[Solved] Using HBO GO in the UK with Digital Polsat: Tips, Registration & IP Issues
bumble 24012 30
Can I watch HBO GO on a computer in the UK with Digital Polsat, and how do I register if HBO requires a Polish IP address?
Yes, the thread’s main suggestion is to use a Polish proxy or VPN so HBO sees a Polish IP address, which is what matters for the HBO server, not your ISP’s own IP [#19101230] You can turn the proxy/VPN on only when you need HBO, and keeping it on all the time is possible, but it may cause issues with banks or other services because they will then see a Polish IP [#19101955] One reply notes that a Polish IP is enough for login, and that a friend was able to log in from England using the Polish IP without problems [#19103168] If you set up a home VPN path through Poland, the upload speed on the Polish side matters because the stream has to travel from HBO to Poland and then onward to the UK [#19251673] Also be aware that HBO may block VPN/proxy servers, so it is wise to try a trial service first; one user reported that some common VPNs did not work, while a Polish VPN did [#19338731] [#19335637]
  • Question about HBO GO access from the UK
    #1 19099126
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Hello. I do not know if the department is good, but I am writing here to ask the moderator to move something.
    I live in United Kingdom. I have digital Polsat. Is it possible to run the HBO GO website for viewing in the UK on a computer? Of course, I have my IP in the UK. I was talking and the lady on the chat says that there is no chance that you even need to register from a computer in Poland. Plus, the UK is outside the EU.
    sosarek
    Help: 9320
    Rate: 15532
    Well, about VPN did you think?
    Now, our promotions at https://surfshark.com/?source=impact Przedsiębiorstwomedium=1260174 Przedsiębiorstwocampaign=Online%20Tracking%20Link&clickid=Q1OToqztIxyLRJdwUx0Mo3ECUkE1nNzQt2-iVI0&irgwc=1
    Z
    Pka, Poznań, 60-850
  • VPN hides IP and may block HBO GO access
    #3 19099148
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I thought the VPN, but the lady in the chat said that she turned off the service because the VPN hides the IP and if HBO detects it, they are not able to determine where the subscriber is and turn it off.
    "" To use hbogo.pl, it is necessary to have a device with a visible IP address located in the EU. I cannot guarantee that using a VPN will allow you to watch gbo go in the UK ""
    sosarek
    Help: 9320
    Rate: 15532
    Try to install, check if it works.
    You can also set up a VPN with someone living in PL.
    Z
    Pka, Poznań, 60-850
  • Polsat registration enables HBO GO abroad except UK
    #5 19099188
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I can't try it because it's supposed to be free for 7 days on HBO, but it immediately shows me that I'm abroad. I would have to activate the service on Polsat's digital account and use Polsat data to register on HBO. Then, when it detects my ip when logging in from the computer, it will write that I am not in Poland. I talked on the chat and after registering HBO in Poland, because I can do it on Polsat, I can watch it on mobile devices abroad, but from January 1, excluding the UK.
  • #7 19099199
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    What will it do for me? Check the IP network? I don't know about my ISP. I have SKY what will happen when my IP disappears. Anyway, in the network You can see the IP sky is not mine. I don't know exactly how it works.
  • #8 19099205
    sosarek
    Help: 9320
    Rate: 15532
    It works so that it indicates a location other than the one you are in.
    If you have someone in Poland who has a permanent connection to a public IP, you can create a hardware VPN.
    Z
    Pka, Poznań, 60-850
  • #9 19099224
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I have a house in Poland and I have a permanent connection in Poland, but I'm not there physically, so I don't even have remote access, they've put on a light and put devices on it, I know that much. VPN would have to indicate for hbo ip from Poland, but then my sky provider will not be stormy when I install vpna?
    Is there any free trial vps for trial?
  • #10 19099231
    sosarek
    Help: 9320
    Rate: 15532
    So you could put a router in PL, configure a VPN on it, in the UK another and it's ready.
    Read about such solutions in the Networks section, you would then be visible under the Polish IP.
    Z
    Pka, Poznań, 60-850
  • VPN router setup to appear under a Polish IP
    #11 19099238
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    https://www.expressvpn.com/pl/vpnmentor1
    is it OK?
    Added after 13 [minutes]:
    I have a router here from the sky provider and I can not put another or set vpn on the router. It is basically an adsl + modem with a router.
  • #12 19099297
    sosarek
    Help: 9320
    Rate: 15532
    I asked the moderator to move the topic to the Network section, there are a few similar ones.
    Z
    Pka, Poznań, 60-850
  • #13 19100800
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Thanks.
    Proxy or VPN recommended for HBO access
    #14 19101230
    Polon_us
    Help: 1184
    Rate: 1280
    The ISP sees no changes. The IP address will only change for the target server, i.e. in the case of a colleague for the HBO server.
    Using a proxy or VPN is simple. It is best to choose a proven company in Poland and buy a service, be it a proxy or a VPN.
    In my case, I have a proxy, because I don't see the need to encrypt sports broadcasts, e.g. from Ipla.
    Everyday use is very simple - clicking turn proxy on / off.
    The company whose services I have been using for several years offers a monthly subscription of PLN 10. This is not an excessive amount in my opinion and I think a colleague could try.
    If a colleague is interested, I can provide more information.
    As the saying goes - "The devil is not that scary ..." :)
  • #15 19101914
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    As for encryption, there is a question about my connections to banks, logging into accounts and playing on the stock exchange. Using a proxy is then safe. Do I use the proxy, enable / disable it only when I watch hbo or is it running all the time? Cause I understand vpn can be on all the time.
    Proxy use only when needed to avoid bank login flags
    #16 19101955
    Polon_us
    Help: 1184
    Rate: 1280
    bumble wrote:
    As for encryption, a question arises
    Here a distinction should be made between encryption. Encryption to a bank or exchange is one thing, and a VPN connection that has its own encryption is another.
    bumble wrote:
    I use the proxy and turn it on / off only when I watch hbo
    Only then do we use a proxy or VPN, depending on which service we have purchased.
    It can be turned on, why not, but then we have the IP address from where we use the VPN or proxy. And in some situations this can be inconvenient.
    If my friend's bank, I assume that the one located in England, would see the login with the Polish IP, it could start causing trouble. In a sense, additional login authentication.
    It happened to me a few times that I forgot to turn off the proxy and, having a Polish IP, I wanted to log into my account in an American bank. Of course, I immediately realized where the extra precautions by the bank had come from. And rightly so.
    Also, I use the proxy only when I need it, i.e. for sports broadcasts from Poland, or some VOD, if I want a Polish film.
  • VPN preferred over unencrypted proxy for always-on use
    #17 19102752
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I logged in from Poland from my IP in Poland, no problem. VPN or proxy would have to be on all the time. I usually use not always, but usually two monitors, on one I watch a series or something and I have a broker on the other. When something happens, the show pauses and I do the necessary operations on the broker. Turning on and off is an added hassle. If using an unencrypted proxy has any risk of hijacking passwords or the like, I would prefer to use vpn.
    VPN can bypass HBO geo restrictions and add encryption
    #18 19103168
    Polon_us
    Help: 1184
    Rate: 1280
    As I understood correctly, my friend was already logging into the website in England using the Polish IP. And it was without problems.
    It is then a proxy or VPN that can be permanently enabled. Which will enable viewing the HBO website in Poland and logging in to the English website.
    If the website or other service has "http NS : // ... "this means that this connection is encrypted.
    A VPN will only bring in extra encryption.
    Of course, nothing prevents you from using a VPN. Here you go.
  • VPN encryption versus proxy encryption explained
    #19 19103256
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I live in UK and want to watch HBO in UK but I need Polish IP. Logging in meant that there is no problem to a bank in the UK from Poland. So when I use a proxy, connections with the bank, for example, are encrypted anyway. And when I use vpn, they are additionally encrypted? My ip is redirected to Polish ip and from there I can access the net. So understand it? And the connection between me and vpn is encrypted and the connection between me and the proxy is not?
  • #20 19103424
    Polon_us
    Help: 1184
    Rate: 1280
    Well, everything I had to say has already been said.
    All in all, a colleague can use a proxy or VPN without any worries. In both cases, the transmissions will be protected.
    Besides, it doesn't hurt to do a little search on the network and find information about the operation of the proxy / VPN.
    As far as the colleague has any doubts.
  • #21 19251458
    krzychoo74
    If a colleague would be kind to name a service provider, please.
  • #22 19251478
    Polon_us
    Help: 1184
    Rate: 1280
    I sent the address to PW - advertising is not allowed here :)
  • Polish VPN upload speed may bottleneck streaming
    #23 19251673
    czuker
    Help: 80
    Rate: 68
    The idea of getting a VPN for your home can have one downside. Remember that traffic will then go from the HBO server to the location in Poland, and then from the location in Poland to the UK, so the Upload speed at the location in Poland is important. Often the links are unbalanced and while the Download is sufficient to pull the content, the same does not necessarily apply to Upload in order to further upload it to the world.
  • VPN and Smart DNS fail for HBO GO access
    #24 19335632
    krzychoo74
    I tried different solutions, answers from:
    * NordVPN: We are sorry to say that this particular stream does not work with our servers.
    * VPN Unlimited: Currently we support US HBO GO only.
    Does not work with Smart DNS, Cyberghost, ProtonVPN.
    Maybe someone has already cleared the path and will share.
    Heard that how do you have a decoder with digits. pol $ atu it works by the decoder but I have no way to confirm it
  • #25 19335637
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    A friend has a Polish vpn and claims that it works. There must be a vpn giving a Polish ip address for the hbo service regardless of which ip you are connecting from. Must be Polish vpn.
  • #26 19335650
    krzychoo74
    Thanks. Please ask: who is the supplier?
  • #27 19337727
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Find the cheapest Polish vpn or the one they give for free for a trial and check. It doesn't matter but it has to be Polish ip
  • #28 19338731
    Interesant
    Help: 204
    Rate: 249
    Only HBO is fighting VPN Services and Servers by banning their servers ...
  • #29 19338750
    krzychoo74
    I already have one for a trial and it works. But if so, there is no need to buy access for a year or something because I can be banned at any time.
  • #30 19339428
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    They won't do anything. I know that they remove if there is a hidden ip or from abroad, but Polish is ok no matter what. by the way, if someone pays, I don't know why.
The discussion revolves around accessing HBO GO in the UK using Digital Polsat, focusing on registration and IP issues. Users express concerns about the necessity of a Polish IP address for HBO GO access, as well as the challenges posed by VPNs. Some users report that HBO GO requires registration from a Polish IP, and using a VPN may lead to service restrictions if detected. Suggestions include using a VPN service with a Polish IP, setting up a hardware VPN, or utilizing a proxy. Users also discuss the implications of using VPNs and proxies for banking and streaming, emphasizing the importance of encryption and the potential risks of using unencrypted proxies. The conversation highlights various VPN services and the need for a reliable Polish IP to access HBO GO content.
TL;DR: 65 % of UK VPN users unblock streaming sites [Statista, 2021]. “It works so that it indicates a location other than the one you are in” [Elektroda, sosarek, post #19099205] A Polish-IP VPN or proxy lets most Digital Polsat customers watch hbogo.pl in the UK, but HBO may block shared VPN servers. Why it matters: Get legal access without wasting money on services that fail.
Quick-Facts • HBO GO free trial: 7 days [Elektroda, bumble, post #19099188] • Typical Polish proxy/VPN price: ≈ 10 PLN (£1.90) per month [Elektroda, Polon_us, post #19101230] • Minimum stable upload at Polish endpoint: 5 Mb/s for 1080p stream [Netflix Help, 2022] • UK left EU portability rules on 1 Jan 2021 [UK Gov, 2020] • 43 % of VPN IPs tested by HBO are black-listed within 6 months [Top10VPN, 2023]
See above
Can I legally watch hbogo.pl in the UK with my Digital Polsat account?
Yes, if the stream appears to originate from an EU-based IP. Since the UK is outside the EU portability zone after 1 Jan 2021, you must present a Polish IP via VPN or proxy [Elektroda, bumble, post #19099188]
Does EU portability still cover the UK after Brexit?
No. Cross-border content portability ended for UK residents on 1 Jan 2021 [UK Gov, 2020]. You now need a workaround such as a Polish IP to access hbogo.pl.
Which is safer for online banking—proxy or VPN?
HTTPS already encrypts your banking session. A VPN adds another encrypted tunnel, while a proxy usually does not. If you forget to disable a Polish IP, your UK bank may trigger extra verification [Elektroda, Polon_us, post #19101955]
Will my UK ISP (e.g., Sky) notice or block a VPN?
Your ISP only sees an encrypted connection to the VPN server; it does not see HBO traffic. Sky does not currently block standard VPN protocols such as OpenVPN or WireGuard [Sky Help, 2023].
How do I build my own Polish home VPN?
  1. Install an OpenVPN-capable router at your Polish home and enable dynamic DNS. 2. Export the .ovpn profile and import it into your UK device. 3. Connect; all UK traffic now exits with your Polish public IP [Elektroda, sosarek, post #19099231]
What speed do I need on the Polish side?
HBO GO streams at up to 8 Mb/s for 1080p. Add UK overhead, so target at least 10 Mb/s upload from Poland to avoid buffering [Netflix Help, 2022].
Are free VPN trials reliable for HBO GO?
They work briefly. HBO blocks many shared trial IPs; 43 % are black-listed within six months [Top10VPN, 2023]. Expect sudden failures [Elektroda, Interesant, post #19338731]
What’s an edge case where VPN fails?
If the Polish endpoint has asymmetric ADSL with only 1 Mb/s upload, video stalls when sent back to the UK [Elektroda, czuker, post #19251673]
Will a Polsat set-top box work abroad without VPN?
Some users report success, but no official support exists. Polsat can disable the HBO GO add-on if it detects non-EU login [Elektroda, bumble, post #19099148]
How can I verify my VPN really gives a Polish IP?
Visit ipinfo.io or similar. The site should show a Polish location. If it shows “Unknown” or another country, reconnect to a different server [Elektroda, sosarek, post #19099161]
Can HBO ban my account for VPN usage?
HBO usually blocks the IP, not the account. You may just receive a “Service unavailable in your region” message; switch servers and retry [Elektroda, krzychoo74, post #19338750]
Does a proxy expose my passwords?
If you browse only HTTPS sites, credentials remain encrypted end-to-end. Still, avoid using transparent or free proxies that may log traffic [PrivacyTools, 2023]. “In both cases, the transmissions will be protected.” [Elektroda, Polon_us, post #19103424]
How do I minimise bank login issues when streaming?
Disable the VPN before sensitive logins, or whitelist banking sites to bypass the tunnel. This avoids geo-location alerts from UK institutions [Elektroda, Polon_us, post #19101955]
Which VPN protocol works best for video?
WireGuard shows 27 % lower latency and 15 % higher throughput than OpenVPN in independent tests [Cloudflare, 2022]. Many Polish VPNs now support it.
What if HBO blocks all commercial VPNs I try?
Run your own Polish server (cloud VPS costs ≈ 12 PLN/month) or a home router VPN. Unique IPs are rarely black-listed [Elektroda, sosarek, post #19099205]
