Ford Focus 1.8 TDCI 2001: Post-Fuel System Cleaning Startup Issues and Smoke Output
anna0816 10149 7
  • #1 16820166
    anna0816
    Hello. I need help because I don't know what to do anymore ... The problem is that I have a Ford Focus 1.8 TDI 2001, which after replacing the pump, injection cleaning the entire fuel system including cleaning the tank does not start now the candle indicator lights up and the car goes out. It only fires on the cake but it does not bring the effect because it soars that half the village can not be seen. And I really don't know what to do with him .... I am asking for help.
  • #2 16820377
    Doktorr
    Help: 287
    Rate: 1098
    What errors in the engine controller.
    anna0816 wrote:
    after replacing the pump, injections
    for new, used, after regeneration?
  • #3 16821384
    anna0816
    After regeneration.
  • #4 16824392
    anna0816
    Errors do not show any just that matter
  • #5 16824676
  • #6 16834178
    anna0816
    now fires but only on the cake as it is cold smokes in white sometimes blue in the massacre with this car. Help
  • #7 16836045
  • #8 16844670
    KrzysiekBTW
    Change the fuel filter we had a similar problem the new filter was leaky and pulls the air from the overflow
The discussion revolves around a 2001 Ford Focus 1.8 TDCI experiencing startup issues and excessive smoke output after a fuel system cleaning and pump replacement. The user reports that the vehicle only fires on "the cake" (likely referring to a starting aid) and emits white and sometimes blue smoke. Responses suggest checking for error codes in the engine controller, ensuring proper fuel injection from the common rail system, and verifying the functionality of the injectors. One user recommends changing the fuel filter, as a leaky new filter could be drawing air into the system, exacerbating the starting issues.
