Locating ABS Sensor Cable in Audi A4 B6 1.6 2002 Model - Procedure to Dislodge Contacts in Cube
1986Sylwek1986 23019 7
  • #1 16768873
    1986Sylwek1986
    Audi a4b6 1.6 and so I got the wrong right rear abs sensor so I wanted to dislodge the contacts in the cube only that I can not locate it. The sensor cable enters the threshold and after removing the rubber plug is only 15cm of the cord and no ankle. I thought maybe from the inside, so I cut down the couch and rolled up the carpet, but nothing is there. Anyone have any suggestions? I do not want to lure myself to damage anything. I will add that the Audi is a 2002 saloon with Dani.
  • #2 16768894
    Pedros050
    Help: 2471
    Rate: 3928
    Hello. The fact that it is long but it should be a cube with a plug. Well, unless somebody got the cables?
  • #3 16768901
    1986Sylwek1986
    Well, it should. I have watched the sensors, this cube is right behind the rubber end cap and nothing at all. I need to buy an inspection chamber.
  • #4 16768923
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6433
    Measure the resistances as a break, replace the sensor.
  • #5 16769665
    jarek66
    The cable is 1360 mm, so you can determine the place of the plug
  • #6 16769812
    Help: 1405
    Rate: 6433
    After the couch or in the bacon. Well, take the undress and finally find the plug and measure.
  • #7 16769843
    masay1
    Help: 40
    Rate: 81
    the sensor's electrical connector is under the sofa ...
    for the measurement only it is enough to "lift" the seat of the sofa ...
    while the sensor has to be removed for replacing the sensor (chassis)
  • #8 16774277
    1986Sylwek1986
    The connector was behind the backrest of the rear seat. I have measured resistances and it turns out that the sensor has been released.
The discussion revolves around locating the ABS sensor cable in a 2002 Audi A4 B6 1.6 model. The user initially struggles to find the connector after mistakenly acquiring the wrong right rear ABS sensor. Responses suggest that the electrical connector is located behind the backrest of the rear seat, and it is necessary to lift the seat to access it. Measurements of resistance are recommended to confirm the sensor's functionality, and it is noted that the cable length is approximately 1360 mm, which can help in determining the plug's location. The user ultimately discovers the connector behind the rear seat backrest and confirms the sensor's release through resistance measurements.
