Renault Scenic 2 - Plug under the driver's seat incorrectly connected
Matik208 33750 10
How is the R2 connector under the driver’s seat wired in a Renault Scenic II, and could a wrong solder repair there cause diagnostic loss, a parking brake error, and a window that works all the time?
The R2 connector under the driver’s seat should be checked against the wiring diagram and the wires verified by continuity from one end of the circuit to the other, because without the original plug you have to identify each wire by measurement [#16680925][#16682204] If the connector is the seat-to-car connector, it normally carries only the seat cushion, pretensioners, seat position sensor, and possibly seat heating, so the parking brake fault and window problem are not usually caused by that connection [#16682589] The forum also identifies this under-seat plug as the central R2 connector under the driver’s seat on a 2004 1.6 petrol Scenic II [#16681829][#16707363] Since the plug was soldered, the most likely issue is that wires were swapped or misconnected there, so the practical fix is to compare every soldered wire with the diagram and test each relevant circuit rather than guessing [#16682204][#16707363]
  • #1 16680579
    Matik208
    Rate: 30
    Hi, I have scenica 2, the plug under the driver's seat has already been soldered but I suspect that someone did it wrong because
    - no diagnosis
    - there is a mistake from the manual brake
    - PT glass works permanently and not after ignition
    I would ask for a schematic of installing this plug-in if someone has one.
  • #2 16680925
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Which cube, what color, how many pins?
    Vintage car and how is the engine there?
    1216 CONTROL MODULE FOR AUTOMATIC PARKING BRAKE
    1217 ELECTRICAL MODULE FOR AUTOMATIC PARKING BRAKE
    1222 CONTROL MODULE FOR THE ELECTRIC PARKING ASSISTANCE SYSTEM
    1057 CLUTCH PEDAL SUSPECT SENSOR
    225 DIAGNOSTIC OUTLET
    1511 CONTROL OF THE LOWER SIDE ON THE DRIVER SIDE WITH TWO BACK SWITCHES
    135 ELECTRIC CONTROL ELECTRIC BLOCKING THE REAR WINDOW
    260 BOX OF FUSES AND RELAYS IN A CAB
    130 ELECTRIC CONTROL, LIFTING THE RIGHT REAR WINDOW
    131 ELECTRIC CONTROL OF THE LEFT WINDOW SUSPENSION
    201 HEIGHT RIGHT SUSPENSION LIFT
    202 SKID WINDOW SUSPENSION HEIGHT LIFT
    1337 SECURITY AND SWITCHING MODULE
    645 CABIN ELECTRICAL CONTROL MODULE
    118 ELECTRIC CONTROL MODULE FOR ABS SYSTEM
    119 ELECTRICAL CONTROL MODULE FOR AUTOMATIC GEARBOXES
    120 ELECTRONIC MODULE OF INJECTION SYSTEM
    989 CONTROL MODULE FOR ELECTRIC DISCHARGE LAMP
    997 LPG ELECTRONIC MODULE
    1094 ELECTRICAL CONTROL MODULE FOR ABS SYSTEM / TRACTION CONTROL
    • lokalizacja R2.pdf (121.62 KB) You must be logged in to download this attachment.
    • Złącze OBD.pdf (9.14 KB) You must be logged in to download this attachment.
    • Szyby tył wer3.pdf (36.45 KB) You must be logged in to download this attachment.
    • Szyby tył wer4.pdf (36.39 KB) You must be logged in to download this attachment.
    • Szyby tył wer2.pdf (36.27 KB) You must be logged in to download this attachment.
    • Szyby tył wer1.pdf (36.49 KB) You must be logged in to download this attachment.
    • Reczny wersja 2 bez cz sprzegla.pdf (19.63 KB) You must be logged in to download this attachment.
    • Reczny wersja 1 z cz sprzegla.pdf (21.63 KB) You must be logged in to download this attachment.
  • #3 16681031
    milejow
    Help: 1563
    Rate: 5148
    Wall motor control module released.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #5 16681273
    kamiloskop
    Help: 42
    Rate: 279
    Well, that's just so much crazy because as more cables the car ends in such a way. Renault Scenic 2 - Plug under the driver's seat incorrectly connected
  • #6 16681829
    Matik208
    Rate: 30
    The cube under R2 under the driver's seat is centrally.
    I do not have a plug, so it's hard to say how many pins were there and what color.
    But this is not the one on the left on the left side only under driver's photo
    Year 2004. 1.6 gasoline
  • #7 16682204
    grala1
    Help: 1495
    Rate: 5052
    Schemes that I put will match only that since there is no plug, you must now check the wires by measuring the transition between them at the beginning and end of the diagram.
    You do not have to check all, you can only those who are responsible for the elements that do not work for you.
  • #8 16682589
    milejow
    Help: 1563
    Rate: 5148
    If it is the connector that connects the seat to the rest of the car, the brake error and glass defect are not related to this connection, only the cushion, pretensioners, seat position sensor and possibly heating of the butt are connected in this connection.
    Which connector are soldered? Renault Scenic 2 - Plug under the driver's seat incorrectly connected
    As it is the R2 connector, it was possible to confuse it there. How many solder cables do you have?
    Działalność własna
  • #9 16707363
    Matik208
    Rate: 30
    Sory I did not speak. THIS is the R2 plug under the seat, not from the armchair (cushion tensioner) so not interesting. all soldered.
  • #10 16934535
    zJaWik
    You fixed these glitches - I have the same problem, there is a schematic for this?
    He shakes me as I think I'm going to have it all
    How would you say something?
  • #11 17369859
    JARZIELINA
    For me after soldering everything is ok
    Added after 3 [hours] 21 [minutes]:
    For me, February and ok
    One rear window does not work
The discussion revolves around issues with the R2 plug under the driver's seat of a Renault Scenic 2, which has been soldered incorrectly. The user reports problems including a lack of diagnostic feedback, a manual brake error, and the permanent operation of the PT glass instead of it activating with the ignition. Various responses suggest checking the wiring and connections related to the seat, as well as providing links to schematics. Some participants clarify that the connector in question is not related to the brake or window issues, while others share their experiences with similar problems and solutions after soldering.
