Error & Game Crash in Call of Duty WW2: Updated Drivers - Possible Reasons & Solutions
dawid456ug 7200 9
Why does Call of Duty WW2 crash with an error even though my drivers are up to date?
The crash is likely caused by a graphics-card/driver stability issue, overheating, or an unstable GPU clock rather than a simple “outdated driver” problem [#16870518] First, make sure the game is actually running on the GTX 960M in the laptop and not on the Intel GPU [#16809252] Then use Display Driver Uninstaller (DDU) to remove the Nvidia drivers completely, install the latest Nvidia driver again, and test the card with FurMark for about 15 minutes while watching for high temperatures, artifacts, freezes, or other errors [#16870518] If it still crashes, reduce the GPU core and memory clocks by at least 100 MHz with MSI Afterburner and see whether the problem stops [#16870518] It is also worth checking whether the same issue happens in other games [#16870518]
  • #1 16809236
    dawid456ug
    Rate: 23
    Hello, when playing the game Call of Duty WW2 I get the error like in the attachment and the game turns off. All drivers are up-to-date because I checked. What could be the reason?
  • #2 16809239
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    Welcome. Enter the computer configuration. Is graphics card supported in this game?
  • #3 16809243
    dawid456ug
    Rate: 23
    I7 6700HQ processor, GTX 960m 4GB memory, 8GB RAM.
  • #4 16809252
    dt1
    Help: 7319
    Rate: 8299
    It is a laptop, so it can have two graphics cards (Intel HD and this Geforce). Are you sure the game starts on GTX960?
  • #5 16809254
    dawid456ug
    Rate: 23
    That's how it starts on this card because it is even visible in the game settings
    Added after 10 [minutes]:
    Maybe something lowering the details in the game will help, because honestly I did everything to the best I could. But apart from this error, the game runs smoothly for a few minutes and suddenly this error.
  • #6 16809447
    atomic99
    Help: 171
    Rate: 338
    @ dawid456ug Is this game original?
  • #7 16809551
    dawid456ug
    Rate: 23
    Unfortunately not. But I reduced the graphics settings and for now the game is going well, but a little pointless because on the full settings it used only half of my card's memory capacity.
    Added after 1 [hours] 38 [minutes]:
    Unfortunately the error returned :( I have no idea what causes it
  • #8 16809747
    dt1
    Help: 7319
    Rate: 8299
    In the case of crack games, it is difficult to conduct any diagnostics. Stolen software works differently, so further considerations do not make sense.
    Based on https://www.elektroda.pl/rtvforum/topic2367809.html p.7 the topic is closed.
  • #9 16820376
    RADU23
    Help: 2428
    Rate: 1732
    The author declared that he bought the original game and the same error continues.
    On this basis, I unlock the topic.
  • Use DDU, FurMark, and a 100 MHz GPU underclock
    #10 16870518
    Piterixos
    Help: 38
    Rate: 56
    http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
    Download this program and uninstall the Nvdia drivers using it, then download the latest and install.
    Download Furmark, run for 15 minutes, enter temperatures after 15 minutes, or when something happens, such as freezing the screen, artifacts etc.
    Download the MSI afterburner and reduce the clock speed of the core and memory card by at least 100 Mhz, write if it changed something.
    There is no problem in other games?
The discussion revolves around an error and game crash issue in Call of Duty WW2 experienced by a user with a laptop featuring an i7 6700HQ processor and GTX 960m graphics card. Initial suggestions included verifying if the game is utilizing the dedicated GPU and lowering graphics settings. The user confirmed the game runs on the GTX 960m but still encounters crashes despite reducing settings. The conversation shifted to the legitimacy of the game, with the user initially indicating it was not original, but later clarifying that they purchased the original version. A solution was proposed involving the use of Display Driver Uninstaller to remove NVIDIA drivers, followed by reinstalling the latest drivers and testing the GPU's performance with Furmark and MSI Afterburner to adjust clock speeds. The discussion highlights the challenges of diagnosing issues with cracked games and emphasizes the importance of using original software for reliable performance.
