BMW E90 318i 2006Year N46 - SORRY CHECK AND ERRORS P1100 and P1101
ptaszek_bs 19521 16
How can I stop P1100 and P1101 check-engine errors on a BMW E90 318i N46 with a STAG 4 QBOX Plus LPG system, and are they caused by the gas installation or by the engine?
Do not rely on the LPG controller to reset these faults; first clear them and test the car on gasoline only to see whether the codes come back [#16776644][#16776703] P1100/P1101 are treated here as mixture/throttle-related errors, so if they return on petrol you should look for airflow/intake problems such as the MAF, intake leaks, throttle-related sensors, or even temperature/thermostat issues rather than replacing the lambda probe immediately [#16778105] If the faults appear only on LPG, the installation is likely adjusted poorly for the N46 Valvetronic engine and needs proper tuning by a gas technician who understands this setup [#16778105] The installer should also check the hardware layout: the PS-02 pressure sensor should be mounted between the injectors, and the injector hoses should be secured with clamps so they do not slip [#16782952][#16782999]
  • #1 16776509
    ptaszek_bs
    Rate: 16
    Hello, I have a BMW e90 318i 2006 N46 ENGINE. In the car I have a STAG4 QBOX PLUS installation with automatic error reset connected to OBD and after driving 100km 150km I check CHECK. After a few days, it goes out on its own or erases it through a gas program, and no technician can set AC from it, IT technicians don't want to download the software so that it clears errors automatically.
    P1100 and P1101.
    HELP
  • #2 16776526
    Doktorr
    Help: 287
    Rate: 1098
    I understood. should the LPG controller reset throttle errors?
  • #3 16776576
    ptaszek_bs
    Rate: 16
    Yes exactly.
    Added after 8 [minutes]:
    I asked IT specialists that LPG driver may be blocked,
  • #4 16776644
    cobraa
    Help: 84
    Rate: 290
    Flow meter errors pop up and resetting errors will not fix the problem. The gas installation is to be selected and installed so that it does not generate any errors in the controller memory.
  • #5 16776683
    ptaszek_bs
    Rate: 16
    Ok, I think so too but there was a technician with AC and set up and nothing helped and says that I would replace the lambda probe. What does the probe have for these errors
    Gas workers also tell me that I would go to set the parameters where I put on gas, I got bored with this ride 10 times I was already and then dup ... they blame on the motor that it is VALVETRONIC
  • #6 16776703
    cobraa
    Help: 84
    Rate: 290
    Okay turn off the gas, clear the mistakes and ride on gasoline. See what will happen. If the same error crashes, you focus on the flow meter and the intake system, i.e. left air, etc.
  • #7 16776717
    ptaszek_bs
    Rate: 16
    ok I'm going to delete it and I will go on gasoline and tomorrow I will reply
    many thanks item
    Added after 21 [minutes]:
    Yesterday I erased the errors. And I was now checking and there is none and switched to gasoline I'll check the vehicle a few days.
  • #8 16778105
    helmud7543
    Help: 1216
    Rate: 1564
    ptaszek_bs wrote:
    Ok, I think so too but he was a technician with AC and set up and nothing helped and says that I would replace the lambda probe. What does the probe have for these errors
    Because this is a probe error (basically it is a mixture) - or they will write what interface they checked because they do not interpret all the same. And it can be caused by dozens of other problems than the damaged probe - flow meter, leaky intake, throttle position sensor (I do not know if this car is because the speed control is via valves) and even a temperature sensor and a thermostat (I do not know if in N46 but in slightly older he was able to dump the persistent check of the first probe and too poor mixture). Also, don't touch the probe for now.
    Maybe they actually spartolalised through Valvetronik, there the collector underpressure works differently (the valve stroke is responsible for the basic speed control and not the throttle), and knowing the life they made maps based on the vacuum. In any case, a gas-fired man who knows what Valvetronik is will just adjust the installation, but if he knocks on Valvetronik, you can suspect that he doesn't know what's going on. Well, they confuse Vanos with Valvetronik, I hope that they did not regulate you as in the case of an engine with ordinary variable timing phases :-)
    Check on gasoline. As it will be ok, I suggest creating a topic in the Gas installations section.
  • #9 16778565
    ptaszek_bs
    Rate: 16
    Thanks a lot since yesterday I run on gasoline and I deleted these two mistakes
    P1100
    P1101
    I'll do 200km and check if there are errors, because on LPG it is 100km or 120 as standard and CHECK was on
  • #10 16780154
    psooya
    Help: 376
    Rate: 575
    What have you fitted and how? Valva is the most pleasant engine to regulate because it always works well. If you don't have far, write pw.
  • #11 16780843
    ptaszek_bs
    Rate: 16
    STAG 4 BOX PLUS
    I am passive around these
    STAG4 QBOX PLUS I wrote it wrong before
  • #12 16780900
    psooya
    Help: 376
    Rate: 575
    What lumber you have under the hood, the driver is not an installation. 4 devils overpaid in this car. You don't have far. Upload a list of lumber like injectors and reducer and pictures from under the bonnet as well as where they installed the injectors. As something more like this you can not grasp it PW after the above.
  • #13 16782850
    ptaszek_bs
    Rate: 16
    Reducer / evaporator AC SA R 01
    HANA H2000 injectors
    AC SAFE PRESSURE SENSOR PS-02 (CLASS2)
    multivalve filters, tank, fuel filler is probably not important.
    Added after 20 [minutes]:
    BMW E90 318i 2006Year N46 - SORRY CHECK AND ERRORS P1100 and P1101 BMW E90 318i 2006Year N46 - SORRY CHECK AND ERRORS P1100 and P1101 BMW E90 318i 2006Year N46 - SORRY CHECK AND ERRORS P1100 and P1101 BMW E90 318i 2006Year N46 - SORRY CHECK AND ERRORS P1100 and P1101
  • #14 16782952
    psooya
    Help: 376
    Rate: 575
    Apart from the wrong positioning of the PS-02 and the lack of bands at the injector outlet - you can see the tubes slightly sliding down the git. The car must drive correctly on such a mounted installation - only adjustment is needed except for the armbands.
  • #15 16782962
    ptaszek_bs
    Rate: 16
    so exactly on LPG is also ok except for the glowing CHECK so every 100-120km. I'm still on gas, I'll do 200-300km and check if I have these two errors P1100 and P1101
    Added after 4 [minutes]:
    It's a pressure sensor that's in the wrong place, right?
  • #16 16782999
    psooya
    Help: 376
    Rate: 575
    Yes, it should be between the injections and it usually fits there too. The Checks are probably from poor regulation, although it is a very simple car so it is not ok.
  • #17 16806777
    psooya
    Help: 376
    Rate: 575
    And how is Beemka after the changes? Is it working as it should?
The discussion revolves around a BMW E90 318i (2006) with an N46 engine experiencing persistent error codes P1100 and P1101, linked to a STAG4 QBOX PLUS LPG installation. The user reports that after driving 100-150 km, the CHECK light activates, but it can be reset either automatically or manually. Various responses suggest that the errors may be related to the flow meter, lambda probe, or issues with the Valvetronic system. Recommendations include switching to gasoline to diagnose the problem, checking the installation of the LPG system, and ensuring proper adjustment of components like the pressure sensor and injectors. The user plans to monitor the vehicle after switching to gasoline and has received advice on potential adjustments needed for the gas installation.
TL;DR: BMW E90 318i (N46) with LPG shows P1100/P1101 about every 100–150 km; “resetting errors will not fix the problem.” [Elektroda, cobraa, post #16776644]
Why it matters:** This FAQ helps BMW N46 owners running STAG4 QBOX PLUS diagnose and stop recurring MAF/mixture faults instead of masking them.
What are P1100 and P1101 on a BMW E90 N46 with LPG?
In this thread they point to flow meter (MAF) and mixture issues. The ECU logs these when airflow readings or learned mixture drift outside expectations. On LPG, poor calibration or intake leaks can trigger them. Clearing codes does not resolve the root cause. [Elektroda, cobraa, post #16776644]
Should I auto-clear these codes with the LPG controller?
No. Auto-clearing hides symptoms and delays repair. As one expert wrote, “resetting errors will not fix the problem.” Fix airflow/mixture causes instead by calibration and leak checks. [Elektroda, cobraa, post #16776644]
How do I confirm LPG is the culprit, not petrol operation?
Disable LPG, clear codes, and drive on gasoline. If codes do not return, focus on LPG calibration and plumbing. If they return, inspect MAF and intake leaks. This isolates fuel-system influence quickly. [Elektroda, cobraa, post #16776703]
What did the OP see after switching to gasoline?
After clearing and switching to petrol, the OP reported no errors on recheck. This supports an LPG-side cause rather than a persistent petrol fault. [Elektroda, ptaszek_bs, post #16776717]
Do I replace the lambda (O2) sensor first?
Not first. The post explains the code reflects mixture, which many faults can affect: MAF, intake leaks, throttle/position sensing, even temperature control. Quote: “don’t touch the probe for now.” Diagnose upstream causes before replacing sensors. [Elektroda, helmud7543, post #16778105]
How does Valvetronic affect LPG tuning on the N46?
Valvetronic controls load with valve lift, so manifold vacuum behaves differently than throttled engines. LPG maps built around vacuum can mislead calibration. Tuners must adapt strategy for Valvetronic characteristics. [Elektroda, helmud7543, post #16778105]
Where should the AC PS-02 pressure sensor be installed?
Mount the PS-02 between the injectors on the rail. Misplacement skews pressure feedback and mapping. The expert explicitly notes this location as correct for reliable readings. [Elektroda, psooya, post #16782999]
What LPG hardware did this car have?
Reported components: AC R01 reducer/evaporator, HANA H2000 injectors, and AC PS-02 pressure sensor, with standard multivalve and filters. Photos were provided for layout review. [Elektroda, ptaszek_bs, post #16782850]
Are these parts sufficient if tuned right?
Yes. Feedback stated the car “must drive correctly on such a mounted installation—only adjustment is needed,” plus proper hose securing and sensor placement. This underscores calibration quality over parts swapping. [Elektroda, psooya, post #16782952]
Quick test: How can I reproduce the issue pattern safely?
  1. Clear codes and log fuel trims.
  2. Drive 50–80 km on LPG, then 50–80 km on petrol.
  3. Compare results; the OP saw codes reappear every 100–120 km on LPG only. This narrows the fault to LPG calibration or plumbing. [Elektroda, ptaszek_bs, post #16782962]
How do I check for intake leaks on this setup?
Inspect injector hoses for slippage, ensure clamps at injector outlets, verify tight manifold connections, and smoke-test if available. Loose hoses and poor sensor placement were noted and should be corrected before remapping. [Elektroda, psooya, post #16782952]
What does “flow meter” mean here?
It refers to the Mass Air Flow (MAF) sensor. The discussion links the logged errors to the MAF and airflow measurement faults that disturb mixture control. [Elektroda, cobraa, post #16776644]
Can cooling system parts cause mixture faults on N46?
Yes. A faulty temperature sensor or thermostat can upset mixture control and keep the Check Engine light on. This is an edge case worth checking after intake and MAF tests. [Elektroda, helmud7543, post #16778105]
Is Valvetronic hard to tune on LPG?
No. A practitioner said, “Valva is the most pleasant engine to regulate.” With correct strategy and sensor placement, it calibrates cleanly. Choose a tuner familiar with Valvetronic. [Elektroda, psooya, post #16780154]
