Samsung Galaxy S6 Home Button Issues: Poor Performance, Hard Pressing, Double-Click Camera Problem
kotak 5607 5
  • #1 16970215
    kotak
    I have a Samsung Galaxy S6
    The Home button has been working less well for some time. You have to press it hard to make it work. Often it does not work at all, but when you press it, it surprises. It is quite troublesome because I can no longer call the camera by double-click because it is not so accurate.
    It is loose. When I press it so softly it sounds like "summers".
    What could be the reason and how to approach it?
    Thanks in advance for your help.
  • #2 16970270
    nutergsm
    Help: 1034
    Rate: 1665
    Replacement button.
  • #3 16970329
    sm233
    Help: 499
    Rate: 434
    In s6 G920 if the home button does not click, then the plate with the charging connector is to be replaced.
  • #4 16970379
    kotak
    Thanks for the answers
    But he does work so badly.
    So electronics probably ok what?
    Need to replace both the buttons and the board?
    And do you know what the cost of repair?
    Need to peel off the display?
  • #5 16970389
    sm233
    Help: 499
    Rate: 434
    Does not work because the return button is not easily clicked?
  • #6 16970402
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    You definitely need to get to the button and it's possible that you just need to clean it.
    Yes you need it and it is quite difficult, so I recommend having it repaired in service or using the phone without this button.
