Samsung B2710 Speaker Panel Removal: Fixing No Sound Issue Due to RTC Battery Electrolyte Leak
MM2X 5772 2
  • Asking how to remove the speaker panel safely
    #1 16758496
    MM2X
    Rate: 618
    No sound on the phone, probably the problem of the pouring electrolyte from the RTC battery, topic described on the forum. I have a problem with removing the speaker panel, I don't want to force myself not to tear something off.
    It looks as if it is pressed on the latches (screen-red selection) but it cannot be undermined.
    Thanks in advance for your advice and suggestions. Samsung B2710 Speaker Panel Removal: Fixing No Sound Issue Due to RTC Battery Electrolyte Leak Samsung B2710 Speaker Panel Removal: Fixing No Sound Issue Due to RTC Battery Electrolyte Leak
    sagem90
    Help: 22
    Rate: 85
    First of all, remove the tape of the side keys and the diode from the flashlight and bend the plastic strongly and it will come off :) From the red mark to the LCD-free side
  • #3 16758885
    MM2X
    Rate: 618
    0k ,, it went :)
    I removed the battery (green), one of the chokes was "digested" by the electrolyte and it fell apart, the other was desoldered, I made jumpers as in the topic:
    https://www.elektroda.pl/rtvforum/topic2618826.html#12829679
    I only obtained the fact that now I have the sound of the keys, but unfortunately there is no sound :(
