[Solved] Explorer.exe Not Starting on Win 10 after Recent Updates - Manual Task Manager Fix
nowynikt 8613 4
  • #1 16891872
    nowynikt
    I have a problem with my Win 10. After installing recent updates, the file explorer.exe does not start at system startup
    If I run it manually from the task manager, everything is ok. Please help [/ td]
  • #3 16893671
    nowynikt
    Here you are
    • FRST.txt (86.37 KB) You must be logged in to download this attachment.
    • Addition.txt (35.84 KB) You must be logged in to download this attachment.
  • #4 16893690
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    The logs show:
    Description: Faulting application name: Explorer.EXE, version: 10.0.16299.125, time stamp: 0xfeba44fb
    Faulting module name: shcore.dll, version: 10.0.16299.15, time stamp: 0x6c07e48f
    It looks like the explorer is starting but closing.
    Uninstall: Advanced Calendar 2.0.0.1000176
    Next to frst.exe, create the Fixlist.txt file with the contents:
    Task: {C50DA7AE-4C7D-4BD6-A43E-A8FB294542BC} - \ Microsoft \ Windows \ UNP \ RunCampaignManager -> No file C: \ Windows \ system32 \ CScript.exe "C: \ ProgramData \ Baidu Security \ Duplicaterecord. js "
    Task: {DCA2E184-99DC-4291-A968-AEED0502D677} - System32 \ Tasks \ SlimDrivers Startup => C: \ Users \ Zbela \ Downloads \ SlimDrivers v2.2.45206.63218 Portable [Full] \ SlimDrivers \ SlimDrivers.exe
    Task: C: \ WINDOWS \ Tasks \ SlimDrivers Startup.job => C: \ Users \ Zbela \ Downloads \ SlimDrivers v2.2.45206.63218 Portable [Full] \ SlimDrivers \ SlimDrivers.exe
    CHR HKLM-x32 \ ... \ Chrome \ Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps: //clients2.google.com/service/update2/crx
    2017-12-16 10:59 - 2017-12-16 11:00 - 002392064 _____ (Farbar) C: \ Users \ Zbela \ Downloads \ FRST64.exe
    2017-12-16 10:58 - 2017-12-16 10:58 - 001752576 _____ (Farbar) C: \ Users \ Zbela \ Downloads \ FRST.exe
    2016-11-13 19:28 - 2017-12-16 10:54 - 000000164 _____ () C: \ Users \ Zbela \ AppData \ Roaming \ sp_data.sys
    In FRST, select Repair.
    Uninstall Baidu Antivirus for now and see if anything changes.
    Also check in clean run mode: https://support.microsoft.com/pl-pl/help/929135/how-to-perform-a-clean-boot-in-windows
  • #5 17308138
    nowynikt
    fixlist has helped. thank you
