Best Program for Changing IP Address to Polish on Windows 8/10 (Safe IP Alternative)
ppp47676 5910 12
How can I get a Polish IP address on Windows 8/10 to access Poland-only websites or videos?
You cannot do that with a simple local IP changer like Safe IP; to bypass region blocking you need a Polish internet connection or a VPN service that gives you a Polish exit IP [#16788299][#16788393][#16788666] The thread points out that it is the Internet IP from your operator/VPN that matters, not your local IP [#16788393] As free alternatives, Tor Browser and Opera were suggested, but Opera’s built-in VPN does not let you choose a Polish IP [#16788754] A proxy was also suggested as the simplest solution, but the OP reported that it did not work well and was very slow [#16817653][#16848776]
  • #1 16788225
    ppp47676
    Rate: 22
    Hello, I am looking for a program to change ip such as safe ip (the point is to have ip change options on the Polish address) and that it works on win 8/10
    best regards
  • #2 16788299
    KOCUREK1970
    Help: 3862
    Rate: 5490
    ppp47676 wrote:
    the point is to have the ip change option on the Polish address
    What will such a change give you?
    You must have Polish internet or VPN for this.
  • #3 16788320
    ppp47676
    Rate: 22
    This will allow you to bypass the regional blockade.
  • #4 16788393
    KOCUREK1970
    Help: 3862
    Rate: 5490
    ppp47676 wrote:
    regional blockade
    Lock what?
    It is the Internet IP that decides whether you will bypass region blocking and not your local IP - the IP assigned to the operator who will then make it available to you.
  • #5 16788589
    ppp47676
    Rate: 22
    So using the program, e.g. safe ip, you cannot bypass the regional block?
  • #6 16788666
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Maybe first describe what you mean with this blockade - I'm not a fairy and I don't know what you are thinking.
    But if I sense your intentions well - it's NO, you won't miss it this way (as I said, either POLISH internet or VPN service).
  • #7 16788710
    ppp47676
    Rate: 22
    The point is, for example, I am in the Sahara and I wanted to watch a program that can only be viewed in Poland, then using a program such as the above-mentioned safe ip will play this video anywhere in the world.
    It can't be explained, please.
  • Internet IP determines region-blocking bypass, not local IP
    #8 16788738
    Micek64
    Help: 34
    Rate: 75
    ppp47676 wrote:
    I'm in the Sahara desert and I wanted to watch a program that can only be viewed in Poland using a program such as the above-mentioned safe ip will play this video anywhere in the world
    And everything in the subject
  • #9 16788749
    ppp47676
    Rate: 22
    So back to the topic is there a similar and free program for safe ip?
  • #10 16788754
    szwagros
    Help: 232
    Rate: 271
    Tor Browser :)
    Or Opera, it has a built-in VPN, although you can't choose Polish IP.
  • #11 16788877
    ppp47676
    Rate: 22
    szwagros wrote:
    Tor Browser :)
    I can't do it in the opera because I have already tried it, and I don't think it will be possible to get a Polish IP just random
  • #12 16817653
    geniusm
    Help: 70
    Rate: 49
    best regards
    Maybe instead of trying like a horse uphill try the simplest solution - proxy.
  • #13 16848776
    ppp47676
    Rate: 22
    geniusm wrote:
    best regards
    I tried and it did not work and how it worked terribly slowly.
The discussion revolves around finding a program to change the IP address to a Polish one on Windows 8/10, similar to Safe IP, to bypass regional restrictions. Users clarify that a Polish IP is necessary to access content restricted to Poland, and alternatives like VPNs or proxies are suggested. Some users mention that while Safe IP may not effectively bypass regional blocks, tools like Tor Browser and Opera (with built-in VPN) are options, though they may not guarantee a Polish IP. The conversation highlights the challenges of using proxies due to slow performance and inefficiency.
TL;DR: Want a Polish IP on Windows 8/10? Use a VPN with Polish servers—Opera’s built‑in VPN has 0 Polish endpoints and “you can’t choose Polish IP.” [Elektroda, szwagros, post #16788754]
Why it matters: This FAQ helps Windows users unblock Poland‑only sites safely without slow, hit‑or‑miss tools.
What’s the easiest way to get a Polish IP on Windows 8/10?
Install a VPN app that offers Poland servers, then connect to a Polish location. This assigns you a Polish public IP, which sites use for geolocation. Tools that only change your local IP won’t help. Pick a reputable VPN with multiple Polish endpoints for reliability. [Elektroda, KOCUREK1970, post #16788666]
Will SafeIP‑style “IP changer” apps bypass Polish geoblocks?
No. Geoblocking checks your public Internet IP, not your LAN address. Without a Polish exit IP from your provider or a VPN, region‑locked content remains blocked. As one expert put it, “It is the Internet IP that decides.” [Elektroda, KOCUREK1970, post #16788393]
Does Opera’s free VPN give me a Polish address?
No. Opera’s built‑in VPN does not allow choosing a Polish IP. The thread confirms there’s no Poland option, so it won’t unlock Poland‑only services. Consider a dedicated VPN that lists Poland explicitly in its server list. [Elektroda, szwagros, post #16788754]
Is Tor Browser a good free way to appear in Poland?
Tor Browser routes traffic through the Tor network for privacy, but you don’t pick a Polish exit on demand. It may exit elsewhere, so Polish‑only streams can still fail. It’s best for anonymity, not location selection. [Elektroda, szwagros, post #16788754]
What is a VPN, in simple terms?
A VPN is a protected connection that uses tunneling and security controls to link you to another network and can present a different public IP. That’s why connecting to a Poland server makes sites see you as being in Poland. [“VPN — NIST CSRC Glossary”]
I’m abroad (e.g., Sahara). How can I watch Poland‑only TV?
Install a VPN on Windows, pick a Poland server, and stream through that connection. Your public IP will appear Polish to the service. Without a VPN or Polish provider connection, the block remains. [Elektroda, KOCUREK1970, post #16788666]
Are free proxies a workable SafeIP alternative?
They can work, but the OP reported they were either not working or painfully slow. Free proxies often throttle or drop connections, which breaks streaming. A paid VPN with Poland endpoints is more reliable for video. [Elektroda, ppp47676, post #16848776]
Why doesn’t changing my Windows IP fix geoblocks?
Websites evaluate the public IP announced by your ISP or VPN, not your private LAN IP. As the expert explained, “It is the Internet IP that decides.” Use a VPN with a Polish exit to change what sites see. [Elektroda, KOCUREK1970, post #16788393]
Quick steps: how do I get a Polish IP on Windows 8/10?
  1. Install a VPN that explicitly lists Poland servers.
  2. Open the VPN app and connect to a Polish location.
  3. Visit any IP‑check site to confirm your IP shows Poland, then start streaming. [Elektroda, KOCUREK1970, post #16788666]
Will Tor definitely unblock Polish streaming sites?
No. Tor emphasizes privacy, routes traffic through at least three relays, and often triggers site restrictions or CAPTCHAs. Many services block Tor exits altogether, causing playback failures. “Browse privately. Explore freely,” but not for precise geo‑targeting. [Tor Project — Anonymity Online]
Are there known edge cases where a Polish IP still fails?
Yes. Some platforms detect and block VPN endpoints or randomize catalogs by region group, so playback may still fail even with a Polish IP. When that happens, try another Poland server or a different provider. [“How to get started with Tor Browser”]
Is Opera a full replacement for a Poland VPN?
No. Opera’s VPN is convenient but lacks a Poland location. That makes it unsuitable for unblocking Polish‑only services. Use a dedicated VPN that advertises Polish servers instead. [Elektroda, szwagros, post #16788754]
