Pairing UPC Horizon Remote Control with Thomson 40FS3246C TV: Seeking Working Codes
prokika 12546 11
What working UPC Horizon remote code can I use to pair the remote with a Thomson 40FS3246C TV?
Try code 2972 for Thomson TVs and follow the UPC instructions on page 9 exactly; after entering the code, test whether the TV turns off and then press Rec to save the pairing [#16976997][#16977126] The remote’s TV on/off button should light red when pairing mode is active [#16977157] If 2972 does not work with your set, try codes for the TV’s underlying platform or chassis, such as TCL, Toshiba, Philips, or Sharp [#16993949]
  • #1 16976940
    prokika
    Hello, I have a horizon decoder, I really want to pair the television with the remote control from the decoder, but no code from upc does not work, additionally the guy from upc was and said that he does not know ... The TV model is Thomson 40fs3246c.
    Please help, maybe someone has a working code.
  • #3 16977062
    prokika
    nomudrek wrote:
    The code for Thomson TVs according to the instructions is 2972, pairing should be carried out strictly according to the instructions on page 9. I doubt that the manufacturer just for this model chose another remote control system.
    https://www.upc.pl/pdf/upc_instrukcja_uzytkownika.pdf?t=1489064044502?t=1516533222857
    So after entering the code, do not press the tv button immediately? Let it go out and press?
  • #4 16977126
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    Follow the instructions on how to turn off the TV, press the Rec button to save.
  • #5 16977134
    prokika
    It just doesn't turn off, I've tried a dozen times and nothing ...
  • #6 16977157
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    Is the TV on / off button on the Horizon remote control lit red as it says in the manual?
  • #7 16977164
    prokika
    Yes, it lights up after pressing a combination of buttons, I release the buttons immediately enters the code, and immediately holds the tv button for a minute. And nothing happens.
    Added after 18 [minutes]:
    As I enter the code u immediately press and hold the button for a minute it flashes every now and then.
  • #8 16993860
    prokika
    Refresh. Please help.
  • #9 16993949
    mychaj
    Help: 214
    Rate: 941
    Search on the net on which guts this Thomson is, my Blaupunkt paired on the code from Sharp, because the original did not bang, it took me about 3 days.
    Check the codes on: TCL, TOSHIBA, PHLIPS, SHARP
  • #10 19569030
    lukszo6561
    unfortunately, the code from TCL changes the screen resolution with the volume key :( and the rest does not react)
  • #11 19617401
    lukszo6561
    the same for me. and before that the remote was working properly, after replacing the remote it does not go; (
  • #12 19617707
    mychaj
    Help: 214
    Rate: 941
    I also have ... a new remote control and he sneezes, I changed the keyboard only ... a bottom and a meter of silt.
The discussion revolves around pairing a UPC Horizon remote control with a Thomson 40FS3246C TV. The user reports difficulties in finding a working code, despite following instructions provided by UPC. A suggested code for Thomson TVs is 2972, with specific pairing instructions referenced. Users share their experiences, noting issues with the remote control's functionality and suggest trying codes from other brands like TCL, Toshiba, Philips, and Sharp. Some users report that alternative codes lead to unintended behavior, such as changing screen resolution with volume controls.
TL;DR: One documented code (2972) is listed for Thomson TVs; “pairing should be carried out strictly according to the instructions.” Use page-9 steps, then save and test. [Elektroda, nomudrek, post #16976997]
Why it matters: This FAQ helps UPC Horizon users quickly pair or troubleshoot a Thomson 40FS3246C without guesswork.
What code works for a Thomson 40FS3246C with a UPC Horizon remote?
Use code 2972, as documented for Thomson TVs in the cited instructions. Enter it using the standard programming sequence, then test power. If the TV responds, save the configuration. “Pairing should be carried out strictly according to the instructions.” [Elektroda, nomudrek, post #16976997]
How do I program the UPC Horizon remote to control my Thomson TV?
  1. Start the remote’s TV programming mode as per the manual.
  2. Enter 2972 and test the TV Power key.
  3. Press Rec to save the pairing once Power works. These steps store the code so the remote controls basic TV functions. [Elektroda, nomudrek, post #16977126]
Do I press the TV button immediately after typing the code?
No. Follow the instructions: test the TV Power key first, then press Rec to save the code. Holding the TV button is not part of the saving step and can prevent pairing from completing. “Press the Rec button to save.” [Elektroda, nomudrek, post #16977126]
The remote’s power LED turns red during programming—is that normal?
Yes. The manual notes the TV power button should light red while in programming mode. That confirms the remote is in the correct state to accept and test a code before saving it. [Elektroda, nomudrek, post #16977157]
2972 doesn’t switch my TV off—what should I try next?
Try codes from related brands that share hardware with some Thomsons: TCL, Toshiba, Philips, or Sharp. Many TVs are rebranded, and alternate brand code sets can control them. Test Power after each entry before saving. [Elektroda, mychaj, post #16993949]
Why does a TCL code change screen resolution when I press Volume?
That code maps the remote’s volume buttons to the TV’s resolution function on some sets. It’s an incompatibility sign. Exit programming, clear that test, and try a different brand code until Power and Volume work correctly. [Elektroda, lukszo6561, post #19569030]
My setup used to work, but after replacing the remote it won’t pair. What changed?
Users report successful control before a remote swap, then pairing failures with the replacement. Newer Horizon remotes can ship with different internals or code libraries, so earlier codes may not behave identically. Try the alternate-brand approach and re-save. [Elektroda, lukszo6561, post #19617401]
The new remote “sneezes” and nothing works—any fixes?
A user with a new remote noted it wouldn’t pair even after changes. If code tests fail repeatedly, request another remote from the provider or try a universal remote known to support Thomson/TCL sets. Document your attempts to speed exchange. [Elektroda, mychaj, post #19617707]
What is the UPC Horizon remote in this context?
It’s the decoder’s remote control that can be programmed to operate the TV for power and volume. The user sought to pair their Thomson 40FS3246C with the Horizon decoder’s remote using brand codes. [Elektroda, prokika, post #16976940]
Can a different brand’s code really control my TV?
Yes. One user paired a Blaupunkt TV using a Sharp code, illustrating how shared components lead to cross-brand compatibility. Try related brands when the listed one fails. [Elektroda, mychaj, post #16993949]
Where are the instructions people mention (like “page 9”) from?
They refer to the official UPC user guide for the Horizon remote. The thread cites page 9 for the pairing steps and the Thomson code reference. [Elektroda, nomudrek, post #16976997]
Any quick checklist to avoid common programming mistakes?
  • Enter 2972 for Thomson and test Power.
  • Do not hold the TV button; use Power to test.
  • Press Rec to save only after a successful Power test.
  • If Power fails, try TCL/Toshiba/Philips/Sharp codes.
  • Confirm the red TV power LED during programming. [Elektroda, nomudrek, post #16976997]
