Task Scheduler Not Overwriting Reports Post-Win10 Update: .bat File Execution Issue
kajoj 5790 5
  • #1 16820305
    kajoj
    I would like to ask my colleagues who are investigating this topic, because I have a similar problem. Namely:
    - I have a * .bat file that starts the process of creating reports on my computer (in Excel), the file is launched by the Task Scheduler,
    - so far, when the application works on WinXP, everything worked, now I updated it to Win10 and it does not work as I would like,
    - the symptom is that when I click directly on the * .bat file, it starts and overwrites the files correctly, if it is done by the Task Scheduler, the program is executed, but the report files are not overwritten ...
    And I don't really know what's going on ...
    Maybe someone met with such a problem ??
    Thanks in advance for any suggestions ...
    I separated as a new topic.
    Do not attach to other people's threads. This causes a mess in the forum.
    RADU23
  • #2 16820427
    djtommy
    Help: 38
    Rate: 41
    If they aren't overwritten, it's probably a permission issue.
    I had a similar problem with the script on Windows Server 2008/2012.
    The script on the Windows 2003 server worked without any problems, not much on the newer ones.
    This started working fine as I converted * .bat to * .exe.
    I don't remember the name of this converter now, but the schedule worked fine when I pointed it to the * .exe file instead of * .bat.
  • #3 16824022
    kajoj
    The idea with the * .exe file does not work. I still don't overwrite my files when I open * .bat through the Task Scheduler.
  • #5 16838817
    kajoj
    I would like to remind myself ... Maybe some more ideas with the problem that remains unsolved by me ... I have no idea :cry:
  • #6 17376725
