Opel Corsa C 1.2L 75km 2000 Gasoline Engine - Best Oil Type, 220,000 Mileage, Previous Cast?
Fifiopel256 50547 12
What oil should I use in an Opel Corsa C 1.2 gasoline engine with 220,000 km mileage when I do not know what oil was used before?
Use an oil that meets ACEA A3/B3; in this thread, viscosity is treated as secondary to the required quality class. [#16674707] The most common recommendation is 10W-40 semi-synthetic, while 5W synthetic was also mentioned as acceptable. [#16672762] Because the previous oil is unknown and the mileage is high, semi-synthetic was considered the safer choice than mineral oil. [#16673576] Another reply says the engine is not suitable for mineral oil and that modern oils are fine even at high mileage. [#16673738]
  • #1 16672755
    Fifiopel256
    Hello, what oil to choose for the car opel corsa c gasoline engine 1.2 liters, 75km, mileage 220,000, year 2000. I have a problem because I do not have information on what type of oil cast was before. I am asking for help, greetings.
  • #2 16672762
    leonov
    Help: 1039
    Rate: 2248
    I would use 10W (semi-synthesizer), but the 5W synthesizer might as well.
  • #3 16672764
    Fifiopel256
    I once heard that it was better to go with better oil for worse. Is not it worth thinking about mineral oil with such a course? If pol syntetyk is what company?
  • #4 16672785
    leonov
    Help: 1039
    Rate: 2248
    Such "formerly" opinions were "not pouring better oil after a mineral because it rinses the engine and unsealed engine", but it was at a time when the quality of mineral oil was very poor, now even mineral oil should not create carbon deposits in the engine.
    As for the brand, it will not make much difference.
  • #5 16673576
    zed71
    Help: 13
    Rate: 185
    thoroughly semi-synthesized - 10-40 (regardless of which companies would not be counterfeit (eg castrol or mobil 2000) but not a lotus (I used to get burned on the lotus and heartily advise against it) Do not look at the mileage - I have a car with a mileage of over 240 thousand and pouring castrol 0w40 from the news - just do not know what was flooded earlier in your car and safer will be semi-synthesizer.
  • #6 16673738
    wichurewicz
    Help: 7
    Rate: 326
    It was at the time of Polonez and Fiat 125p, unfortunately myths still linger in the nation. The engine is unsuitable for mineral oil (i.e., almost all currently), it will not work well even if it runs above the psychological barrier of 200k km.
    When I was not sure what was injected into the engine earlier, I used a Millers lotion and switched to 5W30 synthetic oil, recommended by the car manufacturer. The rinse should be poured into a warmed up engine like oil, start the engine for 10-15 minutes and decant the old oil with the rinse aid. I have not noticed any negative symptoms after this procedure.
  • #7 16674683
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    280 thousand of which 180,000 on Valvoline MaxLife 10W40. Engine 1.6 16v. This oil is much smoother and it burns at least 4 times less than other, which I used before and was already mentioned here.
  • ACEA A3/B3 oil recommended for this engine
    #8 16674707
    kkknc
    Help: 1915
    Rate: 6709
    Gentlemen, none of the above. Each engine requires oil of a certain quality. And you all give viscosity. Which allowed to use the engine in a specific climate zone. I will not mention that with stickiness you start tying the kines with mineral or synthetic oil. What has nothing to do with this? First class advising .........
    Engine oil with ACEA A3 / B3 quality is completely available for this engine
    The oil selection calculators are on the oil producer's website.
  • #9 16674749
    leonov
    Help: 1039
    Rate: 2248
    Take it according to this :D Opel Corsa C 1.2L 75km 2000 Gasoline Engine - Best Oil Type, 220,000 Mileage, Previous Cast?
  • #10 16677359
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    @kkknc Valvoline meets this standard, but just out of curiosity goes somewhere to find a catalog with oils and a description of their quality? Because everywhere I am looking is just the class of viscosity is given and the elaborate name of the manufacturer. In the store, it's also foolish to change from right to left.
  • #11 16677687
    kkknc
    Help: 1915
    Rate: 6709
    On the website of the manufacturer of the oil you have everything. There are also product cards.
  • #12 16678079
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    @kkknc actually. Anyway, the author of the subject can pour what I have recommended. The oil is compatible with A3B3.
  • #13 16819974
    Fifiopel256
    I chose the German ROWE semi-synthetic oil 10W40, some new on the market, from what I know is nothing special but the price encouraged me - about PLN 60 for 4l. Thank you, I have completed the information on car oils, I take the above graphic to myself and I will be happy to use it when choosing oil, greetings!
The discussion centers around the appropriate oil type for a 2000 Opel Corsa C with a 1.2L gasoline engine and 220,000 km mileage. Recommendations include using semi-synthetic oil, specifically 10W40 or 5W30, with a preference for reputable brands like Castrol and Valvoline. Concerns about switching from mineral to synthetic oil are addressed, with modern oils being deemed safe for high-mileage engines. Users suggest checking for ACEA A3/B3 quality standards and utilizing oil selection calculators from manufacturers. The original poster ultimately decided on ROWE semi-synthetic oil 10W40 based on price and recommendations.
TL;DR: For a Corsa C 1.2 (2000) with 220,000 km, many owners report success even past 240,000 km; “safer will be semi‑synthesizer” 10W‑40. Choose oil meeting the required quality spec and avoid counterfeits. [Elektroda, zed71, post #16673576] Why it matters: Picking the right oil grade and quality keeps a high‑mileage Opel’s small petrol engine quiet, clean, and leak‑free while avoiding unnecessary wear.
What oil grade is best for an Opel Corsa C 1.2 petrol with high mileage?
Owners recommend 10W‑40 semi‑synthetic as a safe, widely available choice. One poster with over 240,000 km still preferred this path, calling it the safer option when the previous fill is unknown. It balances cold starts and hot protection well in older small petrol engines. [Elektroda, zed71, post #16673576]
Can I use 5W oil (like 5W‑30 or 5W‑40) instead of 10W‑40?
Yes. A 5W full‑synthetic is acceptable for this engine, offering better cold flow while maintaining protection when hot. An experienced member noted a 5W synthetic “might as well” be used in place of a 10W semi‑synthetic. Match the manufacturer’s quality specification when choosing. [Elektroda, leonov, post #16672762]
Which oil quality standard should I follow for the Corsa C 1.2?
Target ACEA A3/B3 quality. As one expert put it, “Engine oil with ACEA A3/B3 quality is completely available for this engine.” Use the oil maker’s online selector or product data sheet to verify the spec on the exact bottle you buy. [Elektroda, kkknc, post #16674707]
Do brands matter much, or should I focus on grade and spec?
Brand matters less than matching viscosity and the correct ACEA specification. A contributor noted the brand “will not make much difference.” Prioritize the right grade and verified quality, then buy from a trusted source to avoid counterfeit stock. [Elektroda, leonov, post #16672785]
Is mineral oil a good idea at 220,000 km?
No. The “mineral is safer for old engines” myth dates to much older designs. A member explained modern engines are unsuitable for mineral oil and recommended switching properly to synthetic instead of downgrading based on mileage alone. [Elektroda, wichurewicz, post #16673738]
How do I safely switch to full synthetic if I don’t know the previous oil?
Use a short pre‑change flush, then fill with the correct synthetic. 1) Warm the engine. 2) Add the rinse additive and idle 10–15 minutes. 3) Drain immediately and refill with the specified synthetic. The poster used this approach before 5W‑30. [Elektroda, wichurewicz, post #16673738]
Is Valvoline MaxLife 10W‑40 a good option for older petrol engines?
One owner ran 280,000 km (180,000 km on MaxLife 10W‑40) and reported the engine burned at least four times less oil than with prior brands. High‑mileage formulas can help sealing and consumption in worn engines when the spec fits. [Elektroda, mkpl, post #16674683]
Does mileage alone decide if I must thicken the oil?
No. A member with over 240,000 km advised not to choose viscosity by mileage alone. Focus on the recommended spec and the engine’s actual condition, noises, consumption, and pressure readings if available. [Elektroda, zed71, post #16673576]
What price should I expect for a decent semi‑synthetic 10W‑40?
A community example: ROWE 10W‑40 semi‑synthetic at roughly PLN 60 for 4 liters. Prices vary by region and retailer, but this shows budget options exist that still meet needs when they match the right specification. [Elektroda, Fifiopel256, post #16819974]
Are counterfeit oils a real issue, and how can I avoid them?
Yes. The forum warned about counterfeit versions of popular brands. Buy from reputable stores, check seals and labels, and verify batch codes against the manufacturer’s site when possible. When unsure, choose trusted retailers over bargain offers. [Elektroda, zed71, post #16673576]
Where can I double‑check the right oil for my exact model?
Use oil manufacturers’ online selection tools and product data sheets. They list engine compatibility and the ACEA specification on each oil. This ensures you buy a bottle that clearly states the required quality class for your engine. [Elektroda, kkknc, post #16674707]
