[Solved] Pairing nc+ UltraBox 4K Remote with Manta TV: Troubleshooting & Semi-Automatic Mode Guide
madmac8787 50787 0
  • #1 18640647
    madmac8787
    I have a problem with pairing the ultra box 4k remote control with the manta tv
    I tried this scheme but it doesn't work. Can anyone help? I just want to turn the TV on and off and change the TV volume with the remote control from the set-top box.
    The ilot included in the set is a universal remote control and can additionally control most TV models available on the market. Controlling the TV requires configuring the remote control with a given model of the receiver. The remote control is used to work with 4K UltraBox+ USW 4001NCP and WiFi PremiumBox+ ADB NCP-4740SF set-top boxes. Similarly, you can program the remote control issued to WiFi Box+ SAGEMCOM DSIW74 and Box+ SAGEMCOM DSI83/DSI87.
    Remote control configuration in semi-automatic mode:
    1. Press and hold the TV key until the LED (next to the TV key on the remote control) flashes.
    2. Enter the two-digit code that corresponds to the brand of your TV.
    Manufacturer - Code - semi-automatic programming
    Samsung - 10
    Phillips - 11
    LG - 12
    Panasonic - 13
    Sony - 14
    Thomson - 15
    Grundig - 16
    Sharpe - 17
    JVC - 18
    Toshiba - 19
    Funai - 20
    Hyundai - 21
    Loewe - 22
    Manta - 23
    Akai - 24
    If the code is not accepted, the LED will turn off, then programming must be repeated.
    3. Press the mute key while pointing the remote control towards the switched on TV. If this mutes the sound on the TV, press the OK key.
    If the sound doesn't mute the first time, repeat the step.
    4. Check that the TV can be operated correctly. If not, program the remote manually.
    Remote control configuration in manual mode:
    1. Press and hold the TV key until the LED (on the remote control next to the TV key) starts flashing. Enter the three-digit code that corresponds to the brand of your TV while pointing the remote control at the switched-on TV.
    Example of action for Samsung TV:
    Pressing the TV key
    Releasing the key when the LED starts flashing
    Entering code 826
    Pressing the OK key (if the TV is muted)
    Manufacturer Code - manual programming
    Samsung - 826 828 701 705 713 715 718 179 724 737 759 762 765 770 771
    Philips - 882 858 705 875 880 701 716 730 733 739 762
    LG - 831 837 844 854 868 700 701 705 712 713 715 719 723 733 737 740 762 767 781 785 786
    Panasonic - 777 807 869 700 705 711 713 715 722 733 736 758 761 762
    Sony - 849 856 702 704 705 709 714 731 762
    Thomson - 705 712 719 726 728 730 762 763 771
    Grundig - 839 842 861 863 701 704 705 706 715 716 717 730 737 746 752 756 760 762 765 783
    Sharp - 818 843 875 704 709 758 778 794
    JVC - 875 704 709 720 738 743 767 777 778
    Toshiba - 819 831 835 843 851 855 861 863 701 703 704 705 706 712 716 717 756 770 777 781 785 787
    Funai - 724 742 780
    Hyundai - 808 810 851 853 705 762 783 792
    Loewe - 705 734 737 757 758 762 773 798
    Manta - 881
    Akai - 815 829 850 861 863 701 703 705 713 715 716 718 719 720 724 733 738 740 744 748 749 758 761 762 766 767 772 776 785 7929 7
    2. If the code entered was correct, the remote control will send a mute command to the TV. If the TV responded by muting the sound, press the OK key to save the settings.
    3. Check that the TV can be operated correctly with the remote control. In case of a malfunction, repeat programming by entering the next code from the list for your TV brand.
    If the code is not accepted, the LED will turn off, then repeat programming.
    If the TV does not mute after , enter the next code from the list for your TV brand.
    How to set up a universal remote
    Other functionalities of the remote control:
    "Easy on" function
    Turning on the decoder and the TV set using the standby button (the remote control sends two commands: to the decoder and to the TV set, you must first configure the remote control to work with your TV set)
    Power on - press and hold the TV button, then enter the code "02" and confirm with the OK button.
    Power off - press and hold the TV button, then enter the code "03" and confirm with the OK button.
    "Sound on TV" function
    Control the TV volume with the V - and V + buttons without having to switch to TV mode (without pressing the TV button)
    Power on - press and hold the TV button, then enter the code "04" and confirm with the OK button.
    Power off - press and hold the TV button, then enter the code "05" and confirm with the OK button.
    To restore the remote control to factory settings:
    Enter code "00" and confirm with OK.
