Resolve Incorrect IP Address (-201) for Nc Plus Go Abroad: Change to Polish IP Guide
1wymiatacz1 8706 8
  • #1 16565281
    1wymiatacz1
    Hello. Trying to watch the channels on the NC page plus it popped up an error (wrong IP address), probably for the fact that I live abroad and can only be used in Poland. Is there a way to change ip to Polish? If so, please explain this to me. Thanks in advance . Greetings...
  • #2 16565399
    WMichał
    Level 32  
    Help: 172
    Rate: 136
    If the problem really is geolocation of the IP address, then you can use some Polish vpn.
  • #3 16566831
    1wymiatacz1
    I do not understand what to do @ Michael, maybe someone has a different idea? I know there are different programs for this but I do not know exactly what. Please help .
  • #5 16584073
    1wymiatacz1
    Anyone else have an idea? The above program is payable.
  • #6 16584100
    jimasek
    Help: 3783
    Rate: 2681
    You can look for something free, but most of this type of services is then very limited in terms of its functionality. I use vpnonline services myself and I'm happy.
  • #7 16584170
    1wymiatacz1
    Can someone send a program?
  • #8 16584220
    jimasek
    Help: 3783
    Rate: 2681
    Unfortunately, I do not know such an application.
  • #9 16584251
    KOCUREK1970
    Help: 3860
    Rate: 5488
    The program itself will not give you anything - you have to "get" someone / buy such a service.
    Free offers often have a tragic, even snail transfer.
    For free viewing tv via neta, transfer via VPN must be at the level of 25/30 Mb - on the free option, no one will give you so much.
To resolve the IP address error (-201) encountered while using NC Plus abroad, users are advised to utilize a Polish VPN service to change their IP address to a Polish one. Several suggestions were made, including the paid service vpnonline.pl, which is favored for its reliability. However, users expressed interest in free alternatives, although these often come with limitations such as reduced functionality and slower speeds. It was noted that free VPN services may not provide sufficient bandwidth for streaming, with a recommended speed of at least 25-30 Mbps for optimal viewing.
