Corsa C 1.2 75KM 2002 (246,000 km) - What Oil Type, Dipstick Levels & When to Drain?
MrDoimer 9768 3
  • #1 16817930
    MrDoimer
    Help: 271
    Rate: 125
    I bought a toy car as in topic 1.2 75KM 2002. covered 246,000 km.
    What oil is it? I currently have 3/5 on an oil dipstick, and I don't know what was poured before. I can wait until I have min. and pour in as needed or oil needs to be drained?
  • #2 16817944
    Ireneo
    Help: 747
    Rate: 2472
    The rule is that if you do not know when you change it, you change it when you buy it, the cost is small. Funnel 10W40
  • #3 16818051
    yacko88
    It will be best to change the oil for a new one
    With the aforementioned mileage, unless the meter was moved back, I would use semi-synthetic oil, best dedicated to Corsa C 1.2 16V (2000 - 2004) Liqui Moly MoS2 Leichtlauf Super 10W-40 catalog number 2184 3L lubrication capacity
  • #4 16828736
    MrDoimer
    Help: 271
    Rate: 125
    Thank you for your answer.
    yacko88 wrote:
    semi synthetic oil best dedicated to Corsa C 1.2 16V (2000 - 2004) Liqui Moly MoS2 Leichtlauf Super 10W-40
    The only question is whether it is worth the money for such a car?
    Ew. something cheaper could you recommend?
    @Edit:
    However, the oil bought above.
    Thank you for your help.
