Ford Mondeo MK3 2.0 TDDI: Electric Fuel Pump Absence, Pressure on Injections, Error & Fuses
ALIBABA I 7620 3
  • #1 16631591
    ALIBABA I
    Help: 223
    Rate: 537
    Hello colleagues, is it possible that in my Ford 2.0 TDDI there is no electric fuel pump I searched the bottom of the car to the tank I did not look anywhere, it can not hear the car turns and does not smoke the lack of pressure on injections, were there versions without this pump? I checked the fuses on the computer, there is a fuel pressure error, the injection pump adjuster, because before I get to the adjuster I would like to make sure I greet.
  • #2 16631598
    Don de Leon
    Help: 51
    Rate: 458
    If so, it should be with the rear right mounting on the trailing arm.
  • #3 16633673
    robert_d_g
    Help: 51
    Rate: 250
    ALIBABA I wrote:
    2.0 TDDI
    What engine power?
  • #4 16637923
    ALIBABA I
    Help: 223
    Rate: 537
    robert_d_g wrote:
    What is the engine power?
    Oh, I don't know
    Don de Leon wrote:
    if this is the case it should be at the rear right arm mounting in the longitudinal.
    She is not there, what is the invention? after Sunday, pump type, some symbols of the injection pump engine, etc. I haven't seen it yet. the sea sits there.
