Samsung Galaxy J5 2016 J510F Home Button Malfunction Despite Tape Replacement & Software Update
Jarek2140 5559 4
  • #1 16772909
    Jarek2140
    Rate: 64
    I have a Samsung Galaxy J5 2016 with a broken home button. I replaced the tape, but still no effect, the side buttons work. I heated the disc in the bottom part of the USB socket in general but nothing, any ideas? uploading the new software didn't help either.
    • Samsung Galaxy J5 2016 J510F Home Button Malfunction Despite Tape Replacement & Software Update 20171022_213019.jpg (386.02 KB) You must be logged in to download this attachment.
  • #2 16774514
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Phone after falling or home stopped working on its own ??
  • #3 16774578
    Jarek2140
    Rate: 64
    by itself :-)
  • #4 16775013
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    And this flex what did you exchange sat down evenly? Are you sure the home button moves perfectly? The old tape was clean, it wasn't even a bit dirty, because usually in these models it stops working because you often click with a damp thumb. If everything is ok, the damage on the disc. The question is, did you get a service kit ...
  • #5 16776221
    Jarek2140
    Rate: 64
    The tape has been changed to a new one, so the tape falls off :)
