Lenovo K6 Note (K53a48) Update: How to Update with Lenovo Assistant, Find HW Code & 8-Digit SN
dzedaj2000 8322 5
  • #1 17136955
    dzedaj2000
    Rate: 37
    How to update lenovo k6 note with program? Need
    HW Code. There is a description of how to read after sn but after 18 digits and I have 8 digits SN. When I choose the phone model in the Lenovo Assistanit program, I still need to provide the HW Code where I can choose the number 10,16,18,20. How should I read HWcode after eight-digit SN?
  • #2 17137136
    Labira
    Level 4  
    Hello. The two numbers marked in a circle are HWcode. Google search will also help? Regards.
    • Lenovo K6 Note (K53a48) Update: How to Update with Lenovo Assistant, Find HW Code & 8-Digit SN hwcode_2_20160727024519.png (5.73 KB) You must be logged in to download this attachment.
  • #3 17137138
    dzedaj2000
    Rate: 37
    Unfortunately I don't have it.
    My code has eight characters with numbers and letters and no parenthesis, and only 10 characters found how to read it.
  • Lenovo serial number can be checked in phone settings
    #4 17137178
    Labira
    Level 4  
    I can also see from lenovo. I quote
    '' 10-digit format and S / N structure: 1 digit (plant code) + 1 digit (MIDH code: "D") + 8-digit serial number ''. According to what he writes there, the first 2 digits can be the code.
    Don't suggest using the battery sticker, just check your phone:
    "system information request. Settings --- Phone information --- Status --- Serial number" info from manufacturer's website.
    Alternatively, check the serial number by entering the code #### 2222 # on your phone, the sticker may not match the actual series. You can also call lenovo. There they will know for sure.
  • #5 17137179
    dzedaj2000
    Rate: 37
    SN: HA0SQHP3
  • Lenovo Smart Assistant and Wi‑Fi update steps
    #6 17137185
    Labira
    Level 4  
    1. Open Lenovo Smart Assistant (No device connected
    2. After connecting via USB, you can view device information
    3. Click: Update Rom
    4. When the ROM download is completed, the ROM will be sent to the connected device
    After the ROM update is completed, it means the ROM has been updated.
    5.Note: Updating the system may delete personal data, so make sure you have backed up your personal data before updating the system
    Installation instructions from the lenovo website.
    You have strange messages. Maybe your phone is from abroad or you don't have the latest updates installed. Your serial doesn't tell me anything.
    There is also an option to update via wifi:
    Make sure you are connected to the WLAN, and then click Settings (system settings); System (all settings); System; Information about the phone (tablet); System Update (System Updates)
    If a new software version is available, the device will prompt you to download and install it. When installing the update, do not turn off or unplug the device. The 'notifications' icon is displayed when the System Update installs updates that will restart or shut down the computer using serialization mode.
    Different operating system versions may have different menu option names.
    Different software and function versions are available for different device models. info from lenovo
