BMW e90 318i 2006 N46 129KM VALVETRONIC: Check Lights Issue w/ STAG4 QBOX PLUS, P1100 & P1101 Codes
rafal77g 7410 2
  • #1 16787774
    rafal77g
    Hello, I have a BMW e90 318i 2006 N46 129KM VALVETRONIC ENGINE. I have a STAG4 QBOX PLUS installation with automatic error reset connected to OBD and after 100 km 150 km, CHECK crashes to me. After a few days, it goes off by itself or it deletes it via the gas program and none of the technicians can set it up with AC. IT technicians do not want to upload the software to me to delete errors automatically.
    P1100 and P1101
    INSTALLATION PARTS;
    Reducer / Evaporator AC SA R 01
    HANA H2000 injectors
    PRESSURE SENSOR AC SA PS-02 (CLASS2)
    Multivalve filters, tank, fuel filler, it is probably not relevant.
    Gas workers tell me to go where I was assembling.
    The gas engine that installed it says that it is the unfortunate VALVETRONIC engine, my hands are falling down.
    LADIES Help
    I will add that when the car switched to petrol, I drove 300 km and nothing came on, it is OK on petrol. And on LPG, after 100-120 km, CHECK lights up.
    The gas engineers also said that I am braking the engine and this is the cause, or the lambda probe is broken, these errors are not from the probe but the intake air.
  • #2 16787800
    kkknc
    Help: 1915
    Rate: 6709
    You have assembly sp .....
    Assemble the board, set it up and it should work.
    Although both errors are related to the flow.
    So for sure on gasoline OK?
  • #3 16788035
    ptaszek_bs
    Rate: 16
    Yes, I have already driven 390 km on petrol and I am still driving and there is no error, on the computer because I checked. One gas engineer said that I had a pressure sensor installed too far from the injectors, a distance of 50 cm and preferably between injections 2 and 3 I have to change.
