Renault Scenic 2 2005 - Problem with the rear windows after the R2 ankle repair
marcias 8586 3
  • #1 16841839
    marcias
    Help: 18
    Rate: 87
    The patient is Renault Scenic 2 2005 1.6 16V
    At first, the problem was the rear windows not working and the handbrake error constantly popping up. The culprit was the R2 cube under the driver's seat, after soldering it permanently (some cables fell out due to rotting during disassembly, but 99.9% of all are soldered as they should be) the problem with the manual stopped, but the rear windows started to freak out.
    Current situation:
    - Almost front window works normally
    - Left front window works normally
    - The left rear window works normally (although after soldering the R2 ankle it was ok, but after one day it was possible to open the window with the button in the driver's panel, but it closed with a button in the rear panel)
    - The right rear window does not open and, additionally manipulated by a button in the driver's panel, it opens the rear left (sic!) Window.
    What I did:
    - I checked the switch in the driver's panel - all contacts work ok, I corrected February to be sure.
    - I checked the knuckles in the driver and rear doors
    - I made sure as much as possible that the R2 cube was soldered correctly
    - Swapped rear door modules
    Generally, you can see that something was already buried in it, but I think someone gave up quickly and did not even reach R2's cube.
    Where to look Possibly someone has a wiring diagram for this car?
  • #2 16841909
    andrzej20001
    Help: 1574
    Rate: 6647
    These few cables fell out.
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    Please, just take a correction on the colors of the wires, because they don't always match.
    • Scenic_2003-.pdf (1.83 MB) You must be logged in to download this attachment.
  • #4 16851105
    marcias
    Help: 18
    Rate: 87
    Problem solved!
    I suspected 2 pairs of wires and they were actually swapped. Earlier, I swapped them places but it did not help because it turned out that the engine in the rear right door was damaged. Thanks to the scheme, I improved the beam, diagnosed the engine and everything bangla.
    Thanks for the help.
