Ford Mondeo MK4 2.0tdci 140km zetec - After warming up the turbine stops working
bejca1233 22245 12
What does P003A mean on a Ford Mondeo MK4 2.0 TDCi when the turbo stops working after warm-up, and should the turbo or its controller be replaced?
P003A means the turbocharger/supercharger pressure control mechanism has reached its programming limit, so the fault points to the turbo control system rather than the MAF sensor alone [#16485529] The thread suggests checking the turbo variable-geometry actuator/sensor and the wiring or connector between them and the ECU, because the turbo itself may still be OK [#16485560] One user fixed the problem by adjusting the turbo “pear”/actuator linkage, which stopped the engine fault from appearing [#17462810] In another case, the cause was excessive shaft clearance in the variable-geometry turbo and the fix was replacing the turbocharger [#18949823]
  • #1 16485495
    bejca1233
    Hello everyone and I ask for help I have a Ford Mondeo mk4 2.0tdci 140km zetec from 2008 the problem is that when the engine heats up to its temperature a yellow exclamation mark lights up, information on the computer FAULT ENGINE and the ESP lights up The engine is getting muddy turbo stops proccessing I connected car under the computer error P003A was displayed I have no idea what this error means and also jerked at 2000 rpm. in each gear I disconnected the air flow meter the jerking stopped and also for some time the turbine did not turn off but after 60km the message FAULT ENGINE lit up again, YELLOW EXCLUSION IS LIGHTED AND ESP today I changed the air flow meter the engine sometimes jerks
    but I still have a problem with turbo I don't know whether to replace the turbine or the controller.
  • #2 16485523
    jenusz11
    Help: 33
    Rate: 196
    in the workshop you would pay half of what you gave for the flow for the diagnosis, but exchange turbo now
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4181
    P003A: 17-2F Position programming limit of turbocharger / supercharger pressure control mechanism exceeded, circuit voltage above threshold.
  • #4 16485534
    bejca1233
    the diagnosis was made in a workshop there I was told that I should replace the air flow meter and as for the error P003A I was told that it could be the fault of the turbine controller itself or the sensor
  • #5 16485560
    jaszczur1111
    Help: 173
    Rate: 494
    The turbine itself is rather functional. The error generates a sensor, computer or some bad connection in between.
  • #6 16485610
    bejca1233
    I read on the internet that the culprit may be the turbine controller, but I have no idea where to look on the internet, I haven't found anything, I don't even know what this sensor looks like
    Added after 4 [hours] 2 [minutes]:
    can the turbocharger variable geometry position sensor be responsible? Ford Mondeo MK4 2.0tdci 140km zetec - After warming up the turbine stops working
  • #7 16509460
    bejca1233
    I changed this sensor of the variable geometry of the turbocharger and my question is whether after the replacement I have to do turbine calibration, some mechanics say yes and some say no
  • #8 16829698
    wary2
    Help: 6
    Rate: 221
    Hi, I currently have the same error, I don't know how to solve it either. I have it right after starting the car. And every time. Have you solved the problem.
  • #9 17451877
    cocolinkaa
    Hello, and how did the PAns deal with this problem? I have the same symptom immediately after driving 5m pops up engine fault
  • #10 17462810
    wary2
    Help: 6
    Rate: 221
    Hi I played with the pear on the turbine and the problem was solved. The error does not pop out.
  • #11 17617200
    Arturoestebano
    Rate: 70
    I have a similar problem, sometimes the engine light illuminates, the turbo is broken, once it pulls the car and once at all, it drives 60 / h for 2-4km and then I press the gas and the car does not pull ...
  • #12 18943748
    d4rk18
    Do you know what was the cause in your cases?
  • #13 18949823
    wary2
    Help: 6
    Rate: 221
    Some of me had large clearances in the turbine on the shaft, which is controlled by geometry. After replacing the turbine OK
The discussion revolves around a Ford Mondeo MK4 2.0 TDCi experiencing turbocharger issues after the engine warms up. The user reports a yellow exclamation mark and "FAULT ENGINE" message, along with turbo malfunction and jerking at 2000 RPM. Error code P003A indicates a position programming limit issue with the turbocharger's pressure control mechanism. Responses suggest that the problem may stem from the turbocharger controller, a faulty sensor, or bad connections rather than the turbo itself. The user has replaced the air flow meter and is considering whether to replace the turbine or the controller. There is also a query about the necessity of turbo calibration after replacing the variable geometry sensor.
