[Solved] Opel Zafira 1.8 A18XER: Engine Wavers, Stalls & Steering Lock Issues at Low Temperature
mikavel 30234 17
Why does my Opel Zafira 1.8 A18XER idle waver and sometimes stall when cold after I press the clutch, while it works normally once the engine is warm?
Start by checking and cleaning the electronic throttle body, then perform a proper throttle adaptation with Opel-specific diagnostics, because a dirty or sticking throttle can cause cold idle wavering and stalling when you press the clutch [#16813197][#16813205][#16813249][#16850817] If that does not fix it, read live parameters while driving and inspect the intake for vacuum leaks, the EGR valve, and the MAF sensor, since a lean-mixture P0171 fault was present and the 1.8 engine was noted for MAF problems [#16814319][#16867699][#16832334][#17002956] One reply also mentioned a possible ECU hybrid fault, but only as a later fallback after the air/throttle checks [#16838746]
  • Cold idle control fault causing stalling and rev flare
    #1 16812300
    mikavel
    Rate: 150
    In Zafira 1.8 (A18XER) sometimes just after firing (only after a few hours of parking) for several / several seconds the engine wavers at revolutions in the range of 1000-1100.
    In addition, recently, when changing the gear (usually 2, 3, 4), after pressing the clutch, the revolutions are about 500-1500 revolutions and return to their position (800-900). Another thing related to this, when driving, and exactly when commuting, for example, to intersections or lights, after removing the leg from the gas and pressing the clutch, the engine goes out, after the previous rotation of the rotation.
    The engine goes off sporadically and only if the engine is not heated to 90 degrees. On the road it is dangerous because after closing the engine the steering wheel is blocked during light traffic.
    After heating the engine to 90 degrees, the above-described problems do not occur.
    I do not know if these few second wavy turns have something to do with the speed of rotation when changing gear or the engine goes out, but I wrote it, because maybe someone will give me a hint and help me locate the fault.
    I will add that the car has the BRC gas system installed, but the above-mentioned problems occur both as the car drives both on the gasoline itself and on lpg.
    Is anyone able to help you locate the problem?
  • #2 16813197
  • #3 16813205
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    bubus1769 wrote:
    It's worth it at the beginning
    At the very beginning it is worth to do good diagnostics dedicated to Opel hardware.
    The result of this action can explain a lot about the turnover.
    Of course, to interpret the result of tests is necessary someone who has a concept and knows what values are correct.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #4 16813249
  • #5 16814319
    mikavel
    Rate: 150
    I have an interface dedicated to opel and it only shows error P0171, but I had this error a few months earlier, before the symptoms appeared as above.
    I do not know too much about parameters, and I do not even have anything to compare with.
    I have heard that the throttle can be sated or a stepper motor, but I can not locate it in my engine.
    Next week I will have to take down the throttles and clean it
  • #6 16814579
  • #7 16814775
    mikavel
    Rate: 150
    bubus1769 wrote:
    In this engine, there is no such thing as a crotch because the throttle is electronic, the error about the sub-mixture appeared on gas and gas or only on gas?
    the mistake is all the time and on gas and gas (even if I drive only on gas for a long time)
  • #8 16815043
  • #9 16832274
    mikavel
    Rate: 150
    Do you need to adapt after cleaning the throttle?
  • #10 16832334
    andrzej20001
    Help: 1578
    Rate: 6669
    In 1.8 there was a problem with the mass flowmeter. Look for faq on this topic
  • #11 16834183
    mikavel
    Rate: 150
    Yesterday I cleaned the throttles, I started the car (without driving) and everything was going on, today I'm going to the streets and it turned out that it is not good. During the ride, after each pressing of the clutch, or throwing it in play, turns rotate, first fall to about 1000 revolutions and immediately jump to the level of 2000 - 2500 and sometimes up to 3500 revolutions. After a few seconds of waving at higher revolutions, it returns to around 800. Immediately after starting the engine, even as it stalls in the place, everything is ok with revolutions, the problem starts as I go a few meters, then even at low speed the spins jump.
    I hooked it to the computer and showed error P2119, which was deleted on the engine and no longer shows.
    Flowmeter efficient.
    Did I do something wrong while cleaning the throttle, or is it some other fault or gets "left" air? Maybe you need to do a throttle adaptation? Any idea?
  • #12 16838746
    CameR
    Help: 1139
    Rate: 3272
    A hybrid ECU of the engine may be damaged.
    It will locate the fastest and easiest way by "replacing" for the whole set (ECU, immo loop, transponder).
    You will not even need to program anything (at least for the test)
    This way you will eliminate the very common fault in Opel and you will be able to focus on the remaining elements of the engine.
    ABC KOM
  • #13 16850817
    mikavel
    Rate: 150
    It will update the topic a bit.
    Last week I was on the site to make adaptations of the throttle and to see if something else might be wrong.
    To my surprise, the site did not find a mistake in my car and according to them is OK! :)
    After cleaning the throttle and after its adaptation and driving week, the situation looks like this:
    I start the car, no waving, whether on a cold or warm engine. All you need to do is move and, as I put on the play, the revolutions wave to 1500, sometimes up to 2000 and 3000 revolutions, until the car stops, then it drops to about 800.
    I will add that such symptoms came out after cleaning the throttle, before there was nothing like that.
    Will it be a damaged ECU, or some leak in the system (I have no loss of power while driving)?
  • #14 16867699
    bubu1769
    Help: 1177
    Rate: 2374
    It remains probably only reading the parameters while driving.
  • #15 17002836
    siczek77
    I have the same problem I found out that this is a stepper motor that occurs with the X18XE1 throttle. 1500 price for a new 200-300 dose.
    As for the ACU, it is rather a good new ACU about 1500 plus adaptation with an immobilizer at not easy to better complete a set to recognize the immobilizer
    You can search for alegro
  • #16 17002956
    mtd
    Rate: 19
    Vacuum tight lines? If there is an EGR valve, check it.
  • #17 18110599
    Petrer30
    I don't know, but it is worth assuming that this wave may also result from the shaft position sensor. If the car is stationary and nothing is happening, it's ok. But if it moves and waves, this shaft sensor can be.
    Moderated By gulson:
    | Report: harmful advice
  • #18 18116484
    mikavel
    Rate: 150
    The problem practically solved itself, the car was running, the waviness was less and less, until after about 3-4 months it disappeared completely. I don't know what was the cause of the waving, maybe the throttle had to tune after cleaning. Even the mechanics could not find the problem, so the problem solved itself :) .
The discussion revolves around issues experienced with the Opel Zafira 1.8 (A18XER) engine, specifically concerning engine wavering, stalling, and steering lock at low temperatures. Users report that the engine exhibits unstable revolutions (1000-1100 RPM) shortly after starting, particularly when cold. Symptoms include sporadic stalling when the engine is not warmed up, and erratic RPM fluctuations during gear changes. Suggested diagnostics include checking the throttle body for cleanliness and functionality, as well as examining the mass airflow sensor and potential vacuum leaks. Users also mention the possibility of a faulty ECU or stepper motor affecting performance. After cleaning the throttle, some users experienced temporary improvements, but issues persisted, indicating further investigation is needed.
TL;DR: Owners report idle flare to 3,500 rpm and stalling; one case self-resolved after 3–4 months. “Do good diagnostics dedicated to Opel hardware.” [Elektroda, CameR, post #16813205]
Why it matters: This FAQ helps Opel Zafira 1.8 A18XER drivers quickly pinpoint low‑temperature stalling, wavering idle, and steering assist loss.
What causes wavering idle or cold stalling on the A18XER?
A dirty or sticky electronic throttle plate often causes wavering idle and cold stalling. Contamination alters airflow at small openings, upsetting fuel trim until the engine warms. Cleaning the throttle body is a first step, followed by adaptation. “The collapsed and sticky throttle can cause such symptoms.” [Elektroda, 3048296, post #16813249]
Does the A18XER have a stepper motor/idle control valve?
No. The A18XER uses an electronic throttle body. There is no separate idle air control (stepper) motor. Idle control happens via the throttle actuator that the ECU commands. This matters when sourcing parts and diagnosing post‑cleaning adaptation issues. [Elektroda, 3048296, post #16814579]
What does P0171 mean here, and does LPG change the diagnosis?
P0171 indicates a lean mixture. In the thread, it persisted on both petrol and LPG, so start with unmetered air, throttle cleanliness, MAF accuracy, and adaptation checks rather than blaming LPG calibration alone. Clear the code only after fixing root causes. [Elektroda, mikavel, post #16814775]
After cleaning the throttle, I got P2119 and rpm flares—what happened?
P2119 points to throttle actuator range/performance. Cleaning can shift the blade’s learned rest position. Perform throttle adaptation with Opel‑capable diagnostics, then road‑test. Expect temporary rpm flare to 2,000–3,500 rpm until values relearn. If it persists, recheck for air leaks. [Elektroda, mikavel, post #16834183]
Do I need to adapt the throttle after cleaning on this engine?
Yes. After cleaning, adaptation aligns the ECU’s expected throttle positions with the actual plate. One user reported adaptation was done, followed by a week of driving and continued monitoring. Always adapt, then log live data during a drive. [Elektroda, mikavel, post #16850817]
What’s the best first diagnostic step for Opel Zafira 1.8 A18XER?
Use Opel‑dedicated diagnostics and read live parameters at idle and while driving. “Do good diagnostics dedicated to Opel hardware.” Check fuel trims, throttle angle, MAF g/s, and rpm during clutch‑in events. Capture data during symptom onset. [Elektroda, CameR, post #16813205]
Could the mass air flow (MAF) sensor be the culprit on the 1.8?
Yes. Contributors note known MAF issues on 1.8 engines. Verify with live data and a controlled MAF unplug test only if safe, then compare trims. Replace the MAF only after confirming readings deviate under load or at idle. [Elektroda, andrzej20001, post #16832334]
Could the engine ECU be at fault, and how do I test it quickly?
A failing hybrid ECU can cause unstable throttle control. A quick test is swapping in a matched set (ECU, immo loop, transponder) to rule it out without programming. If symptoms vanish, investigate ECU repair or replacement. [Elektroda, CameR, post #16838746]
Should I inspect vacuum lines or EGR for idle surge and stalls?
Yes. Air leaks skew the mixture lean and can trigger P0171. Check all vacuum hoses for tightness and cracks. If equipped, confirm EGR isn’t stuck open. Fix leaks before recalibrating anything. [Elektroda, mtd, post #17002956]
Why does the steering feel locked when the engine dies at intersections?
When the engine stalls, hydraulic/electric power assist stops. The wheel suddenly feels heavy or “blocked,” especially at low speeds. Restore stable idle and prevent stalls to keep steering assist active in traffic. [Elektroda, mikavel, post #16812300]
How do I clean the A18XER throttle body safely and avoid new faults?
  1. Remove the intake duct; keep the throttle connected electrically.
  2. Gently clean the plate and bore with throttle cleaner; do not force the blade.
  3. Reassemble, then perform throttle adaptation and road‑test with logs. If rpm flares continue, check for air leaks. [Elektroda, mikavel, post #16834183]
What is a MAF sensor, in simple terms?
The mass air flow (MAF) sensor measures incoming air so the ECU can meter fuel correctly. Faulty readings cause lean or rich conditions, surging, and codes such as P0171. Verify before replacement using live data. [Elektroda, andrzej20001, post #16832334]
Can this problem go away on its own after cleaning and adaptation?
Yes. One owner reported the wavering diminished over time and fully disappeared after about 3–4 months, likely as the ECU relearned. Monitor live data during the period to ensure trims normalize. [Elektroda, mikavel, post #18116484]
Any reported parts costs or alternative approaches from the thread?
One user quoted about 1,500 for certain replacements and suggested buying a complete ECU/immobilizer set for easier recognition. Always verify engine applicability (A18XER uses electronic throttle). Cross‑check part numbers before purchase. [Elektroda, siczek77, post #17002836]
