Samsung Galaxy J5 (2016) Touch Not Working After Water Damage - Screen Replacement?
Karol445 14889 8
  • #1 17127108
    Karol445
    Hello. I have a problem with samsugniem galaxy j5 (2016) yesterday I fell out of my pocket and fell into the water I dryed everything worked and suddenly the touch stopped working all buttons work even those who touch it too and nothing on the screen is not moving what to do screen replacement?
  • #3 17139644
    proelektronics1
    Rate: 9
    The only chance to recover is to unstick the display and check the connector from the tape touch on the display tape. As a rule, it is burned or corroded. Just clean or do a cross :)
  • #4 17147420
    Karol445
    How do you do a lot of work?
  • #5 17148101
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    You wrote earlier that everything you disassembled, how in the end ?? If you have no experience, it is better to take it to a service. At home, you can only check the lcd and digitizer jack for the moment. At the back of the body, there is probably a plug on the right side at the top, and there is an LCD tape beneath it.
  • #6 17152285
    polter11
    Rate: 10
    Go to the site as you do not want to do it at home.
  • #7 17152343
    br501
    Help: 14
    Rate: 56
    In this model, very often after flooding, the water collects at the place where the touch strip is attached. You have to unstick the display and clean the pin. If it's not too late, it should help. [/ Code]
  • #8 17160718
    Karol445
    How can I unstick this display?
  • #9 17161002
    Orzel27
    Help: 91
    Rate: 52
    We need some experience and practice. Without this, the display damage is virtually certain.
The user reports that their Samsung Galaxy J5 (2016) became unresponsive to touch after water exposure. Responses suggest that the issue may stem from corrosion or damage to the touch connector, which can occur when water collects at the touch strip. Recommendations include ungluing the display to inspect and clean the connector, although this requires some technical skill. If the user lacks experience, it is advised to seek professional repair services to avoid further damage.
