Ford Focus 1.6 tdci 109ps - Turbo Failure, Moaning Sound, Smoke, Post DPF Removal
maliiina.ew 9753 6
  • #1 16896856
    maliiina.ew
    Hello, I was browsing the topics and in each of them there was no other factor than mine, so I write separately (if I did wrong, please connect the mod to a different topic).
    1.6 tdci 109ps engine, in summer replaced turbo engine without factory DPF
    On Thursday, when I drove up to the house, something began to moan slightly with the increase in turnover (I thought it was a leak) I corrected the bands and I guess I drove 5 km, there was no sound and suddenly it began
    It turned out that the turbo does not work, i.e. after firing it pulls the bar down, but with the addition of gas, it does not raise the bar.
    I checked the intake, there is no hole anywhere, the vacuum hoses (I replaced all rubber connectors to be sure) replacing the pierburg with a new one also did not give anything
    (I thought that maybe the vacum pump could not do it, but on the other hand, it would not pull the barbell at the start as if it were so)
    Below, he adds a video of the barbell work, the car kicks hard, the forscan has no errors
    https://youtu.be/FpJ_ATPW2w4
    I miss the idea of what I can still check
    I will do a dump of parameters from forscan and paste here, but what to pay attention to?
    I do not know how to read this csv from forscan but I will put 2 screens (at ease and at 3,000)
    https://i.imgur.com/tQZXFpX.png
    https://i.imgur.com/ok6Gi8u.png
    I got an error for it (nothing had appeared before)
    === PCM DTC P1000-21 ===
    Code: P1000 - On-Board Diagnostic Readiness (OBD) test incomplete
    Additional fault symptoms:
    - Signal above the maximum threshold value
    Status:
    - Pre-set DTC - Not present at time of command.
    - Fault indicator lamp is off with this DTC
    Module: Engine Control Module (Power Train Chain Control Module).
    Details of fault codes
    EOBD readiness test not completed
    This DTC can be caused by:
    Some or all of the EOBD tests are not properly performed.
    EOBD diagnostic functions not performed since last DTC cleared. To resolve this, let the engine run from cold to warm for the diagnostic functions to be successful.
    do not replace the module while this DTC is set
    if this is the only DTC present, return the vehicle to the customer, the DTC will clear under normal operating conditions
    Further information on diagnostics can be found in the appropriate eTIS section.
    === END PCM ===
    === PCM DTC P0014-00 ===
    Code: P0014 - Exhaust valve timing adjustment - too much advance (1 row of cylinders)
    Exhaust valve timing adjustment - too much lead (1st row of cylinders)
    The mechanical parts of the solenoid valve may be jammed.
    Mechanical damage to the engine.
    === END PCM ===
    I took out this sensor, cleaned it, deleted the error and ass
    after firing, there is nothing, I will turn off and the error of this sensor pops up again, so I will have to replace it, or replace it because I have no other idea
  • #2 16897133
  • #3 16897148
    maliiina.ew
    radek3p wrote:
    Have you checked the EGR valve? if it is dirty, the exhaust gas recirculation does not work properly and it is through it that the air goes to the turbine, you can hear in the video that there is a problem with spinning the revolutions.
    I just left the valve for now, I'm waiting for the plug, I will take it off, clean it and plug it
    . but could EGR cut off the turbine?
    So far, I have probably diagnosed this whining from the timing side, the bearing on the alternator or compressor - the sound after removing the accessory belt dies.
  • #4 16897163
    robokop
    Help: 1763
    Rate: 6372
    If you had learned how it works, you wouldn't be asking such questions. In addition, if a timing error appeared, the engine went into emergency operation mode - hence it does not load the turbo as it should. Remove one fault, then look for others.
  • #5 16897210
    maliiina.ew
    Well, that's the point, that I don't know and that's why I'm asking, and I know that the EGR directs some of the exhaust gases into the combustion chamber, with the fact that, as you can see in the photo at 3000 rpm, it closes completely, and I did not receive any error earlier, much less related to EGR.
  • #6 16897227
  • #7 16897253
    maliiina.ew
    radek3p wrote:
    No, I do not understand if the EGR valve at 3000 rpm. closes completely, how is the turbine supposed to work? A colleague wrote to enter the emergency mode so as not to damage the engine.
    but in this engine, the exhaust gases go from the EGR straight to the intake, but behind the turbine, i.e. when the valve is closed (the pedal in the floor), it should not direct the exhaust gases into the combustion chamber, and the turbo should pump with all its strength. And the safe mode should also be signaled? Unless it isn't.
The discussion revolves around a Ford Focus 1.6 TDCi 109ps experiencing turbo failure, characterized by a moaning sound, smoke, and issues following DPF removal. The user reports that after replacing the turbo, the vehicle began to exhibit a whining noise and subsequently lost turbo functionality. Various components were checked, including the intake and vacuum hoses, with no leaks found. Responses suggest checking the EGR valve, as a malfunction could affect turbo operation. The user also considers the possibility of a timing issue, which could trigger emergency mode, preventing proper turbo function. The conversation highlights the importance of diagnosing the EGR and timing system to resolve the turbo issues effectively.
