Max Load Capacity of 12V Car Cigarette Lighter Socket: 120W, Fuse, USB Charger, H1 Bulb, Inverter
fsq 36534 7
  • Checking cigarette socket current budget and inverter load
    #1 14634812
    fsq
    I need to know how much I can load the 12V cigarette lighter socket.
    The car manual says that the maximum is 120W, the fuse (30A inserted, but it should be 10A :) ) is for the cigarette lighter + reversing light. The reversing light is a P21W bulb, i.e. 100W (8.3A) is left for the cigarette lighter.
    I attach it to the lighter
    - A power supply for a video recorder, at auctions I write that it takes 0.15A, and a charger with two usb sockets (router and telephone) such an ordinary Chinese one, I accept the second 0.15A.
    - Rooster with H1 bulb. H1 has 55W, 55W / 12V gives 4.58A, plus the motor rotates the reflector, so probably 5A will be safe. Total 5.3A.
    So there is 3A left for ... an inverter, I have no idea how much it can take, because the manufacturer does not say, the output is 600 / 1200W. It is run sporadically for a maximum of a minute.
    Are the calculations correct and can the converter run on the rest of the devices?
  • #2 14634832
    jasiek1122
    Help: 50
    Rate: 366
    (inserted 30A but I think it should be 10A Smile)
    If I were you, I wouldn't risk it like that. Put in the 10A fuse right away. Because it may turn out that the fuse will last and the wires will stick together and there will be no reason to laugh. :D
  • #3 14634839
    gimak
    Help: 614
    Rate: 1678
    fsq wrote:
    (30A inserted, but probably should be 10A :) )
    Measure the resistance of the lighter itself and count how much current it will take, because the value of the fuse inserted was selected under it as a temporary load. The given load capacity of 120W will apply to a constant (long-term) load, about this I also have some doubts, due to the thinness of the cables to it.
  • #4 14635637
    Javoreczek
    Help: 53
    Rate: 114
    First of all, it depends on what you will connect to this converter. Its current consumption depends on its load.
  • #5 14635711
    marian6666
    Help: 8
    Rate: 129
    Pull the plus point straight from the battery (with a suitably thick cable), plus the weight on the body also with a thick, decent cigarette lighter socket and you have an installation that you can charge more than the standard one. Leave the factory socket alone.
  • Power the inverter directly from the battery with thick cables
    #6 14640499
    fsq
    Such a thing http://login.wamgroup.com/contents/rangemve/scheda.asp?unmis=m&fsn=n&codmve=55&codlang=1
    I thought about it, but it's hard to go through the bulkhead wall and you would have to do too much demolition and the car is not mine.
  • #7 14641959
    Javoreczek
    Help: 53
    Rate: 114
    The inverter with this something connected will consume over 10A. The only reasonable solution is the one mentioned above with a separate battery cable.
  • #8 14642587
    fsq
    So all about, thank you for your help.
The discussion revolves around the maximum load capacity of a 12V car cigarette lighter socket, which is stated to be 120W. The user calculates the current draw from various devices connected to the socket, including a video recorder power supply (0.15A), a USB charger (0.15A), and an H1 bulb (approximately 5A). This leaves about 3A available for an inverter, which the user is uncertain about in terms of its power consumption. Responses suggest caution, recommending the installation of a 10A fuse instead of a 30A one, and highlight the importance of measuring the resistance of the lighter socket. Some responses advise running a separate cable directly from the battery for higher loads to avoid overloading the factory socket.
