Connecting 400W 12-230V Inverter: Fuse Size (33.3A), Cable Thickness for 400W & 100W Loads
tbik 11316 11
Can I power a 400W 12V-to-230V inverter from a car cigarette lighter socket, and what fuse and cable size should I use for 400W and for about 100W loads?
For a 400W inverter, do not rely on the cigarette lighter socket; it should be wired directly to the battery with a fuse close to the battery and a much heavier cable. A 40A fuse and about 4–6mm² cable (10–12 AWG) were recommended, because the inverter can draw more than 33A from 12V and may have 650–800W startup surges [#16771170][#16776499] The 15A lighter fuse does not mean you can safely run 180W continuously, because the socket and wiring can overheat long before the fuse blows, especially with continuous load [#16775621] For around 100W, one reply suggested that 1.0mm² cable would be enough, and another said a good-quality factory lighter installation is usually fine only up to about 100–120W inverter output [#16775216][#16775110]
  • #1 16770611
    tbik
    Rate: 34
    I am going to connect a 230V converter with a capacity of 400W to the cigarette lighter socket (12V).
    (If I'm not mistaken then):
    If I load it like that, then the 400W to 230V will give ~ 1.7A
    And now the questions:
    1. Will it be ~ 33.3A for DC 12V then? Do I have to put in such a fuse?
    2. What thickness should the cores of the cable supplying this current to the inverter be when the load is 400W?
    3. What thickness should the cores of the cable supplying this current to the converter be when it is loaded with 100W? 4x thinner enough?
  • #2 16771170
    enhanced
    Help: 963
    Rate: 883
    1) That is 40A or more. Because the momentary jumps on the converter probably 600-800W can be (unless you have already given the temporary ones, not the long constants).
    2) 2.5mm2 is enough for me - for this, of course, a solid cigarette lighter socket because it is very important because otherwise it will heat up a lot.
    3) This point is nonsensical - you either install them in reserve or not at all. Unless you are asking for some other reason?
    You will actually use up to 400W or only max 100W? What will you connect to it?
  • #3 16772756
    tbik
    Rate: 34
    Thanks for the answer.
    Ad1. These 400W are its continuous capacity, the jump is 650W.
    Ad2. I did not replace the socket, the original fuse is 15A, i.e. up to 180W, I can probably connect it safely without replacing the socket.
    Ad3. I am going to connect to 90W at the peak, but I also wanted to know how thick (not handy, stiff and heavy) would be needed if I ever wanted to use its full 400W.
    So what lived for 100W? How is it calculated?
  • #4 16775110
    tzok
    Help: 3176
    Rate: 6549
    Buy yourself a 12V laptop power supply and do not combine it with an inverter, because I suspect you need it for that. The factory installation of the lighter (provided that it is of good quality and was not used as a lighter) will withstand up to 150W at 12W, which is about 100-120W at the inverter output.
    :arrow: http://lumier.pl/kalkulator/
  • #5 16775134
    tbik
    Rate: 34
    Yes, it is supposed to be for a laptop, but I already have an inverter, and all laptop car adapters that I meet either do not have a Lenovo tip (rectangular) or are very expensive.
    Thanks for the link.
  • #6 16775216
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    You could buy an older Lenovo and buy a square adapter.
    Yes, I have it at home.
    And you bought the converter, the power supply has only 90W, so with a power reserve of 200W, it would be enough, and on 1.0 mm2 cables it would pull without any problems.
  • #7 16775564
    tbik
    Rate: 34
    I bought an inverter a long time ago (before I had a laptop), so I decided to use it instead of buying an additional power supply. I did not only have a wire that supplies it with electricity from the cigarette lighter socket (because the set included cables with battery clips) and hence my question.
  • #8 16775621
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    You're wrong. First of all - the fuse is selected with some margin - it can be assumed that about 20-30%. It cannot be assumed that the fuse current value is equal to the maximum useful current in the circuit. Second: there are usually other receivers on the fuse that also consume electricity. Although the principles of constructing such circuits aim at connecting devices on the same fuse that are not likely to be used together (or there is no more than one device with continuous power consumption connected to one fuse), in the given case it can be almost certain that the circuit current will be exceeded. Third - be aware of the nature of the lighter's operation - it is a temporary consumption, allowing a certain degree of higher current. The same current consumed continuously may damage the installation even though it will not blow the fuse (!).
    At this point, it's time for a small parable: A tire compressor was plugged into the cigarette lighter socket (the same hand-made, slightly larger than the market ones, but the fuse did not blow), which was in constant use for about 10 minutes. The operation was interrupted (fortunately!) By a smoke coming out of the cigarette lighter socket. This symptom can be ignored, because it is not difficult to make a poor contact in a tarnished lighter socket. When checking the socket, it turned out that the insulation of the cable leading to the socket had melted. The fuse is still intact, with its original value!
    So now consider why the inverter comes with battery grips. What was the problem with installing a much more convenient cigarette lighter plug?
  • #9 16775924
    tbik
    Rate: 34
    Thanks for the warning and information. I will definitely use it.
    As for "What was the problem with installing a much more convenient cigarette lighter plug?" in my opinion it was easier (and probably cheaper) to put on a (large, comfortable) frog than a small (and probably more expensive) lighter plug.
  • #10 16776499
    tzok
    Help: 3176
    Rate: 6549
    Generally, it would be appropriate to pull the installation with a modular connector and a 40A fuse directly next to the battery under the inverter. 4-6mm ^ 2 cable (10-12AWG). The cigarette lighter socket is a very insecure connector that likes to get hot. Especially if the socket was used for the cigarette lighter.
  • #11 16776502
    enhanced
    Help: 963
    Rate: 883
    Show such a power supply but of certain quality? Besides, where would it get power if not from a lighter with such a power supply?
    It is better to use the original power supply through converters than to buy some pseudo 12V power supply, i.e. in fact converters, only it is not known what quality.
    If you were to actually use non-stop, you pull the wires inside, but you make a special socket for which you connect converters because in fact, the quality of lighters is not special, although 100W or less, if good quality, will do the trick. Although a dedicated connection will certainly heat up less than through the cigarette lighter socket - you would just have to figure it out and make a 230V ala socket or something like that for 12V.
  • #12 16776517
    tzok
    Help: 3176
    Rate: 6549
    This is how it has a 14VDC to 230VAC converter, followed by a 230VAC to 19VDC power supply ... instead it would be better to use a 14VDC to 19VDC converter. Such a connection would have higher efficiency, and therefore lower power consumption from the 12V socket. Lenovo offers such power supplies, there are also many replacements. Nevertheless, it has already been explained that the author does not want it because he already has this converter.
The discussion revolves around connecting a 400W inverter to a 12V cigarette lighter socket, addressing concerns about fuse size and cable thickness for different load capacities. The user inquires about the appropriate fuse rating, which is suggested to be around 40A due to potential peak loads. For cable thickness, a recommendation of 2.5mm² is made for 400W loads, while 1.0mm² is deemed sufficient for 100W loads. Concerns about the quality and capacity of the cigarette lighter socket are raised, with suggestions to consider a direct connection to the battery for higher safety and efficiency. The user also expresses a preference for using the existing inverter instead of purchasing a dedicated power supply for a laptop.
TL;DR: A 400W 12V inverter can pull 40A+ on the DC side—"that is 40A or more." Size wiring and fusing accordingly to avoid hot lighter sockets. [Elektroda, enhanced, post #16771170]
Why it matters: This FAQ helps drivers safely wire 12V-to-230V inverters for laptops and small appliances without melting sockets or blowing fuses.
How many amps does a 400W inverter draw from 12V, and what fuse should I use?
Budget for 40A or more on the DC side. Protect the circuit with a 40A fuse mounted close to the battery. This supports startup surges and reduces voltage drop when paired with adequately thick cable. Keep cable runs short and connections tight. [Elektroda, tzok, post #16776499]
Can I power a 400W inverter from the cigarette lighter socket?
Avoid it. A typical factory lighter circuit safely supports about 150W at 12V, which yields roughly 100–120W at the AC output of a consumer inverter. Exceeding that risks heat, voltage drop, and intermittent shutdowns. For higher loads, wire directly from the battery with proper fusing. [Elektroda, tzok, post #16775110]
What cable thickness do I need for the full 400W rating?
Use 4–6 mm² copper (about 10–12 AWG) from the battery to the inverter, protected by a 40A fuse near the source. This sizing keeps resistive losses low at ~40A DC and improves reliability during surge events. Secure all terminations to minimize heating. [Elektroda, tzok, post #16776499]
What wire size is OK for a 100W load to the inverter?
For around 90–100W, 1.0 mm² copper is sufficient when crimped properly and kept to short runs. Ensure connectors are solid and avoid corroded or loose lighter plugs that can overheat at sustained current. [Elektroda, pepe150, post #16775216]
Why doesn’t a 15A fuse guarantee I can draw 180W continuously from the lighter?
Fuses include headroom and may also protect multiple devices. Continuous high current can overheat wires and sockets without blowing the fuse. One documented case showed melted lighter wiring while the 15A fuse remained intact. Continuous loads need thicker wiring and a dedicated feed. [Elektroda, Gerri, post #16775621]
How should I wire a safe, dedicated inverter feed from the battery?
  1. Mount a 40A fuse within a few inches of the battery positive.
  2. Run 4–6 mm² copper to a quality modular/quick connector near the inverter.
  3. Keep the ground short and solidly bonded to chassis or battery negative.
    This reduces voltage drop and heating. [Elektroda, tzok, post #16776499]
Is a 12V car adapter better than using an inverter for a laptop?
Yes. A direct 14VDC-to-19VDC adapter avoids double conversion losses (DC–AC–DC). "Such a connection would have higher efficiency, and therefore lower power consumption from the 12V socket." Lenovo-branded and quality replacements exist. [Elektroda, tzok, post #16776517]
What’s the practical maximum through a good lighter socket?
Treat ~150W at 12V as the practical ceiling for continuous draw, which delivers about 100–120W at the inverter output after conversion losses. For anything beyond a laptop or small charger, use a dedicated, fused battery feed. [Elektroda, tzok, post #16775110]
Why do lighter sockets overheat with inverters?
Lighter plugs are mechanically loose and resistive under vibration. Contacts warm at 10–15A continuous, and heat accelerates oxidation, raising resistance further. "The cigarette lighter socket is a very insecure connector that likes to get hot." Use a hard-wired connector for reliability. [Elektroda, tzok, post #16776499]
Do I need to size wiring for inverter surge power?
Yes. 400W inverters can see 600–800W short surges. That means brief DC spikes above 40A. Choose cable and fuse placements that handle these transients without excessive voltage drop. Keep runs short and connections tight. [Elektroda, enhanced, post #16771170]
Why did my inverter ship with battery clips instead of a lighter plug?
Clips indicate the manufacturer expects high currents that lighter sockets shouldn’t carry continuously. Direct battery connection reduces heating and voltage drop at 30–40A loads. Cost aside, it’s primarily a safety and reliability choice for sustained power. [Elektroda, Gerri, post #16775621]
Where should the fuse go when hard-wiring the inverter?
Place the fuse as close to the battery positive as possible. This protects the entire run of cable to the inverter from short circuits and limits fault energy. Pair it with 4–6 mm² wiring and quality terminations. [Elektroda, tzok, post #16776499]
What’s 10–12 AWG in metric, and why does it matter?
10–12 AWG corresponds roughly to 6–4 mm² cross-section. Larger cross-section lowers resistance, reducing voltage drop and heat at 30–40A draw. Follow the inverter’s manual, but the 4–6 mm² guidance covers most 400W installs. [Elektroda, tzok, post #16776499]
I only need ~90W peak for a laptop—can I stay on the lighter socket?
Often yes, if the socket and plug are high quality and not worn. Keep current modest and check for heat at the plug during use. A dedicated 12V feed or a 12V-to-19V laptop adapter will still run cooler. [Elektroda, enhanced, post #16776502]
How can I estimate DC current for my AC load quickly?
As a quick check, a 400W inverter roughly means 40A DC capability due to conversion losses and surge. If your load is 100W, expect around a quarter of that current on average. Always size wiring and fusing with margin. [Elektroda, enhanced, post #16771170]
