Maintenance Factor in Dialux: Real-Life Measurements vs. Set Value (0.77) and Intensity (200lx)
AXELF 7794 9
How do I interpret a maintenance factor of 0.77 in Dialux, and what initial illuminance does it imply if the target is 200 lx?
With MF 0.77, a design value of 200 lx means the installation should provide about 200 / 0.77 ≈ 260 lx initially, so that after aging and dirt it still maintains 200 lx [#16780110][#16779620] The maintenance factor is used to account for the drop in light output over time, so the calculated value is not the “real” site value but the maintained value after a certain period and cleaning cycle [#16779620] In practice, MF is made up of several parts: LLMF, LSF, LMF, and RSMF, so it depends on both the lamps/luminaires and the room conditions [#16780939] Actual measurements on site can differ from the calculation and may be higher right after installation, then stabilize after the luminaires warm up [#16780829]
  • #1 16779369
    AXELF
    Help: 8
    Rate: 49
    Hello all,
    I've had a problem with my head for some time. How is it with the maintenance factor in Dialux and the actual measurements on site. Suppose the project is set to 0.77 and the intensity is 200lx. So what will the intensity really be? How is it calculated?
    Thank you in advance for your help
    kozi966
    Help: 599
    Rate: 1288
    The MF factor is set so that after some time (e.g. 2 years) the intensity in a given place continues to meet the requirements of the standard. Then you need to perform activities, e.g. cleaning, replacing sources, etc.
    More. At least as much as when calculating for a factor of 1.
    Reality does not count, it can be measured.
  • #3 16779824
    AXELF
    Help: 8
    Rate: 49
    I heard that it can be calculated 1 / 0.77, then the result is multiplied by the mean value and it comes out the same as assuming a factor of 1. But I don't know if it is correct.
    kozi966
    Help: 599
    Rate: 1288
    Since:
    E o MF = Em
    This:
    Em o 1 / MF = E
    There is no big secret here, but it is still not "reality" but numbers and letters on a piece of paper.
  • #5 16780644
    AXELF
    Help: 8
    Rate: 49
    Thank you :)
  • Warm-up causes initial light output to read high
    #6 16780829
    JohnySpZOO
    Electric installations specialist
    Help: 186
    Rate: 330
    In theory, just like my colleagues mentioned above.
    In practice it is different. You can buy the goods and advertise because the measurements will not work - I had such a topic. You can buy the goods and have it too bright.
    As an adjunct ...
    In practice, with some types of luminaires, immediately after installing and lighting the lighting, you can measure that the lighting shines for you more than it should, e.g. 130-150% compared to what you will measure in 40-100 hours of work (theoretically MF = 1). The fittings have to 'warm up' and then the stream emitted from them stabilizes.
    Once at a friend's I tested an application on the phone for measuring the intensity of lighting over time, which confirms what I wrote above.
    As for the simulations themselves, recently reviewing them from lighting manufacturers, to whom I commission the simulation, I can see that the maintenance factor is 1 regardless of the maintenance cycle. Are their products that great?
  • Maintenance factor includes lamp, luminaire, and room losses
    #7 16780939
    kozi966
    Help: 599
    Rate: 1288
    The MF factor consists not only of the part dependent on the luminaire but also of the part depending on e.g. the room.
    The paint "wears out" - it becomes dirty with time, dust settles on it, reflection decreases.
    The MF correction factor itself consists of many "factors.
    MF = LLMF * LSF * LMF * RSMF (* NRF)
    Where the lamp itself (source) maintaining its flux is only LLMF (lamp lumen maintenance factor), and the group of lamps operating for the intended period is LSF (lamp survival factor).
    LMF is already a flux coming out of the luminaire (luminaire maintenance factor), which depends, for example, on dirty luminaires.
    The aforementioned RSMF is a room surface maintenance factor.
    So, in my opinion, if someone sets MF at 100%, he or she assumes in advance that the lamp has a system that initially reduces the luminous flux, which it programmatically increases over time, has some "magic methods of maintaining cleanliness and quality of the luminaires / room, or he doesn't know what he's doing.
  • #8 16781166
    AXELF
    Help: 8
    Rate: 49
    Probably only if you live in a vacuum you can take the factor 1 because dust will always appear :D
  • MF depends on room conditions, not just luminaire data
    #9 16781305
    JohnySpZOO
    Help: 186
    Rate: 330
    I know this, so when I get the calculations, I try to recalculate in my own way when something does not suit me or is on the border :D By the way, from a year ago I had the theme of a funeral home where the interior of the half of the building was in shades of black - simulations for the PB were made as standard 0.77 and here in the executive you have the modification of almost all the lighting because it will not work ... - arrangement made in PW. Life, you have to redo everything :)
    Later, as everything is accepted by the architect, the inquiry goes to the cost estimate.
    Once upon a time, Philips had such large 'heads' with several light sources in one housing, which allegedly caused air flow when the lampshade heated up, the movement of which cleaned the housing. It was 10 years ago.
    I once read in ElektoInfo about some intelligent lighting system, where luminaires based on sensors located in the room and adjust the beam to the conditions prevailing there - maintenance-free installation.
    I installed a similar patent on the basis of the Philips magic system (I do not remember the name of the system anymore) in 2013 at school, regulating the intensity of lighting by adjusting it to the current insolation, cooperating with a lighting intensity meter built in the middle of the room.
    Everything is fine, but in practice, space and lottery. It shone as it shouldn't shine or it was moody dark as it was supposed to be bright :idea: :idea: :idea: The funniest thing was that the funds for the modernization of lighting came from European funds and it had to be built and functioned as in the project. It was supposed to be cheaper and it turned out as always ... The producer's service spread their hands amen saying that everything is ok. At school at night, there is a disco in the windows. As a result, the fun with the lighting intensity after 3 weeks ended with a note that the lighting was functioning properly (intelligently) and the lighting intensity sensors were taped over.
  • #10 16781626
    Darom
    Electrician specialist
    Help: 231
    Rate: 588
    If I do not have data from an investor, I assume a stock / maintenance ratio of 0.8
    pzdr
    -DAREK-
The discussion revolves around the maintenance factor (MF) in Dialux, specifically comparing the set value of 0.77 and the expected intensity of 200lx with real-life measurements. Participants explain that the MF is intended to ensure that lighting intensity meets standards over time, accounting for factors like lamp maintenance and room conditions. Calculations for actual intensity involve using the formula Em = E * MF, where E is the initial intensity. Some users note discrepancies between theoretical calculations and practical outcomes, highlighting issues such as luminaires initially emitting higher light levels that stabilize over time. The MF is influenced by various factors, including lamp lumen maintenance, lamp survival, luminaire maintenance, and room surface maintenance. Users also share experiences with specific lighting projects, emphasizing the need for adjustments based on real-world conditions.
