[Solved] Audi A6 C6 2005: OBD Diagnostic Connector Diagram, Wire Locations, Englishman w/ Spacer
TheLast1 7728 5
  • #1 16379953
    TheLast1
    Rate: 19
    Hello. I need a diagram of the Audi A6 C6 Diagnostic Connector. The car does not connect to any computer. It is an Englishman with a spacer, possibly a broken wire.
    Added after 19 [minutes]:
    Checked with a meter, the weight is on brown, 12V from the fuse is OK. I am interested in 2 thin orange wires. I am asking for a hint where they are going, to which module or preferably if someone dropped the diagram. greetings
  • #2 16380090
    sk700
    Help: 173
    Rate: 420
    I don't want to look for schematics, but these wires go to the gateway. What is the tension on them relative to the mass?
  • #3 16380103
    TheLast1
    Rate: 19
    I have no tension on the orange ones
  • #4 16380161
    sk700
    Help: 173
    Rate: 420
    Orange-red A11 and orange-brown A24 of J533 behind the passenger glove box.
  • #5 16380201
    TheLast1
    Rate: 19
    Thanks for your help, I'll check the crossing over the weekend. greetings
  • #6 17381636
    TheLast1
    Rate: 19
    Soldering the broken cable. Problem solved.
