Identify this electronic component by unknown manufacturer's logo
351 13
How can I identify an unknown SMD electronic component by its logo and marking codes?
It appears to be a TVS diode, with the stripe marking indicating the cathode and the SMD codes LE/LP matching unidirectional TVS parts; LE was found as a 12 V breakdown device and LP as a 16 V device [#21660205][#21660206] The marking on the part also includes what looks like a date/manufacturing code such as 948 [#21660205] A later reply identified the logo as Diodes Inc. based on a datasheet, though the same poster noted Diodes Inc. had initially said it was not theirs, so it may be an older part or counterfeit [#21660210][#21660214]
  • #1 21660203
    Tom Blough
  • Suggests diode identification via IV tracer and manufacturer list
    #2 21660204
    Joe Wolin
  • #3 21660205
    Pieter Kruger
  • TVS diode likely clamps 12–16 V lamp supply
    #4 21660206
    Tom Blough
  • #5 21660207
    Pieter Kruger
  • #6 21660208
    Steve Lawson
  • Stripe does not always mark the cathode
    #7 21660209
    Steve Lawson
  • #8 21660210
    Teresa Mueller
  • #9 21660211
    Todd Hayden
  • #10 21660212
    Nauman Chughtai
  • #11 21660213
    Steve Lawson
  • #13 21660215
    Nauman Chughtai
  • #14 21660216
    Todd Hayden
The discussion centers on identifying an electronic component marked with an unfamiliar manufacturer's logo, suspected to be a diode or a transient voltage suppressor (TVS) diode based on its cathode line marking and circuit context. The component's markings include codes such as "LE" and "LP," which correspond to unidirectional TVS devices with breakdown voltages of approximately 12V and 16V, respectively. The circuit involves three white LEDs with a combined forward voltage near 9.6V, powered by a 16V DC supply regulated by a constant current driver, supporting the TVS hypothesis. Various contributors suggest using IV tracing to characterize the device and reference comprehensive diode manufacturer lists and logo archives for identification. Some speculate the logo might belong to Diodes Inc., though this remains unconfirmed, with suggestions of possible counterfeit or obsolete markings. Other brands like Hyundai and Unitrode are mentioned as potential matches. The discussion also highlights the importance of verifying polarity markings, as the cathode line is not always definitive. Resources such as datasheet archives and logo databases are recommended for further investigation.
TL;DR: Forum sleuthing points to a unidirectional TVS diode; one user “turned up eight manufacturers” sharing LE/LP SMD codes. “Turned up eight manufacturers.” [Elektroda, Tom Blough, post #21660206] Why it matters: This FAQ helps you identify mystery SMD diodes/TVS parts, decode markings, and avoid polarity and replacement mistakes—fast.
What is this part most likely?
It’s most likely a unidirectional TVS diode in an SMD package. The LE and LP top marks align with 12 V and 16 V breakdown parts. The stripe suggests the cathode orientation in typical TVS/diode markings. Use a meter or IV tracer to confirm before replacement. [Elektroda, Tom Blough, post #21660206]
What do the SMD codes “LE” and “LP” mean on this device?
In this thread, LE corresponded to an Approx. 12 V breakdown unidirectional TVS diode, and LP to an Approx. 16 V version. These codes appear across multiple vendors, so verify electrically and by package outline before substituting. “Turned up eight manufacturers” using the same codes, so cross-check datasheets. [Elektroda, Tom Blough, post #21660206]
Does the stripe always mark the cathode?
Do not assume it always marks the cathode. One engineer reported parts where the stripe marked the anode, leading to reversed installs. Confirm with a multimeter’s diode test: forward direction should show a junction drop; reverse should read open. “They had neglected to try reversing their probes.” [Elektroda, Steve Lawson, post #21660209]
How can I tell if the logo is Diodes Inc?
Compare the printed logo against a known Diodes Inc logo shown in a related datasheet image. If the graphic styling matches, you may have a Diodes Inc device or an older/cross-marked variant. Always verify with electrical tests and package dimensions before ordering replacements. [Elektroda, Todd Hayden, post #21660214]
Did Diodes Inc confirm the part as theirs?
A user contacted Diodes Inc and reported the company said it wasn’t theirs. That can happen with legacy marks, private labels, or counterfeits. Proceed by validating function and ratings rather than relying solely on the logo. Keep notes for future cross-referencing. [Elektroda, Nauman Chughtai, post #21660212]
What does a mark like “948” mean on the package?
It’s a date/lot code. In this context, “948” was interpreted as manufacturing year and week (YWW/YYW). Use it to estimate device age and to track batches in repairs. Combine with the top code and package to narrow datasheet searches. [Elektroda, Pieter Kruger, post #21660205]
How do I characterize an unknown TVS/diode quickly?
Use this 3‑step check: 1. Inspect top code, logo, and stripe. 2. Measure with a multimeter and, if available, an IV tracer to see knee voltage and polarity. 3. Compare results with candidate datasheets by code and package. This triangulates function and safe substitutes. [Elektroda, Joe Wolin, post #21660204]
Do the circuit measurements support it being a TVS?
Yes. The lamp module measured 16 VDC without load and 9.4–9.6 VDC with three white LEDs, matching a constant-current driver and a clamp device nearby. That behavior aligns with a protective unidirectional TVS across the LED string. The data narrows viable breakdown ratings. [Elektroda, Tom Blough, post #21660206]
Could this TVS fail if an LED opens?
Yes. If an LED in the string goes open, the driver may raise voltage and the TVS can conduct hard, overheating and failing. Placement and upstream limits decide survivability. “I am concerned that the TVS will be destroyed if any of the LEDs go open circuit.” [Elektroda, Pieter Kruger, post #21660207]
How do I test diode polarity with a multimeter?
Use the diode-test mode. Touch red to anode and black to cathode to read a forward drop. Reverse the probes; it should read open. If it reads the opposite, the stripe may mark anode on that family. Always verify both directions before committing. [Elektroda, Steve Lawson, post #21660209]
Where can I search unknown logos and SMD codes?
Check curated logo and code indexes such as the integrated-circuit logos archives and SMD code lists. Cross-match the graphic, then validate by electrical tests and package dimensions. Keep screenshots of close matches to build your own lookup library. [Elektroda, Steve Lawson, post #21660213]
What is a TVS diode in plain terms?
A TVS (transient-voltage-suppressor) diode clamps voltage spikes to protect circuits. Unidirectional TVS parts resemble diodes and have a breakdown rating, such as Approx. 12 V (LE) or 16 V (LP). They conduct briefly during surges, then return to high impedance. [Elektroda, Tom Blough, post #21660206]
What is an IV tracer and why use it here?
An IV tracer plots current versus voltage. It reveals forward direction, knee voltage, and clamping behavior. For unknown diodes/TVS parts, it quickly distinguishes zeners/TVS from rectifiers and helps pick a safe substitute part number and rating. [Elektroda, Joe Wolin, post #21660204]
