[Solved] Volvo FH Starter Not Spinning: Address Gearbox Errors MID 130 PID/SID/PPID & FMI 13 Solutions
Kaszpirowski2 12216 7
  • #1 17166579
    Kaszpirowski2
    Rate: 10
    Volvo does not turn the starter with errors in the gearbox
    mid 130 pid 33 fmi 13
    mid 130 pid 31 fmi 13
    mid 130 pid 32 fmi 13
    mid 130 sid 253 fmi 13
    mid 130 ppid 10 fmi 13
    mid 130 ppid 51 fmi 13
    mid 130 ppid 11 fmi 13
    Active errors
    What to do to make the car start.
  • #2 17166674
    kkknc
    Help: 1916
    Rate: 6721
    Fix it.
    You have a description of the errors on the web.
    Clutch actuator position. These are the first 3 mistakes.
    The others are the gear selector position. And clutch position. All values out of calibration range. Moreover, each of these errors prevents the engine from starting. If so and they popped up at once, I have a bunch to check.
  • #3 17168805
    Kaszpirowski2
    Rate: 10
    What beam of sensors in the i-shift gearbox
  • #4 17168853
    kkknc
    Help: 1916
    Rate: 6721
    Well, not the tail lights. Harness and power.
  • #5 17168908
    Kaszpirowski2
    Rate: 10
    Dude, you don't really know Volvo repair.
    The box has electronics on the selector and the sensors are connected to the electronics and not the cables to the cabin, although a pair of wires comes to the box, but there is communication with the boxes. Tomorrow I will replace the electronics because all sensors cannot be out of range.
  • #6 17169042
    kkknc
    Help: 1916
    Rate: 6721
    TCM communicates with GSCM 8 wires and no, and I write this. But do as you like.
  • #7 17169389
    Kaszpirowski2
    Rate: 10
    But you yourself write that it communicates, there should be a problem with communication, not with sensors.
  • #8 17170503
    Kaszpirowski2
    Rate: 10
    Added after 16 [hours] 23 [minutes]:
    Replacing the electronics on the box helped the car drives.
    Thank you for your help.
The discussion revolves around a Volvo FH truck that fails to start due to multiple gearbox-related error codes, specifically MID 130 with various PID/SID/PPID and FMI values indicating issues with the clutch actuator and gear selector positions. The errors suggest that calibration issues are preventing the engine from starting. A user highlights the importance of the electronics in the i-shift gearbox, indicating that communication problems may exist rather than sensor failures. Ultimately, replacing the electronics resolved the issue, allowing the vehicle to operate normally.
