Lumia 640 Glass/Touch Replacement: Procedure, LOCA/OCA Glue & Finding Digitizer
KamGr 2874 4
  • #1 16815919
    KamGr
    Help: 77
    Rate: 203
    Has anyone replaced the touch / glass in this model?
    If so, what does it look like when it comes to combining fast with touch?
    Is it LOCA or OCA glued?
    I am asking because I am looking for a digitizer and I cannot find it. They're fast everywhere.
    DejoDejo
    Help: 35
    Rate: 75
    The glass is separate, the touch is welded to the display. Without skill and the right tools, changing the glass itself will be very difficult ;)
  • #3 16816001
    KamGr
    Help: 77
    Rate: 203
    Oh, that is, the touch is in the display and I unstick the glass itself and replace it, I understand. Only now is the display like IPS or Amoled? Because I don't know if I need to glue LOCA or OCA?
    It does not matter anymore, I can see that IPS is there, that is, OCA must be glued.
  • #4 16822635
    pajeczak
    Rate: 11
    For this model, full sets are cheap, so I do not know if it is worth replacing the glass itself.
    bogdan2491
    Help: 52
    Rate: 97
    Glued on OCA, IPS display. Generally, if you have both technologies, it is better to glue everything on OCA
