Lenovo K6 Note Software Upload Issue: QPST_2.7.438.3 Program Crash & Visibility in Windows 7 x64
sagem90 4299 2
  • #1 16790531
    sagem90
    Help: 22
    Rate: 85
    Hello, I have a problem with the lenovo k6 note. I have to upload new software, drivers installed, the phone is visible in the QPST_2.7.438.3 program, but unfortunately when you click Download, the program does not start uploading, but hangs and then crashes. The same windows 7 x64 on two computers
    Does anyone know where the problem is?
    Ps is also visible in this program, but it is still like in the picture.
    Log from QPST:
    Validating Application Configuration
    Load APP Configuration
    COM:0
    PBLDOWNLOADPROTOCOL:0
    PROGRAMMER:True
    PROGRAMMER:
    SEARCHPATH:C:\
    ACKRAWDATAEVERYNUMPACKETS:False
    ACKRAWDATAEVERYNUMPACKETS:100
    MAXPAYLOADSIZETOTARGETINBYTES:False
    MAXPAYLOADSIZETOTARGETINBYTES:49152
    DEVICETYPE:eMMC
    PLATFORM:8x26
    VALIDATIONMODE:0
    RESETAFTERDOWNLOAD:False
    MAXDIGESTTABLESIZE:8192
    SWITCHTOFIREHOSETIMEOUT:30
    RESETTIMEOUT:200
    RESETDELAYTIME:2
    FLATBUILDPATH:C:\
    FLATBUILDFORCEOVERRIDE:True
    QCNPATH:C:\Temp\00000000.qcn
    QCNAUTOBACKUPRESTORE:False
    SPCCODE:000000
    ENABLEMULTISIM:False
    Load ARG Configuration
    Validating Download Configuration
    Image Search Path: C:\
    Process Index:0
    Programmer Path:C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware\prog_emmc_firehose_8937_ddr.mbn
    Image Search Path: C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware
    RAWPROGRAM file path: C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware\rawprogram0.xml
    PATCH file path:C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware\patch0.xml
    Start Download
    Program Path:C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware\prog_emmc_firehose_8937_ddr.mbn
    Binary build date: May 13 2015 @ 14:41:37
    QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files (x86)\Qualcomm\QPST\bin\QSaharaServer.exe -p \\.\COM145 -s 13:C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware\prog_emmc_firehose_8937_ddr.mbn 'Current working dir: C:\Users\Maras\AppData\Roaming\Qualcomm\QFIL
    Sahara mappings:
    2: amss.mbn
    6: apps.mbn
    8: dsp1.mbn
    10: dbl.mbn
    11: osbl.mbn
    12: dsp2.mbn
    16: efs1.mbn
    17: efs2.mbn
    20: efs3.mbn
    21: sbl1.mbn
    22: sbl2.mbn
    23: rpm.mbn
    25: tz.mbn
    28: dsp3.mbn
    29: acdb.mbn
    30: wdt.mbn
    31: mba.mbn
    13: C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware\prog_emmc_firehose_8937_ddr.mbn
    20:59:47: ERROR: function: rx_data:247 Error occurred while reading from COM port
    20:59:47: ERROR: function: sahara_main:854 Sahara protocol error
    20:59:47: ERROR: function: main:265 Uploading  Image using Sahara protocol failed
    Download Fail:Sahara Fail:QSaharaServer Fail:Process fail
    Finish Download
    Start Download
    Sahara mappings:
    2: amss.mbn
    6: apps.mbn
    8: dsp1.mbn
    10: dbl.mbn
    11: osbl.mbn
    12: dsp2.mbn
    16: efs1.mbn
    17: efs2.mbn
    20: efs3.mbn
    21: sbl1.mbn
    22: sbl2.mbn
    23: rpm.mbn
    25: tz.mbn
    28: dsp3.mbn
    29: acdb.mbn
    30: wdt.mbn
    31: mba.mbn
    21:00:35: ERROR: function: rx_data:247 Error occurred while reading from COM port
    21:00:35: ERROR: function: sahara_main:854 Sahara protocol error
    21:00:35: ERROR: function: main:265 Uploading  Image using Sahara protocol failed
    Finish Download
    Start Download
    QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files (x86)\Qualcomm\QPST\bin\QSaharaServer.exe -p \\.\COM9 -s 13:C:\Users\Maras\Documents\LENOVO\k6 note\Lenovo_K53a48_S115_Q00380_20161017\Lenovo_K53_S115_Q00380_20161017\Firmware\prog_emmc_firehose_8937_ddr.mbn 'Current working dir: C:\Users\Maras\AppData\Roaming\Qualcomm\QFIL
    Sahara mappings:
    2: amss.mbn
    6: apps.mbn
    8: dsp1.mbn
    10: dbl.mbn
    11: osbl.mbn
    12: dsp2.mbn
    16: efs1.mbn
    17: efs2.mbn
    20: efs3.mbn
    21: sbl1.mbn
    22: sbl2.mbn
    23: rpm.mbn
    25: tz.mbn
    28: dsp3.mbn
    29: acdb.mbn
    30: wdt.mbn
    31: mba.mbn
    21:02:14: ERROR: function: sahara_rx_data:194 Unable to read packet header. Only read 0 bytes.
    21:02:14: ERROR: function: sahara_main:854 Sahara protocol error
    21:02:14: ERROR: function: main:265 Uploading  Image using Sahara protocol failed
    Finish Download
  • #2 16791149
    nutergsm
    Help: 1034
    Rate: 1665
    Do you connect it with the vol down and vol up buttons pressed?
  • #3 16795450
    sagem90
    Help: 22
    Rate: 85
    Yes, but I managed it. I used a newer version and it went.
