Volvo FH 2006 - Automatic error MID 223 PSID 9 FMI 12 does not work
TomasAGC 40530 12
Why does a Volvo FH only work in manual mode and show MID 223 PSID 9 FMI 12 instead of automatic gear selection?
MID 223 PSID 9 FMI 12 usually points to a selector/joystick wiring fault: an open circuit, short circuit, missing signal, or two sensor signals active at once, which can leave the transmission in manual only [#16814163] [#17245593] Check the electrical installation first, especially the harness section that moves when the cab is lifted and the cable path from the cab to the frame [#16814163] [#16817219] Also inspect the selector/joystick connectors, especially the plug under the driver's seat and the transition at the bottom of the seat, because broken wires there were reported and repaired by soldering or replacing them [#17798685] The replies point to a selector-side problem rather than a gearbox problem [#17798685]
  • #1 16814135
    TomasAGC
    Help: 13
    Rate: 210
    The problem with Volvo FH is that only the gears selected manually after switching to A no gear work the accelerator pedal works in the gearbox and brakes no errors. Only what is active is MID 223 PSID 9 FMI 12
  • #2 16814163
    Foxtrott
    Help: 253
    Rate: 944
    Volvo FH 2006 - Automatic error MID 223 PSID 9 FMI 12 does not work MID 223 PSID 9 FMI 12
    Incorrect wiring (break or short circuit)
    No sensor signal
    Two or more sensors are active at the same time.
    Generally, electrical installation needs to be checked, especially on "breaking".
  • #3 16814232
    TomasAGC
    Help: 13
    Rate: 210
    And the jack joystick itself may be damaged? Because everything works manually.
  • #4 16814363
    darfur5
    Help: 267
    Rate: 1716
    It is thanks to this error that you only have the manual. If you had everything working, you would have both.
  • #5 16816406
    TomasAGC
    Help: 13
    Rate: 210
    No sensor signal
    Where is this breaking?
  • #6 16817219
    Foxtrott
    Help: 253
    Rate: 944
    You lift the cabin = you break the cabin - the place where the beam passes from the cabin to the frame.
  • #7 17245005
    pabloo88
    Hello, I have the same problem, only that the driver came down to the square on the manual. And now everything works. And I don't know what to look for and think about it
  • #8 17245593
  • #9 17798685
    Piterr2212
    Rate: 27
    I warmly welcome.
    Please check the joystick wiring, the error describes an open circuit or a faulty component.
    Do not look in the frame (On breaking) another error if the break in the frame.
    There is clearly a selector error, not a gearbox.
    Please check the transition on the plug at the bottom of the driver's seat. [Img-0] Volvo FH 2006 - Automatic error MID 223 PSID 9 FMI 12 does not work Volvo FH 2006 - Automatic error MID 223 PSID 9 FMI 12 does not work
    I personally solder the wires.
  • #10 17820786
    esterr
    Rate: 12
    I have the same problem as in the subject. MID 223 PSID 9 FMI 12 at VOLVO FH 2011 / 460km - manifested by the lack of the AUTO mode on the selector. It is MANUAL and only forward.
    Please advise what else to look for.
    So far I have checked both plugs for the selector (under the selector and under the seat) - they were generally clean but I secured them with WD40.
    In addition, I tried to swap the K5 relays (maybe it got hung up). Unfortunately, nothing helped?
    Engine and transmission system - NO FAULTS.
    Apparently, under the panel with fuses are some controllers that route the signal - can it be ???
    Thank you in advance for your answer.
  • #11 18201880
    Adipoznan1
    Rate: 18
    Hello, did someone manage to solve the problem in a different way than the plug next to the violet?
    I have everything with the plug and the error is still ...
  • #12 20490077
    ganizaniselemani0
    Rate: 10
    Thanks to you piter2212..it worked..salute..you're a life saver
  • #13 21770887
    konradwantusiak
    In my case, the cable under the seat was broken, and I fixed a few more in the process.
Volvo FH automatic transmission fault MID 223 PSID 9 FMI 12 causes loss of AUTO mode and leaves only manual gear selection, while accelerator, gearbox and brakes otherwise operate normally. The discussion identifies the fault as a selector/joystick wiring problem rather than a gearbox defect, typically an open circuit, short circuit, broken wire, or two selector sensors active at the same time. Suggested checks focus on the gear selector joystick, its connectors under the selector and under the driver’s seat, and the wiring harness where it flexes when the cab is tilted, especially the transition point near the seat and cab-to-frame area. Reported fixes include repairing broken wires and soldering damaged connections in the selector harness.
TL;DR: For Volvo FH (e.g., 2006–2011), MID 223 PSID 9 FMI 12 points to 3 likely causes and disables AUTO; “Generally, electrical installation needs to be checked, especially on ‘breaking’.” [Elektroda, Foxtrott, post #16814163]
Why it matters: This FAQ helps Volvo FH owners and techs quickly restore AUTO shifting by targeting the real fault, not the gearbox.
What does MID 223 PSID 9 FMI 12 mean on a Volvo FH?
It flags a gear selector circuit fault. Typical causes are an open or short, missing sensor signal, or two selector sensors reading simultaneously. AUTO mode is inhibited until the circuit fault is cleared. “Generally, electrical installation needs to be checked, especially on ‘breaking’.” [Elektroda, Foxtrott, post #16814163]
Why does my FH only shift manually when this code appears?
The transmission controller disables AUTO if it detects a selector fault. Owners report manual still works, while AUTO vanishes, sometimes with forward-only movement logged by one case. This behavior comes directly from the selector error, not the gearbox. [Elektroda, darfur5, post #16814363]
Where does the wiring usually break?
A frequent failure point is the harness that flexes when you tilt the cab, at the cab-to-frame pass-through. Inspect the loom and strain-relief there for cracked insulation or pulled pins. Check continuity through the bend while moving the cab. [Elektroda, Foxtrott, post #16817219]
Which connectors should I check first?
Check two places: the plug directly under the selector and the multi-pin connector under the driver’s seat. Clean, reseat, and inspect for backed-out pins or stretched conductors at both locations. [Elektroda, esterr, post #17820786]
How do I fix the under-seat plug issue? (3 quick steps)
  1. Unplug the under-seat connector and inspect each pin and wire for breaks.
  2. Repair breaks; many owners solder and heat-shrink the conductors.
  3. Reseat the plug firmly and clear codes; test AUTO. [Elektroda, Piterr2212, post #17798685]
Could the joystick/selector itself be faulty?
Yes. The fault points to the selector side. A defective selector or its internal sensors can cause an open-circuit or dual-sensor state. Verify wiring first, then substitute a known-good selector if needed. “There is clearly a selector error, not a gearbox.” [Elektroda, Piterr2212, post #17798685]
Does swapping the K5 relay help with this code?
One owner tried swapping K5 relays with no change. That suggests the issue is not relay-related but in the selector wiring or sensors. Focus on connectors and harness integrity before relay diagnostics. [Elektroda, esterr, post #17820786]
How can I check if two selector sensors are active at once?
Monitor the selector’s signal lines while moving through positions. The controller flags a fault if two position sensors read active together. Inspect wiring for shorts between signal lines that could tie channels. [Elektroda, Anonymous, post #17245593]
Is the gearbox or engine at fault here?
Evidence from owners shows no engine or transmission faults when this code appears. The problem resides in the selector circuit, not internal gearbox mechanics. Fixing wiring restored normal operation. [Elektroda, esterr, post #17820786]
WD-40 made no difference—what next?
Cleaning alone may not solve fractured conductors. After cleaning, perform a tug test and continuity test on each selector wire. Repair any broken or high-resistance paths to restore AUTO. [Elektroda, esterr, post #17820786]
What do experienced techs recommend checking first?
Follow the selector circuit. Inspect for incorrect wiring, missing sensor signal, or simultaneous sensor activity. “Generally, electrical installation needs to be checked, especially on ‘breaking’.” Prioritize flexible sections and connectors. [Elektroda, Foxtrott, post #16814163]
Has anyone confirmed an under-seat cable break as the fix?
Yes. A recent owner reported a broken cable under the seat and fixed several more during repair. Restoring conductor integrity resolved the issue. [Elektroda, konradwantusiak, post #21770887]
My truck had the code, then everything worked again—should I still inspect it?
Yes. An intermittent manual-only episode was reported by another owner. That behavior indicates a marginal connection that could recur under vibration or cab tilting. Inspect and secure the wiring now. [Elektroda, pabloo88, post #17245005]
Do accelerator and brakes show faults with this error?
Owners noted accelerator response and brakes remained normal while the transmission stayed in manual. That supports a localized selector circuit issue rather than a broader system failure. [Elektroda, TomasAGC, post #16814135]
What basic tools help with this repair?
Use contact cleaner, small picks for terminals, heat-shrink, and a soldering iron if you choose permanent wire repair. Many owners report success after soldering damaged conductors. [Elektroda, Piterr2212, post #17798685]
