Estimating CR2032 Battery Life for Device with HM-10, Atmega8L in Sleep & Active States
Jakub17 10428 6
  • #1 16772608
    Jakub17
    Rate: 15
    I need to get an estimate of the theoretical power consumption of the device and how long the battery will last before going on to experiment to confirm the estimates.
    Current consumption for the systems included in the device:
    Sleep state
    HM-10 (400 uA)
    Atmega8L (1.25 uA)
    Active state
    HM-10 (9 mA)
    Atmega8L (1.6 mA)
    I have two CR2032 batteries connected in parallel, so their total capacity is 240 + 240 mAh.
    Battery discharge chart from documentation:
    The battery voltage cannot drop below 2.7 V in the system, which, according to the diagram, gives approx. 1050 hours of operation under the tested conditions.
    There are 2 batteries, so a total lifetime of 2100 hours. But the power consumption in the sleep state is about 400 uA and 190 uA for the graph. So I think it can be assumed (but I'm not sure) that the endurance is 2 times lower, i.e. 1050 hours for the sleep state.
    The device works in the active state for about 0.5 seconds, say 10 times a day, which gives 5 seconds of the total duration of the active state per day, i.e. consumption of 10.6 mA.
    Now I need to calculate somehow the average daily current, in order to estimate how long the battery will last for working both in active and sleep mode. How to count it? And are my simplifications in the presented analysis acceptable?
  • #2 16772763
    TvWidget
    Help: 472
    Rate: 699
    Temperature is also a key parameter. As it decreases, the voltage decreases and the internal resistance increases.
    Check whether the given current for the HM-10 is average or peak current. It may turn out that the voltage drops below 2.7V at the first turn on.
  • #3 16772774
    Jakub17
    Rate: 15
    The given HM-10 current is average. I don't have to be that precise to take the temperature into account.
    Do you have any suggestion on how this should be calculated?
  • #4 16772860
    TvWidget
    Help: 472
    Rate: 699
    You need to know what the maximum current will be consumed by the system.
  • #5 16772900
    Jakub17
    Rate: 15
    Well, I wrote above, a total of 10.6 mA of average current. I do not take into account impulse currents.
  • #6 16773109
    TvWidget
    Help: 472
    Rate: 699
    Without taking this parameter into account, the calculations do not make much sense. Estimated for two new batteries at room temperature, the voltage will drop to 2.7V when the device starts to consume 30mA for a while.
  • #7 16773234
    Jakub17
    Rate: 15
    I am only interested in the calculation methodology. Let us assume that the impulse current is X. While it is easy to find such information in the microcontroller documentation, the hm-10 documentation is truncated.
    I do not know how to calculate the average value of the daily current, but since there is time as a parameter, because the current 400 uA runs smoothly for (23h - 5s) and the current 10.6 mA for the remaining 5 seconds, then I can approach the matter from the energy side, from the power side which includes time by definition? I just don't know how to do it yet ...
    Added after 12 [minutes]:
    It can calculate the current work for two cases with the dependence W = UIt. Then add them together and average for the entire period, i.e. 24 hours. This way I have the average power calculated. Knowing that the voltage is constant (although it is tightly stretched because the battery voltage will drop gradually) from the average power, I can determine the average daily current. It will be fine?
    Added after 16 [hours] 6 [minutes]:
    When I transformed the formulas, it turned out that the average daily current does not depend on the voltage and everything turned out nicely.
    The battery capacity that is given in the documentation, unfortunately, concerns the situation of a battery discharge to 2 V, and for me the limit is 2.7. There is only a problem here. If I knew the discharge capacity to 2.7 V at the calculated average current, I could easily calculate the battery life ...
The discussion revolves around estimating the battery life of a device utilizing HM-10 and Atmega8L microcontrollers in both sleep and active states. The user provides current consumption values: 400 µA for HM-10 and 1.25 µA for Atmega8L in sleep mode, and 9 mA for HM-10 and 1.6 mA for Atmega8L in active mode. With two CR2032 batteries in parallel, the total capacity is 480 mAh. The user references a battery discharge chart indicating a potential operation time of 2100 hours, but questions the accuracy of this estimate due to varying current consumption. Responses emphasize the importance of considering maximum current draw, temperature effects on battery performance, and the need for a proper calculation methodology to determine average current over time. Suggestions include calculating energy consumption using the formula W = UIt and averaging the power over a 24-hour period.
