[Solved] Samsung LE40R71B LCD TV Issue: Relay Clicking, BN44-00134A Power Supply Troubleshooting
andrasoni_lucian 3585 1
  • #1 17972376
    andrasoni_lucian
    Rate: 11
    I have this TV equipped with the source BN44-00134A.Tv does not start, it is heard how the relay is continuously coupling and disconnecting. The stable voltage drop is STB = 6.5V, P-ON / OFF varies between 0.2-2.5V in normal operation = 2.6V) PFC between 360-385V (when going is 382V). All electrolytes, secondary-primary, have been changed, except the 220uF / 450V which is ok. In this state, if measure the voltage on the pins 1-2 to optocouplePCS802, the relay stay connect and tv work normally . I have replaced the PCS802,801, the ICS 802 (KIA431), the QP803, the QS801, the QS802 checked. If I stop (unplugged) and I restart the tv in a few minutes, it works normally, if I leave it a little longer, the defect returns. Any suggestion is welcome, I do not think it would be the problem with the mainboard. Thank you!
    I attach the power supply+ inverter schematic model BN44-00134A
    • samsung_bn44-00134a.pdf (362.93 KB) You must be logged in to download this attachment.
  • #2 17974816
    andrasoni_lucian
    Rate: 11
    Solved by replacing the eeprom 24C32 (IC903) with empty memory (FF). Thanks!
