in such a way that the frequency response of the entire loudspeaker is as wide and even as possible. the designer wanted to achieve.
  • #3 17193066
    bawdoo
    I buy in an hour what do you recommend flip 4 or charge 3? I care about the power
    Added after 8 [hours] 29 [minutes]:
    I bought a charge and it is tight, the neonat was damaged, there are no holes
