Resolving LG G6's WiFi Connectivity Fluctuation: Switching to LTE and Back
geforc 6741 8
  • #1 16777719
    geforc
    Rate: 44
    Hello, gentlemen, I have LG G6 and for some time I have this situation, WiFi is on, disconnects, LTE turns on, after a while WiFi returns, sometimes after a minute sometimes after 5. I have good coverage at home, all savings in the router and phone off what do you think this problem might pose?
  • #2 16777931
    actin
    Help: 187
    Rate: 799
    Possible soft problem. Download the data and perform a reset to start with.
    You don't have any external application to control phone functions?
  • #3 16779019
    .:aspire:.
    Help: 53
    Rate: 62
    Settings -> Developer options -> Turn off "Aggress. Switch from Wi-Fi network to mobile
  • #4 16781605
    geforc
    Rate: 44
    this option is disabled in this menu ...
  • #5 16781639
    actin
    Help: 187
    Rate: 799
    Did you reset?
  • #6 16782044
    .:aspire:.
    Help: 53
    Rate: 62
    And check: Settings - wi-fi - advanced - Switch automatically to mobile network
  • #7 16782410
    geforc
    Rate: 44
    I have it turned on, but I want it to be turned on because when I leave the house, it switches to LTE and that's it.
  • #8 16782620
    .:aspire:.
    Help: 53
    Rate: 62
    It will also switch to LTE without it, but only when the wi-fi completely disappears. You only need to have data enabled.
  • #9 16782630
    geforc
    Rate: 44
    Ok, I turned it off, I'll see how the phone will behave now
The discussion revolves around the LG G6 experiencing WiFi connectivity issues, where the device frequently disconnects from WiFi and switches to LTE. Users suggest potential solutions, including performing a factory reset, adjusting settings in Developer options to disable aggressive switching from WiFi to mobile networks, and checking advanced WiFi settings for automatic switching. The author confirms that some options are disabled and expresses a desire to maintain LTE switching when leaving the house. The conversation concludes with the author testing the changes made to the settings.
