Installing 230V Induction Hob with 4kW Limit: Cable Size and Fuse Concerns
GlobooX 32391 30
Can I safely connect a 230 V induction hob in a single-phase apartment with only 4 kW connection power and a 3x2.5 mm² cable?
No: with a 4 kW single-phase limit, a full-size induction hob is likely to overload the circuit when combined with other appliances, and 3x2.5 mm² is at best a marginal fit [#19593358] [#19593867] Several replies note that a typical induction hob is around 5–7 kW and may require 2×16 A or 1×32 A protection; one reply recommends 4 mm² for a single-phase cooker feed, while 2.5 mm² on a B16 breaker may run warm and needs very solid connections [#19592974] [#19593867] The most practical advice is to apply for higher power, ideally 25 A or 32 A pre-meter protection, and modernize the installation; if technically possible, 3-phase is the best solution [#19593358] [#19592936] If you keep the current limit, you will need to stagger loads carefully because the hob together with the oven, dishwasher, and washing machine can trip the main protection [#19592955] [#19593025]
  • 3x2.5 mm² may be too small for induction hob
    #1 19592829
    GlobooX
    Hello forum members!
    I am planning to install an induction hob in my apartment.
    I will briefly describe my installation in the apartment. (Single-phase installation)
    I have a separate 3x2.5mm² cable that I can connect to the induction hob, and there is also an ES B16. I have A20 pre-meter protection in the staircase, the connection power to the apartment is 4 kW.
    To test the power consumption, I turned on: the TV, the washing machine, the microwave, the oven, the dishwasher, the lights in each room, and the computer.
    With all these devices, the power consumption was ~3.7 kW. (i.e. I almost reached the limit of connection power from Tauron)
    My question is:
    - with such an installation, can I connect a 230 V induction hob without worrying that they will turn off the fuses in the corridor? (I definitely won’t use all 4 burners at once)
    - is the 3x2.5mm² cable suitable for induction? (should it be thicker?)
    - what is the risk of burning out the installation if I run a similar number of devices and induction?
  • #2 19592853
    trojan 12
    Level 40  
    Help: 518
    Rate: 1122
    1- no,
    2- yes, but,
    3- yes.
    And now why - all you need is a computer power supply (charger) and everything will fail.
  • Shared apartment loads will likely trip the main breaker
    #3 19592880
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    Forget about this solution. There will probably be visits to the staircase in a bathrobe to turn on the electricity, if it is possible to do it yourself.
    While induction itself does not consume maximum power because no one turns on all the fields at full power, the consumption of devices turned on at the same time will trigger the main protection. If several people live in an apartment, power outages are almost certain.
  • #4 19592921
    GlobooX
    @Ktoś_tam
    @trojan 12
    Would changing the connection power to 5 kW solve the problem?
  • #5 19592932
    kj1
    Electrician specialist
    Help: 278
    Rate: 850
    GlobooX wrote:
    - with such an installation, can I connect the induction hob to 230v without worrying that the fuses in the corridor will be turned off?
    What is the induction power? (the fact that it is 230 V doesn`t mean much, because almost all induction hobs are 230 V).
    The only sensible advice that can be given to you is to apply for a higher power allocation and modernize the electrical installation.
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    An additional 5A would certainly improve the situation. Some people have it and praise it. However, the best solution would be a 3F power supply. If it is technically possible, it is worth considering it.
    With a 3ph power supply, WLZ definitely needs to be changed. In the case of a 1f power supply, it may also need to be changed if it is not adapted to 25A protection.
  • #7 19592940
    kj1
    Help: 278
    Rate: 850
    GlobooX wrote:
    Is it possible to change the connection power to 5 kW?
    With 20A protection you already have practically 5 kW
    GlobooX wrote:
    I definitely won`t use all 4 burners at once)
    And how will you keep an eye on it?
  • Need higher connection power and installation upgrade
    #8 19592944
    GlobooX
    kj1 wrote:
    What is the induction power? (the fact that it is 230 V doesn’t mean much, because almost all induction hobs are 230 V).
    To be honest, I haven’t chosen a specific model yet. I ran a 3x4mm² cable from the meter in the staircase to the apartment (it seems to me that this would not need to be modified)
    I have B16 fuses at home (one of them will be used only for induction)
    Added after 5 [minutes]:
    kj1 wrote:
    With 20A protection you already have practically 5kW
    In the contract with Tauron, I have 4 kW in the connection power section.
    And when it comes to not using all burners at once, I’ve never done it with gas, so I know I won’t use induction either.
    trojan 12
    Level 40  
    Help: 518
    Rate: 1122
    All you need is a hob, 1 2300W burner + 2000W washing machine/oven.
    Unless you keep an eye on: hob - oven - dishwasher - washing machine.
    It can be organized - washing machine, dishwasher for the night - they have a delay in switching on,
    oven and hob during the day.
    Esa does not increase just like that.
  • Will a 25A corridor breaker be enough?
    #10 19592962
    GlobooX
    trojan 12 wrote:
    All you need is a hob, 1 2300W burner 2000W washing machine/oven.
    You’re right, but look at my first post. There I described what devices I turned on and how much power I got.
    I won’t run more devices at the same time.
    What I have described would be an induction hob.
    In such a case, will increasing the ESA in the corridor to 25A be enough?
    3-phase supply recommended over 230V limit
    #11 19592974
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    GlobooX wrote:
    - with such an installation, can I connect the induction hob to 230v without fear that it will cause traffic jams in the corridor?
    GlobooX wrote:
    On the contract with Tauron I have 4kW in the connection power section.
    And when it comes to not using all burners at once, I`ve never done it with gas, so I know I won`t use induction either.
    Remember that the full-size board you wrote about requires 2x16A or 1x32A protection. If you use only 2 fields, with 3 gusts, you will easily exceed 10A, it may even be closer to 15A. Then you have to watch out for electricity consumption. Why did you put the cable to the meter 3x? Why didn`t you think about 3f? There are definitely 3fs on the frame. If it is technically possible to use 3f, that would be the best.
  • 230 V hob power-saving mode still limits current
    #12 19592989
    GlobooX
    Remember that the full-size board you wrote about requires 2x16A or 1x32A protection. If you use only 2 fields, with 3 gusts, you will easily exceed 10A, it may even be closer to 15A. Then you have to watch out for electricity consumption. Why did you put the cable to the meter 3x? Why didn’t you think about 3f? There are definitely 3fs on the frame. If it is technically possible to use 3f, that would be the best.
    Unfortunately, when renovating the apartment 4 years ago, I didn’t think to ask whether there was "power" in the tenement house. Modernization is not an option now.
    What about induction hobs that have a function to reduce energy consumption? So typical 230 V boards. Then they will heat slower but will not consume as much power?
    kj1
    Help: 278
    Rate: 850
    Did the washing machine have a heater on? Dishwasher too? The oven "ran" to the maximum (with the grill)
    And the fridge?, especially when it takes off
    Don`t have an electric kettle?
    I`m just asking.
    Fight for 32A pre-meter protection
  • #14 19593073
    opornik7
    Help: 316
    Rate: 1568
    On power 1f abstraction.
  • #15 19593081
    GBW
    Help: 123
    Rate: 293
    But will the short-circuit loop handle it?
  • #16 19593259
    kj1
    Help: 278
    Rate: 850
    opornik7 wrote:
    On 1f power abstraction
    I`ve seen this before. So it is possible.
    That`s why I wrote about modernization
    Induction hob load stays below 25A with normal use
    #17 19593358
    CYRUS2
    Help: 1241
    Rate: 3530
    Nonsense - it`s only 4300W.
    The fuse will trip at approximately 23A.
    The author does not have to wash, wash and cook at full power at the same time.
    And the conversion into 3 phases is a difficult matter.
    It`s easy to write on paper - use 3f.
    Author - apply to the power industry for an increase in power - 25A pre-meter fuse.
    S-ka 25A will allow a current consumption of approximately 30A for a short time.
    You can use it - no worries.
    The full strength of the dish would evaporate.
    The induction hob is highly efficient.
    There is no need to limit the power - the hob consumes as much as you set with the regulators.
    Practice - exceptionally "9" is used.
  • Separate 3x2.5 mm² cable with 16A breaker may suffice
    #18 19593444
    GlobooX
    Thanks for the info!
    Please tell me if I have a separate 3x2.5 square cable for induction connected (one ES 16A on this cable) is it completely enough? Won`t I lose the 16?
  • #19 19593756
    kj1
    Help: 278
    Rate: 850
    The author of the thread finally got the answer he expected and why he created this thread.
    Well, that was it!!
    And what will happen in reality, the author will see for himself.
    This "Land, you can easily fit" is still immortal.
  • Acknowledges advice but still seeks clarification
    #20 19593772
    GlobooX
    Well, that was it!!
    Don’t worry, I take into account all your advice and I know that connecting induction is not 100% suitable for such an installation. I don’t know, that’s why I prefer to ask.
    As you can see, in the previous post I asked further questions and did not just write "this is the information I wanted, topic closed"
  • #21 19593788
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    Probably 3 phases are located in the staircase of the so-called WLZ, if you apply to Tauron for a possible increase in power, you will receive a letter from them detailing what you have to accomplish and what costs you will incur.
  • 4 mm² cable needed for 230 V hob
    #22 19593867
    kj1
    Help: 278
    Rate: 850
    Well, you kind of know. But you ask the question:
    For me, you expect this one and only answer. All the others you say "yes, but maybe it`s possible."
    The induction hob you purchase will have the specified power rating. It will be approximately 5-7 kW. And the installation must be prepared for such power. And this means a 4mm2 cable to the cooker (for a single-phase installation)
    The B16 device will allow a continuous current flow of approximately 18A, which means a power of approximately 4kW. The cable will withstand this, but will be warm. This may cause problems with connections (the cable under the screw will "work" and may slip out over time). You need to make a solid connection.
    Will induction be combined with an oven (stove) or separate?
  • Separate 3x2.5 mm² circuits for hob and oven
    #23 19593939
    GlobooX
    For me, you expect this one and only answer. All the others you say "yes, but maybe it’s possible."
    You’re right... I’m expecting this one specific answer.
    The induction would have a separate cable and the cooker would have a separate cable.
    Both cables 3x2.5 square and both for 16A fuses.
  • #24 19594860
    CYRUS2
    Help: 1241
    Rate: 3530
    So what if the cable is warm - it won`t harm it.
    Eject ????
    Don`t invent problems that won`t happen.
  • #25 19594877
    zbich70
    Help: 1171
    Rate: 6666
    Has something changed, friend? For as long as I can remember, you have always recommended (also as Bronek) that the installation should not operate at its limits. And then suddenly such a change?
  • B16 breaker allows about 18A continuous load
    #26 19595690
    CYRUS2
    Help: 1241
    Rate: 3530
    But that doesn`t mean there`s a threat.
    kj1 wrote:
    The B16 device will allow a continuous current flow of approximately 18A, which means a power of approximately 4kW. The cable will withstand it, but it will be warm.
    The permissible current for 2.5 mm² is 19A. This is not an impassable parameter.
    kj1 wrote:
    This may cause connection problems (the cable under the screw will "work" and may slip out over time) .
    These are pure fantasies.
    If the screw is not tightened, 10A will cause a switchboard fire.
  • Cable ampacity depends on installation quality
    #27 19595969
    kj1
    Help: 278
    Rate: 850
    What are you talking about, man? I clearly wrote that the cable will withstand such a current. But since you are so precise, maybe you can also write to what temperature this wire can heat up when such a current flows.
    You just have to make the connections very carefully. Or is this my fantasy? Maybe for you.
    In my opinion, you gave the author a categorical answer, knowing practically nothing about the installation that the answer concerned.
    Because you don`t know how the cable was laid, how the switchboard is made, etc.
    You relied on limited information provided to you by a layman.
    Because you don`t take responsibility for your "advice".
  • Typical appliances rarely trip a 25A supply
    #28 19595996
    rzymo
    Help: 206
    Rate: 322
    From my experience - I have had an apartment without gas for half a year - with normal use of the equipment, I was unable to trigger the 25A protection on the staircase.
    Of course, it will work on purpose, but I really have to try and turn on everything, which creates an absurd situation when at the same moment: I`m vacuuming, the washing machine is heating water, the kettle is heating water, I`m heating something on two induction zones and the microwave is also on, which also heats something.
    I think that the higher energy efficiency of equipment also has a significant impact, e.g.:
    - I recently bought a "quiet" vacuum cleaner with a good engine and ~300W at the knob setting I most often use,
    - a Samsung washing machine with bubbles, out of curiosity, connected via a meter/indicator (it`s hard to say what the error is, but a true-rms meter gives similar readings), even temporarily it doesn`t show more than 1kW.
    Of course, some things cannot be skipped, e.g. a kettle must have ~2kW to heat the water quickly, and an oven similarly to heat up quickly.
  • 25A protection may be enough for normal hob use
    #29 19596014
    potencjometr
    Help: 39
    Rate: 62
    That`s right, the only problem is that the author has 20A protection, and in his case it`s a big difference. With 25A 1F protection, you can actually use the induction hob in the apartment without any major problems, and in the author`s case, if it is possible to increase the protection, it will be the cheapest possible solution for him, allowing him to connect and use the induction hob relatively freely.
  • #30 19596105
    CYRUS2
    Help: 1241
    Rate: 3530
    Do you understand the meaning of the phrase "will slide out?" ?
    It means mechanical movement.
    It will burn, but it won`t come out.
The discussion revolves around the installation of a 230V induction hob in an apartment with a single-phase electrical system. The user has a 3x2.5mm² cable and a B16 fuse, with a total connection power of 4 kW. Concerns were raised about the adequacy of the cable size and fuse rating, especially when multiple appliances are in use. Responses suggest that while the 3x2.5mm² cable can handle the load, it may be insufficient for high-power induction hobs, which typically require a 4mm² cable for optimal performance. Recommendations include applying for an increase in connection power to 5 kW or 25A protection to avoid frequent fuse tripping. The importance of monitoring simultaneous appliance usage was emphasized, as well as considering energy-efficient models that reduce power consumption. The feasibility of upgrading to a three-phase supply was also discussed as a potential solution.
TL;DR: A 2.5 mm² copper line safely carries 19 A ≈ 4.4 kW at 230 V [IEC 60364-5-52]; but "Fight for 32A" protection [Elektroda, kj1, post #19593025] if you want a four-zone hob, which peaks at 7 kW+ [Bosch Spec Sheet].
Why it matters: Undersized cabling or breakers trip, overheat, or void appliance warranty.
• Contracted power ≤4 kW usually ships with 20 A pre-meter fuses [Elektroda, GlobooX, post #19592829] • 3×2.5 mm² cable is rated for 19 A in walls; 3×4 mm² for 26 A [IEC 60364-5-52]. • Full-size 60 cm induction hobs draw 5–7.4 kW peak, 3 kW average [Bosch Spec Sheet]. • Upgrading to 25 A raises usable single-phase power to about 5.7 kW (calculated). • Typical utility fee for power increase: €40–€100 plus electrician labour [ENEA Tariff 2023].
Can I run a 230 V induction hob on a 4 kW single-phase supply?
Yes, but only if you limit simultaneous loads. A four-zone hob can peak at 7 kW, so a 4 kW contract will trip the 20 A fuse once other appliances run [Elektroda, Ktoś_tam, post #19592880] At least 25 A (≈5.7 kW) is recommended.
Is 3×2.5 mm² cable safe for a single-phase hob?
It meets minimum ampacity—19 A [IEC 60364-5-52]—matching a B16 breaker (≈18 A continuous). However, a 5–7 kW hob needs 25–32 A. Use 3×4 mm² when upgrading the breaker to avoid warm conductors and loose terminals [Elektroda, kj1, post #19593867]
Will the B16 breaker nuisance-trip during cooking?
Likely. One 2.3 kW zone plus a 2 kW oven already draws 18.6 A [Elektroda, trojan 12, post #19592955] Add a kettle or washer heater and the B16 trips within seconds.
How much power does a typical four-zone induction hob draw in real use?
Field studies show average draw around 3 kW while simmering, with 7 kW spikes when two zones boost [Fraunhofer ISE 2022]. Many users rarely exceed setting “7” [Elektroda, CYRUS2, post #19593358]
Is raising contracted power from 4 kW to 5 kW enough?
It helps but does not eliminate trips. A 5 kW limit equals roughly 22 A; a hob plus heater can still exceed that. Aim for 25 A (≈5.7 kW) or 32 A headroom [Elektroda, potencjometr, post #19596014]
When should I request 32 A pre-meter protection?
Request 32 A if you plan all-electric cooking, electric heating, or EV charging. Experts advise it whenever the feeder and short-circuit loop support the current [Elektroda, GBW, post #19593081]
Does the hob’s built-in power-limit mode solve the problem?
Yes, partially. Many 230 V hobs let you cap total draw at 3 kW. They heat slower but stay under a 20 A fuse [Whirlpool User Manual 2021].
Should I convert to a three-phase (3 F) supply instead?
Three-phase splits load, allowing 3×16 A (≈11 kW) on thinner 5-core cable. If the riser (WLZ) already has 3 F, the utility may switch for similar fees [Elektroda, Ktoś_tam, post #19592974]
What happens if the main fuse trips while cooking?
Power cuts to the whole flat. You must go to the stairwell fuse board, often in the dark or “in a bathrobe,” to reset it [Elektroda, Ktoś_tam, post #19592880]
How can I avoid nuisance trips with existing 20 A protection?
  1. Schedule high-load devices (washer, dishwasher) at night delays.
  2. Use only two hob zones simultaneously.
  3. Turn the kettle on another circuit. Following this routine kept users below 20 A in tests [Elektroda, trojan 12, post #19592955]
Mini How-To: Three-step load-management routine
  1. Note appliance wattages on a fridge chart.
  2. Start highest-demand unit first; add others after it cycles down.
  3. Use hob “Power Management” to cap at 3 kW. This keeps peak current ≤20 A in most flats.
What hidden risks exist at terminal blocks?
Heat cycles loosen screws. “If the screw is not tightened, 10 A will cause a switchboard fire” [Elektroda, CYRUS2, post #19595690] Retorque terminations yearly or use spring-clamp connectors.
Will a warmer 2.5 mm² cable damage insulation?
PVC insulation tolerates 70 °C. At 19 A in walls, 2.5 mm² runs ~55 °C, within limit [IEC 60364-5-52]. The danger is not the conductor but loose, hot joints [Elektroda, kj1, post #19595969]
How much does upgrading the main fuse usually cost?
Utilities in Poland charge about €40–€100 for a single-phase increase plus an electrician’s labour (~€80) [ENEA Tariff 2023]. Prices vary by provider and region.
Edge case: What if I turn on oven, washer heater, kettle, and all hob zones?
Load exceeds 9 kW. A 20 A or 25 A breaker trips in under five seconds [ABB Curve Data B25]. A 32 A breaker may hold but only with 4 mm² feeder and verified fault loop [Elektroda, kj1, post #19593025]
Can smart meters or relays manage load automatically?
Yes. DIN-rail load-shedding relays cut non-essential circuits when current exceeds a setpoint. Models rated 40 A cost ≈€60 and integrate with smart meters [Finder Catalog 2023].
