Yato YT-3884 vs Neo Tools 08-671: Socket Wrench Set for Tractor & Agricultural Machinery (90)
berserker1 102840 8
  • #1 16782132
    berserker1
    Rate: 47
    I am looking for socket wrenches - so to bury the tractor or other agricultural machinery - generally for my own use. Which of the two sets would you recommend:
    http://allegro.pl/zestaw-narzedziowy-216cz-yato-yt-3884-1-gratis-i6959414168.html
    https://www.budujesz.pl/neo-zestaw-kluczy-1-4-3-8-1-2-219szt-08-671-88016/
    Unless some other suggestions? I do not know if there are still sets at a similar price to be socket and flat keys to 32?
  • #2 16782148
    patryk44gks
    Help: 11
    Rate: 74
    Neo is better made, so if you're considering between the two, I'd take Neo.
  • #3 16782216
    Aleksander_01
    Help: 1167
    Rate: 3435
    patryk44gks wrote:
    They're better made Neo so if you're considering between the two, I'd take Neo
    On what basis do you say, "because it's a lot better."
  • #4 16782322
    patryk44gks
    Help: 11
    Rate: 74
    No, because I used them.
    But I mostly use Honiton
  • #5 16782334
    mario 77
    Help: 66
    Rate: 335
    If for amateur use it is rather a difference, but probably more NEO. If you want to use it longer, I will buy some branded rattles for this set, because they do not sin with their original quality.
  • #6 16782346
    Cobrat
    Help: 35
    Rate: 502
    After all, the sets you have indicated do not have flat keys up to 32, only up to 19 or 22.
    You've been a bit freaked out with the amount of elements for that money ;) unless someone gives you a set of plasticine flat keys. Do not spare for tools, because it's your time, comfort and sometimes nerves.
    The budget tools (average shelf and price adequate to quality) can really recommend Honiton (as someone above). It's just that when buying Honitona the most popular suitcase 94 cz. and buying 6-32 combination wrenches you will certainly not fit in the amount of PLN 400.
  • #7 16783249
    patryk44gks
    Help: 11
    Rate: 74
    Flat quite good for this price I recommend this jonnesway at the workshop give advice
    And the rattles and rattles I recommend honithon under the pneumatics give advice
  • #8 16783453
    andrzej20001
    Help: 1578
    Rate: 6669
    Neo are better
  • #9 16790245
    mariuszprv
    Personally, I bought myself sets of yato and craze, there is even no amateurish applications, the little rattle is so weak that on the screw 6 I broke it and the flat keys were made of plasticine. neo are a little more solidly made, at least the caps do not break (in yato it cracked 17, 17, 18)
The discussion centers around the comparison of two socket wrench sets: Yato YT-3884 and Neo Tools 08-671, specifically for use with tractors and agricultural machinery. Users generally favor the Neo Tools set for its superior build quality, particularly for amateur use. Concerns were raised about the Yato set's durability, with reports of weak ratchets and low-quality flat keys. Additionally, it was noted that neither set includes flat keys up to size 32, which may be a limitation for some users. Recommendations for alternative brands like Honiton and Jonnesway were also provided, emphasizing the importance of investing in quality tools for long-term use.
