DVB-T tuner Globo STB T90 lite, which code to enter the universal remote control
Krzysiek27 21405 3
  • #1 16821142
    Krzysiek27
    Rate: 51
    Hello .
    I bought a "UNIVERSAL MULTIMEDIA PILOT 4629 #" and I wanted to replace it with the original remote control because it ended its life (cracked motherboard) to the DVB-T DVB-T Tuner TBO lite.
    In the manual of this remote control there is a brand such as Globo and there are such codes 2273 1626 1429 1334 2026 and 0740, but unfortunately on no tuner does not move.
    The search method tried after pressing the button 250 times I have exhausted my patience.
    I am asking for some advice.
  • #2 16821467
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    Please try the codes from DVB_T KORR, KORR HD128 tuner looks the same as the Globo STB T90 lite.
  • Automatic code search procedure for universal remote
    #3 16822736
    Krzysiek27
    Rate: 51
    I found better instructions on the internet than those included with my remote control :D
    User manual "UNIVERSAL PILOT 4629 #"
    Automatic search
    1. Make sure your device is on (not in standby mode).
    2. Point the remote control towards the device, press and hold for about 3 seconds the button with the type of device you want to operate (TV, DVB-T, DVD, etc.) together with the "OK" button. The red LED should flash on the remote control - it means that the remote control sends a Power OFF signal to the device at one second intervals.
    3. When the device turns off, it means that the remote control has found the correct code for the supported device. Then press the POWER button to save the configuration.
    4. Then check if the other functions of the remote control are working properly (volume, channel switching, etc.). If these functions work correctly - it means finding the correct code for your device. If any of the remote control functions does not work properly - repeat the procedure in points 1 - 3.
    The first automatic code from the edge worked :D
  • #4 18015310
    MIEDZU
    Rate: 14
    I also had a programming problem and found that initiating programming and saving device pairing should be done by pressing the appropriate buttons for 1-2 seconds and "POWER" for 0.5 seconds
