Can someone provide a schematic or pinout description of the R2 cube under the driver's seat in a Renault Scenic II?
There is no complete, reliable schematic in the thread: the found diagram does not match all cables and it also lacks a description of the central pins in the connector [#16796177] Another reply says the standard plug is connected, but the manual plug does not work [#16796318] A later comment adds that there is no R2 connector as such, only some wires pass through it [#20221752]
The discussion revolves around the request for a schematic or description of the R2 cube located under the driver's seat of a Renault Scenic II. Users share links to images and express difficulties with existing diagrams, noting discrepancies in cable designations and the lack of descriptions for central pins in the plug. Some users mention issues with the manual plug not functioning properly and inquire about installation diagrams. The conversation highlights the complexity of the wiring and the need for accurate schematics to resolve connectivity problems. AI summary based on the discussion. May contain errors.
