Opeal Astra H Fuel Filter - FRAM fuel filter - installation question
Panzi 6258 4
  • #1 16789475
    Panzi
    Is it necessary to remove this outer white cover when installing this filter, ie FRAM c10026a? A trivial question, but so far I have not received a clear 100% answer because they are contradictory, and 'unfortunately' I bought such a filter.
    Thanks in advance for the hint. [/ Img]
  • #2 16789554
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. If that's what it looks like, there's no need to Opeal Astra H Fuel Filter - FRAM fuel filter - installation question unless it is to protect the filter against damage in transport.
  • #3 16789768
    Panzi
    It is an outer cover attached like rivets. And this is the problem whether it is a transport or permanent one as an additional external filter.
    Maybe someone has already encountered such a filter.
  • #5 16824956
    Panzi
    The case resolved - the cover remains as an integral part of the filter. But the next time you buy a typical filter, even in stores they had different opinions.
    Serviceman - thanks for your help.
