Need Help Deciphering FFD 450 TDK BS? Join Our Technical Electronics Discussion Forum
rejak 2040 3
  • #1 1716879
    rejak
    Rate: 21
    I can not decipher such a sign
    FFD
    450
    TDK
    BS
    This inscription is on the casing of this something that has three legs.
    Maybe someone knows what transistor and optional substitutes are. :|
  • #2 1718302
    SONIAK12
    Help: 76
    Rate: 21
    And what does it work in and what does it do more ????
    Regards, Sonia
    Added after 6 [minutes]:
    see it: http://boss.iele.polsl.gliwice.pl/pdf/International_Rectifier/irfk2d450.pdf
    ewentulanie patches in the search engine http://elenota.iele.polsl.gliwice.pl
    d450 password
    because it seems to me that it will be some IRF
    but you have to specify where it works and what this element does
  • #3 1718480
    andy_o
    Help: 22
    Rate: 27
    Is it really about tranzysor? This designation may also apply to the 450kHz ceramic filter.
    andy_o
  • #4 1720215
    rejak
    Rate: 21
    Everything indicates that it is IRF, it's stupid to me that I did not fall into it anymore. Thank you very much for your help
