Opel Corsa C 1.2 Petrol: Appropriate Semi-Synthetic Engine Oil Recommendations & Tips
Silesia87 13497 5
  • #1 17370744
    Silesia87
    Hello, I have to add engine oil because it shows the minimum, and I have no idea how it was poured in there. I only associate something that the mechanic said he poured in semi-synthetic.
    I am talking about Corsa C petrol 1.2
    What can I pour in so that there are no surprises?
  • #2 17370761
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    No, just replace it with a new one, then and only then will you be sure it is ok.
  • Recommend 5W40 synthetic or good semi-synthetic oil
    #3 17372549
    helmud7543
    Help: 1216
    Rate: 1564
    All brand oils are miscible - no snot will do. Do not look at the base, you can give a calm synthesizer, add something that the quality (norm) is acceptable by the manufacturer, universal viscosity is 5W40 in our climate. If you have a semi-synthetic, then lower viscosity there rather than 10W40. We do not know in what condition the engine. Too high a viscosity and can burn oil, too low - if the engine is worn - it can finish off and can also drink oil.
    On the other hand, complete replacement is the optimal solution, the more you don't know what is poured in there (the more synthetic additives, the better the washing properties, in turn, the more mineral base, the more frequent replacement is recommended to keep the engine clean, of course you select the quality class first, then viscosity, then base, but here I recommend a synthetic or good semi-synthetic).
  • #4 17372564
    kkknc
    Help: 1915
    Rate: 6709
    Any oil in a similar class. They are miscible.
  • #5 17372570
    andrzej20001
    Help: 1578
    Rate: 6669
    Ee these 5w30 mowers should probably walk. It's these inventions on the 1.0 1.2 16V chain
  • #6 17372821
    helmud7543
    Help: 1216
    Rate: 1564
    It should, but writes that semi-synthetic, and there are probably 5W30 - which says something about the engine or at least about the previous owner. It is not known in what condition this engine is why I would look for a classy oil for this engine but with a viscosity of 40 - how much is available of course.
